path: root/include/asm-powerpc/string.h
2008-04-07[POWERPC] Add hand-coded assembly strcmpSteven Rostedt
We have an assembly version of strncmp for the bootwrapper, but not for the kernel, so we end up using the C version in the kernel. This takes the strncmp code from the bootup and copies it to the kernel proper, adding two instructions so it copes correctly with len==0. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-26[STRING]: Move strcasecmp/strncasecmp to lib/string.cDavid S. Miller
We have several platforms using local copies of identical code. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-25powerpc: fix strncasecmp prototypeLinus Torvalds
It takes a size_t, not an int, as its third argument. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] powerpc: Standardize on _ASM_POWERPC header symbol prefixjdl@freescale.com
Standardize on _ASM_POWERPC_... prefix for all #include exclusion symbols. Fixup all the non-compilers. Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-08-30[PATCH] Move all the very similar files to asm-powerpcStephen Rothwell
They differed in either simple comments or in the protecting ifdefs. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
