path: root/include/asm-powerpc/types.h
2008-05-02powerpc: types: use <asm-generic/int-*.h> for the powerpc architectureH. Peter Anvin
This modifies <asm-powerpc/types.h> to use the <asm-generic/int-*.h> generic include files. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Anton Blanchard <anton@samba.org>
2008-04-17[POWERPC] Move phys_addr_t definition into asm/types.hKumar Gala
Moved phys_addr_t out of mmu-*.h and into asm/types.h so we can use it in places that before would have caused recursive includes. For example to use phys_addr_t in <asm/page.h> we would have included <asm/mmu.h> which would have possibly included <asm/mmu-hash64.h> which includes <asm/page.h>. Wheeee recursive include. CONFIG_PHYS_64BIT is a bit counterintuitive in light of ppc64 systems and thus the config option is only used for ppc32 systems with >32-bit physical addresses (44x, 85xx, 745x, etc.). Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-10-17remove strict ansi check from __u64 in asm/types.hOlaf Hering
Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on 32bit targets. GCC can be made to warn about usage of long long types with ISO C90 (-ansi), but only with -pedantic. You can write this in a way that even then it doesn't cause warnings, namely by: #ifdef __GNUC__ __extension__ typedef __signed__ long long __s64; __extension__ typedef unsigned long long __u64; #endif The __extension__ keyword in front of this switches off any pedantic warnings for this expression. Signed-off-by: Olaf Hering <olh@suse.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-22[POWERPC] Use __attribute__ in asm-powerpcMike Frysinger
Pretty much everyone uses "__attribute__" or "attribute", no one uses "__attribute". This tweaks the three places in asm-powerpc where this comes up. While only asm-powerpc/types.h is interesting (for userspace), I did asm-powerpc/processor.h as well for consistency. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[PATCH] Centralise definitions of sector_t and blkcnt_tMatthew Wilcox
CONFIG_LBD and CONFIG_LSF are spread into asm/types.h for no particularly good reason. Centralising the definition in linux/types.h means that arch maintainers don't need to bother adding it, as well as fixing the problem with x86-64 users being asked to make a decision that has absolutely no effect. The H8/300 porters seem particularly confused since I'm not aware of any microcontrollers that need to support 2TB filesystems. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-26[PATCH] 2TB files: add blkcnt_tTakashi Sato
Add blkcnt_t as the type of inode.i_blocks. This enables you to make the size of blkcnt_t either 4 bytes or 8 bytes on 32 bits architecture with CONFIG_LSF. - CONFIG_LSF Add new configuration parameter. - blkcnt_t On h8300, i386, mips, powerpc, s390 and sh that define sector_t, blkcnt_t is defined as u64 if CONFIG_LSF is enabled; otherwise it is defined as unsigned long. On other architectures, it is defined as unsigned long. - inode.i_blocks Change the type from sector_t to blkcnt_t. Signed-off-by: Takashi Sato <sho@tnes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-27[PATCH] ppc64: make dma_addr_t 64 bitsStephen Rothwell
There has been a need expressed for dma_addr_t to be 64 bits on PPC64. This patch does that. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-26[PATCH] powerpc: Fix types.hBecky Bruce
Powerpc: Fix types.h I noticed that Paul had already pulled the version of types.h that is missing the config.h include into the merge tree - this patch adds it back in. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-20[PATCH] powerpc: Merge types.hBecky Bruce
This patch merges types.h into include/asm-powerpc. The only real change is the removal of the include of linux/config.h from the 32-bit version - it doesn't appear to be necessary. This patch has been built on several different 32 and 64-bit platforms, and booted on mpc8540_ads. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
