path: root/include/asm-powerpc
2007-05-10[POWERPC] Fix warning in hpte_decode(), and generalize itPaul Mackerras
This adds the necessary support to hpte_decode() to handle 1TB segments and 16GB pages, and removes an uninitialized value warning on avpn. We don't have any code to generate HPTEs for 1TB segments or 16GB pages yet, so this is mostly for completeness, and to fix the warning. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2007-05-10[POWERPC] PS3: Fix sys manager build errorGeoff Levand
Fix a PS3 build error when CONFIG_PS3_SYS_MANAGER=n. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-10[POWERPC] Assorted janitorial EEH cleanupsLinas Vepstas
Assorted minor cleanups to EEH code; -- use literals, use kerneldoc format. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> ---- arch/powerpc/platforms/pseries/eeh.c | 13 ++++++++++--- arch/powerpc/platforms/pseries/eeh_driver.c | 7 ++++--- include/asm-powerpc/ppc-pci.h | 18 +++++++++++++++--- 3 files changed, 29 insertions(+), 9 deletions(-) Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-10[POWERPC] We don't define CONFIG_HAVE_ARCH_EARLY_PFN_TO_NIDStephen Rothwell
so this declaration is not needed. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-10[POWERPC] Wire up sys_utimensatStephen Rothwell
2007-05-10Merge branch 'linux-2.6'Paul Mackerras
2007-05-09[POWERPC] User rheap from arch/powerpc/libKumar Gala
Removed rheap in arch/ppc/lib and changed build system to use the one in arch/powerpc/lib. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-05-09[POWERPC] Change rheap functions to use ulongs instead of pointersTimur Tabi
The rheap allocation functions return a pointer, but the actual value is based on how the heap was initialized, and so it can be anything, e.g. an offset into a buffer. A ulong is a better representation of the value returned by the allocation functions. This patch changes all of the relevant rheap functions to use a unsigned long integers instead of a pointer. In case of an error, the value returned is a negative error code that has been cast to an unsigned long. The caller can use the IS_ERR_VALUE() macro to check for this. All code which calls the rheap functions is updated accordingly. Macros IS_MURAM_ERR() and IS_DPERR(), have been deleted in favor of IS_ERR_VALUE(). Also added error checking to rh_attach_region(). Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-05-09[POWERPC] Move reg_booke.h to include/asm-powerpcBecky Bruce
This patch moves a copy of reg_booke.h to include/asm-powerpc and fixes up the ifdef protection. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-05-09Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Further fixes for the removal of 4level-fixup hack from ppc32 [POWERPC] EEH: log all PCI-X and PCI-E AER registers [POWERPC] EEH: capture and log pci state on error [POWERPC] EEH: Split up long error msg [POWERPC] EEH: log error only after driver notification. [POWERPC] fsl_soc: Make mac_addr const in fs_enet_of_init(). [POWERPC] Don't use SLAB/SLUB for PTE pages [POWERPC] Spufs support for 64K LS mappings on 4K kernels [POWERPC] Add ability to 4K kernel to hash in 64K pages [POWERPC] Introduce address space "slices" [POWERPC] Small fixes & cleanups in segment page size demotion [POWERPC] iSeries: Make HVC_ISERIES the default [POWERPC] iSeries: suppress build warning in lparmap.c [POWERPC] Mark pages that don't exist as nosave [POWERPC] swsusp: Introduce register_nosave_region_late
2007-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits) sound: convert "sound" subdirectory to UTF-8 MAINTAINERS: Add cxacru website/mailing list include files: convert "include" subdirectory to UTF-8 general: convert "kernel" subdirectory to UTF-8 documentation: convert the Documentation directory to UTF-8 Convert the toplevel files CREDITS and MAINTAINERS to UTF-8. remove broken URLs from net drivers' output Magic number prefix consistency change to Documentation/magic-number.txt trivial: s/i_sem /i_mutex/ fix file specification in comments drivers/base/platform.c: fix small typo in doc misc doc and kconfig typos Remove obsolete fat_cvf help text Fix occurrences of "the the " Fix minor typoes in kernel/module.c Kconfig: Remove reference to external mqueue library Kconfig: A couple of grammatical fixes in arch/i386/Kconfig Correct comments in genrtc.c to refer to correct /proc file. Fix more "deprecated" spellos. Fix "deprecated" typoes. ... Fix trivial comment conflict in kernel/relay.c.
