A number of users of PPC_MEMSTART (40x, ppc_mmu_32) can just always
use 0 as we don't support booting these kernels at non-zero physical
addresses since their exception vectors must be at 0 (or 0xfffx_xxxx).
For the sub-arches that support relocatable interrupt vectors
(book-e), it's reasonable to have memory start at a non-zero physical
address. For those cases use the variable memstart_addr instead of
the #define PPC_MEMSTART since the only uses of PPC_MEMSTART are for
initialization and in the future we can set memstart_addr at runtime
to have a relocatable kernel.
asm/elf.h, asm/page.h and asm/user.h don't export to userspace now, so we can
drop #ifdef __KERNEL__ for them.
[k.shutemov@gmail.com: remove #ifdef __KERNEL_]
Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com>
Reviewed-by: David Woodhouse <dwmw2@infradead.org>
Cc: <linux-arch@vger.kernel.org>
On platforms doing non-coherent DMA (4xx, 8xx, ...), it's important
that the kmalloc minimum alignment is set to the cache line size, to
avoid sharing cache lines between different objects, so that DMA to
one of the objects doesn't corrupt the other.
32-bit powerpc uses a PTE_FMT macro to handle printk() formatting of
PTE entries (which can vary in type and size). Apparently there was a
good reason for it once, but with current compilers it's simpler just
to workaround the variation with a cast in the printk() itself
(there's only one use).
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
Provide ilog2() fallbacks for powerpc for 32-bit numbers and 64-bit numbers on
ppc64.
include/asm-ppc/ had #ifdef __KERNEL__ in all header files that
are not meant for use by user space, include/asm-powerpc does
not have this yet.
This patch gets us a lot closer there. There are a few cases
where I was not sure, so I left them out. I have verified
that no CONFIG_* symbols are used outside of __KERNEL__
any more and that there are no obvious compile errors when
including any of the headers in user space libraries.
This defines PPC_MEMSTART as 0 because it is still used in a couple
of places in the 32-bit code.
Merge asm-ppc/page.h and asm-ppc64/page.h into asm-powerpc/page.h,
asm-powerpc/page_32.h and asm-powerpc/page_64.h
Built for PPC (common_defconfig), with ARCH=powerpc, mostly built with
ARCH=ppc (other things break the build). Built and booted on P5 LPAR
for PPC64 with ARCH=ppc/powerpc (pseries_defconfig). Mostly built for
iSeries powerpc.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