2007-05-09Remove hardcoding of hard_smp_processor_id on UP systemsFernando Luis Vazquez Cao
With the advent of kdump, the assumption that the boot CPU when booting an UP kernel is always the CPU with a particular hardware ID (often 0) (usually referred to as BSP on some architectures) is not valid anymore. The reason being that the dump capture kernel boots on the crashed CPU (the CPU that invoked crash_kexec), which may be or may not be that particular CPU. Move definition of hard_smp_processor_id for the UP case to architecture-specific code ("asm/smp.h") where it belongs, so that each architecture can provide its own implementation. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Acked-by: Andi Kleen <ak@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09[POWERPC] Don't use SLAB/SLUB for PTE pagesHugh Dickins
The SLUB allocator relies on struct page fields first_page and slab, overwritten by ptl when SPLIT_PTLOCK: so the SLUB allocator cannot then be used for the lowest level of pagetable pages. This was obstructing SLUB on PowerPC, which uses kmem_caches for its pagetables. So convert its pte level to use normal gfp pages (whereas pmd, pud and 64k-page pgd want partpages, so continue to use kmem_caches for pmd, pud and pgd). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-09[POWERPC] Spufs support for 64K LS mappings on 4K kernelsBenjamin Herrenschmidt
This adds an option to spufs when the kernel is configured for 4K page to give it the ability to use 64K pages for SPE local store mappings. Currently, we are optimistic and try order 4 allocations when creating contexts. If that fails, the code will fallback to 4K automatically. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-09[POWERPC] Add ability to 4K kernel to hash in 64K pagesBenjamin Herrenschmidt
This adds the ability for a kernel compiled with 4K page size to have special slices containing 64K pages and hash the right type of hash PTEs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-09[POWERPC] Introduce address space "slices"Benjamin Herrenschmidt
The basic issue is to be able to do what hugetlbfs does but with different page sizes for some other special filesystems; more specifically, my need is: - Huge pages - SPE local store mappings using 64K pages on a 4K base page size kernel on Cell - Some special 4K segments in 64K-page kernels for mapping a dodgy type of powerpc-specific infiniband hardware that requires 4K MMU mappings for various reasons I won't explain here. The main issues are: - To maintain/keep track of the page size per "segment" (as we can only have one page size per segment on powerpc, which are 256MB divisions of the address space). - To make sure special mappings stay within their allotted "segments" (including MAP_FIXED crap) - To make sure everybody else doesn't mmap/brk/grow_stack into a "segment" that is used for a special mapping Some of the necessary mechanisms to handle that were present in the hugetlbfs code, but mostly in ways not suitable for anything else. The patch relies on some changes to the generic get_unmapped_area() that just got merged. It still hijacks hugetlb callbacks here or there as the generic code hasn't been entirely cleaned up yet but that shouldn't be a problem. So what is a slice ? Well, I re-used the mechanism used formerly by our hugetlbfs implementation which divides the address space in "meta-segments" which I called "slices". The division is done using 256MB slices below 4G, and 1T slices above. Thus the address space is divided currently into 16 "low" slices and 16 "high" slices. (Special case: high slice 0 is the area between 4G and 1T). Doing so simplifies significantly the tracking of segments and avoids having to keep track of all the 256MB segments in the address space. While I used the "concepts" of hugetlbfs, I mostly re-implemented everything in a more generic way and "ported" hugetlbfs to it. Slices can have an associated page size, which is encoded in the mmu context and used by the SLB miss handler to set the segment sizes. The hash code currently doesn't care, it has a specific check for hugepages, though I might add a mechanism to provide per-slice hash mapping functions in the future. The slice code provide a pair of "generic" get_unmapped_area() (bottomup and topdown) functions that should work with any slice size. There is some trickiness here so I would appreciate people to have a look at the implementation of these and let me know if I got something wrong. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (77 commits) [POWERPC] Abolish powerpc_flash_init() [POWERPC] Early serial debug support for PPC44x [POWERPC] Support for the Ebony 440GP reference board in arch/powerpc [POWERPC] Add device tree for Ebony [POWERPC] Add powerpc/platforms/44x, disable platforms/4xx for now [POWERPC] MPIC U3/U4 MSI backend [POWERPC] MPIC MSI allocator [POWERPC] Enable MSI mappings for MPIC [POWERPC] Tell Phyp we support MSI [POWERPC] RTAS MSI implementation [POWERPC] PowerPC MSI infrastructure [POWERPC] Rip out the existing powerpc msi stubs [POWERPC] Remove use of 4level-fixup.h for ppc32 [POWERPC] Add powerpc PCI-E reset API implementation [POWERPC] Holly bootwrapper [POWERPC] Holly DTS [POWERPC] Holly defconfig [POWERPC] Add support for 750CL Holly board [POWERPC] Generalize tsi108 PCI setup [POWERPC] Generalize tsi108 PHY types ... Fixed conflict in include/asm-powerpc/kdebug.h manually Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Remove tas()Jeff Dike
tas() has no users, so get rid of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: <linux-arch@vger.kernel.org> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08local_t: powerpc extensionMathieu Desnoyers
[akpm@linux-foundation.org: build fixes] Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08atomic.h: atomic_add_unless as inline. Remove system.h atomic.h circular ↵Mathieu Desnoyers
dependency atomic_add_unless as inline. Remove system.h atomic.h circular dependency. I agree (with Andi Kleen) this typeof is not needed and more error prone. All the original atomic.h code that uses cmpxchg (which includes the atomic_add_unless) uses defines instead of inline functions, probably to circumvent a circular dependency between system.h and atomic.h on powerpc (which my patch addresses). Therefore, it makes sense to use inline functions that will provide type checking. atomic_add_unless as inline. Remove system.h atomic.h circular dependency. Digging into the FRV architecture shows me that it is also affected by such a circular dependency. Here is the diff applying this against the rest of my atomic.h patches. It applies over the atomic.h standardization patches. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08atomic.h: add atomic64 cmpxchg, xchg and add_unless to powerpcMathieu Desnoyers
2007-05-08kdump/kexec: calculate note size at compile timeSimon Horman
Currently the size of the per-cpu region reserved to save crash notes is set by the per-architecture value MAX_NOTE_BYTES. Which in turn is currently set to 1024 on all supported architectures. While testing ia64 I recently discovered that this value is in fact too small. The particular setup I was using actually needs 1172 bytes. This lead to very tedious failure mode where the tail of one elf note would overwrite the head of another if they ended up being alocated sequentially by kmalloc, which was often the case. It seems to me that a far better approach is to caclculate the size that the area needs to be. This patch does just that. If a simpler stop-gap patch for ia64 to be squeezed into 2.6.21(.X) is needed then this should be as easy as making MAX_NOTE_BYTES larger in arch/asm-ia64/kexec.h. Perhaps 2048 would be a good choice. However, I think that the approach in this patch is a much more robust idea. Acked-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08parport->dev driver model supportDavid Brownell
Currently a parport_driver can't get a handle on the device node for the underlying parport (PNPACPI, PCI, etc). That prevents correct placement of sysfs child nodes, which can affect things like power management. This patch adds a field to "struct parport" pointing to that device node, and updates non-legacy port drivers to initialize that device pointer. That field replaces the analagous PCI-only support in parport_pc. [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08[POWERPC] Early serial debug support for PPC44xDavid Gibson
This adds support for early serial debugging via the built in port on IBM/AMCC PowerPC 44x CPUs. It uses a bolted TLB entry in address space 1 for the UART's mapping, allowing robust debugging both before and after the initialization of the MMU. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08[POWERPC] MPIC MSI allocatorMichael Ellerman
To support MSI on MPIC we need a way to reserve and allocate hardware irq numbers, this patch implements an allocator for that purpose. New firmware platforms must define a "msi-available-ranges" property on their MPIC node for MSI to work. For U3/U4 we do a best-guess setup. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08[POWERPC] PowerPC MSI infrastructureMichael Ellerman
This provides the architecture specific hooks to support MSI on powerpc. We implement the newly added arch_setup_msi_irqs() and arch_teardown_msi_irqs(), and then delegate to ppc_md routines. Platforms that don't implement MSI will leave the ppc_md calls blank, arch_msi_check_device() will detect this and return ENOSYS. Drivers should detect this error and continue to use LSI. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08[POWERPC] Rip out the existing powerpc msi stubsMichael Ellerman
Rip out the existing powerpc msi stubs. These were the start of an implementation based on ppc_md calls, but were never used in mainline. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08[POWERPC] Remove use of 4level-fixup.h for ppc32David Gibson
For 32-bit systems, powerpc still relies on the 4level-fixup.h hack, to pretend that the generic pagetable handling stuff is 3-levels rather than 4. This patch removes this, instead using the newer pgtable-nopmd.h to handle the elision of both the pud and pmd pagetable levels (ppc32 pagetables are actually 2 levels). This removes a little extraneous code, and makes it more easily compared to the 64-bit pagetable code. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08Merge branch 'linux-2.6'Paul Mackerras
2007-05-08[POWERPC] Generalize tsi108 PCI setupJosh Boyer
Generalize tsi108_setup_pci to take the config space physical address and primary bus designator as a parameter. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08[POWERPC] Generalize tsi108 PHY typesJosh Boyer
Add a phy_type field to the tsi108 ethernet structures to indicate which PHY is used on a board. This is derived from the "compatible" property in the ethernet-phy node of the device tree. The default remains the MV88E PHY. Also, convert the setup code to use of_get_mac_address instead of hard coding a lookup for the "address" property in the ethernet node. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-08[POWERPC] Add tsi108_pci.h for common PCI functionsJosh Boyer
Add a header file for the common PCI routines used for the TSI bridge Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-07[POWERPC] mpc52xx suspend to deep-sleepDomen Puncer
Implement deep-sleep on MPC52xx. SDRAM is put into self-refresh with help of SRAM code (alternatives would be code in FLASH, I-cache). Interrupt code must also not be in SDRAM, so put it in I-cache. MPC52xx core is static, so contents will remain intact even with clocks turned off. Signed-off-by: Domen Puncer <domen.puncer@telargo.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-07[POWERPC] Export of_device_get_modaliasSylvain Munaut
Apparently other parts of the kernel need to know the modalias internally (like the sysfs code in macintosh driver). To avoid consistency issues, we export this code and use it everywhere it's needed rather than repeat it ... Signed-off-by: Sylvain Munaut <tnt@246tNt.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-07[POWERPC] Kill off the PTE_FMT macroDavid Gibson
32-bit powerpc uses a PTE_FMT macro to handle printk() formatting of PTE entries (which can vary in type and size). Apparently there was a good reason for it once, but with current compilers it's simpler just to workaround the variation with a cast in the printk() itself (there's only one use). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-07[POWERPC] DART iommu suspendJohannes Berg
This implements save and restore hooks for IOMMUs and implements it the DART iommu. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-07[POWERPC] powermac: Support G5 CPU hotplugJohannes Berg
This allows "hotplugging" of CPUs on G5 machines. CPUs that are disabled are put into an idle loop with the decrementer frequency set to minimum. To wake them up again we kick them just like when bringing them up. To stop those CPUs from messing with any global state we stop them from entering the timer interrupt. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-07[POWERPC] MPIC sys_device & suspend/resumeJohannes Berg
This adds mpic to the system devices and implements suspend and resume for them. This is necessary to get interrupts for modules back to where they were before a suspend to disk. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-05Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (231 commits) [PATCH] i386: Don't delete cpu_devs data to identify different x86 types in late_initcall [PATCH] i386: type may be unused [PATCH] i386: Some additional chipset register values validation. [PATCH] i386: Add missing !X86_PAE dependincy to the 2G/2G split. [PATCH] x86-64: Don't exclude asm-offsets.c in Documentation/dontdiff [PATCH] i386: avoid redundant preempt_disable in __unlazy_fpu [PATCH] i386: white space fixes in i387.h [PATCH] i386: Drop noisy e820 debugging printks [PATCH] x86-64: Fix allnoconfig error in genapic_flat.c [PATCH] x86-64: Shut up warnings for vfat compat ioctls on other file systems [PATCH] x86-64: Share identical video.S between i386 and x86-64 [PATCH] x86-64: Remove CONFIG_REORDER [PATCH] x86-64: Print type and size correctly for unknown compat ioctls [PATCH] i386: Remove copy_*_user BUG_ONs for (size < 0) [PATCH] i386: Little cleanups in smpboot.c [PATCH] x86-64: Don't enable NUMA for a single node in K8 NUMA scanning [PATCH] x86: Use RDTSCP for synchronous get_cycles if possible [PATCH] i386: Add X86_FEATURE_RDTSCP [PATCH] i386: Implement X86_FEATURE_SYNC_RDTSC on i386 [PATCH] i386: Implement alternative_io for i386 ... Fix up trivial conflict in include/linux/highmem.h manually. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04ps3: Make `ps3videomode -v 0 (auto mode) work againMasashi Kimoto
ps3: Make `ps3videomode -v 0' (auto mode) work again Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04ps3av: misc updatesGeert Uytterhoeven
ps3av: - Move the definition of struct ps3av to ps3av.c, as it's locally used only. - Kill ps3av.sem, use the existing ps3av.mutex instead. - Make the 512-byte buffer in ps3av_do_pkt() static to reduce stack usage. Its use is protected by a semaphore anyway. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04ps3av: thread updatesGeert Uytterhoeven
ps3av: Replace the kernel_thread and the ping pong semaphores by a singlethread workqueue and a completion. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] x86: PARAVIRT: add hooks to intercept mm creation and destructionJeremy Fitzhardinge
Add hooks to allow a paravirt implementation to track the lifetime of an mm. Paravirtualization requires three hooks, but only two are needed in common code. They are: arch_dup_mmap, which is called when a new mmap is created at fork arch_exit_mmap, which is called when the last process reference to an mm is dropped, which typically happens on exit and exec. The third hook is activate_mm, which is called from the arch-specific activate_mm() macro/function, and so doesn't need stub versions for other architectures. It's called when an mm is first used. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: linux-arch@vger.kernel.org Cc: James Bottomley <James.Bottomley@SteelEye.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2007-05-02[POWERPC] Minor fault path optimizationChristoph Hellwig
Call the kprobes pagefault handler directly instead of going through the complex notifier chain. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Transparently handle <.symbol> lookup for kprobesSrinivasa Ds
When data symbols are not present in kernel image, user needs to add dot(".") before function name explicitly, that he wants to probe in kprobe module on ppc64. for ex:- When data symbols are missing on ppc64, ==================== [root@llm27lp1 ~]# cat /proc/kallsyms | grep do_fork c00000000006283c T .do_fork ============================== User needs add "." to "do_fork" kp.symbol_name = ".do_fork"; ============================ This makes kprobe modules unportable. This fixes the problem. Signed-off-by: Srinivasa Ds <srinivasa@in.ibm.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] PS3: Interrupt routine fixups.Geoff Levand
Fixups for the ps3 interrupt routines to support all HV device in a generic way. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Fix suspend states againJohannes Berg
In commit 0fba3a1f39f8b0a50b56c8b068fa52131cbc84c2 (a very long time ago, May 2006), I fixed a bug that caused powermacs to crash when you tried entering standby/mem suspend states. As I'm now getting more familiar with the suspend code I notice a few more things: 1. we previously misunderstood what pm_ops is for, it isn't supposed to be for doing platform dependent suspend/resume stuff that needs to be done for suspend to disk (as we currently try to use it!), it is instead for entering platform dependent suspend states ("standby", "mem"). 2. due to the first point, we never properly save FPU and altivec states when suspending to disk. It probably hasn't hurt yet because the process that writes the "disk" to /sys/power/state uses neither and its context is used. This patch addresses these points as follows: 1. remove all pm_ops from powermac, powermac suspend to ram isn't currently usable via /sys/power/state but is done via the PMU instead. 2. move the code responsible for storing FPU/altivec state into save_processor_state and the set_context() call to restore_processor_state. 3. add a call to kernel_enable_spe() It may look like there is some code removal missing but that is actually because the new suspend.h file overrides the ppc/suspend.h one which was previously used. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Remove arch/powerpc's dependence on asm-ppc/pg{alloc,table}.hDavid Gibson
Currently, all 32-bit powerpc platforms use asm-ppc/pgtable.h and asm-ppc/pgalloc.h, even when otherwise compiled with ARCH=powerpc. Those asm-ppc files are a fairly nasty tangle of #ifdefs including a bunch of things which shouldn't be necessary any more in arch/powerpc. Cleaning up that mess is going to take a while, but this patch is a first step. It separates the asm-powerpc/pg{alloc,table}.h into 64 bit and 32 bit versions in asm-powerpc, which the basic .h files in asm-powerpc select based on config. We make a few tiny tweaks to the innards of the files along the way, making the outermost ifdefs (double-inclusion protection and __KERNEL__) a little cleaner, and #including asm-generic/pgtable.h from the top-level asm-powerpc/pgtable.h (since both the old 32-bit and 64-bit versions ended with such an #include). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
