path: root/include/asm-s390/system.h
2008-08-01[S390] move include/asm-s390 to arch/s390/include/asmMartin Schwidefsky
2008-06-10[S390] Fix __ctl_load/__ctl_store inline assembly constraintsMartin Schwidefsky
__ctl_load/__ctl_store are called with either an array of unsigned long or a single unsigned long value. Add an address operator to the "m"/"=m" contraints to make them work for unsigned long arguments as well. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-05-07[S390] guest page hinting lightMartin Schwidefsky
Use the existing arch_alloc_page/arch_free_page callbacks to do the guest page state transitions between stable and unused. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-04-30[S390] Convert machine feature detection code to C.Heiko Carstens
From: Heiko Carstens <heiko.carstens@de.ibm.com> From: Carsten Otte <cotte@de.ibm.com> This lets us use defines for the magic bits in machine flags instead of using plain numbers all over the place. In addition on newer machines features/facilities are indicated by the result of the stfl instruction. So we use these bits instead of trying to execute new instructions and check wether we get an exception or not. Also the mvpg instruction is always available when in zArch mode, whereas the idte instruction is only available in zArch mode. This results in some minor optimizations. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-04-30[S390] Move stfl to system.h and delete duplicated version.Heiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-04-17[S390] Export stfle.Heiko Carstens
Make stfle visible so other code can call this. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-02-07Add cmpxchg_local to s390Mathieu Desnoyers
Use the standard __cmpxchg for every type that can be updated atomically. Use the new generic cmpxchg_local (disables interrupt) for other types. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-20[S390] Fix irq tracing and lockdep_sys_exit calls.Heiko Carstens
Current support for TRACE_IRQFLAGS and lockdep_sys_exit is broken. IRQ flag tracing is broken for program checks. Even worse is that the newly introduced calls to lockdep_sys_exit are in the critical section code which is not supposed to call any C functions. In addition the checks if locks are still held are also done when returning to kernel code which is broken as well. Fix all this by disabling interrupts and machine checks at the exit paths and then do the appropriate checks and calls. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-10-12[S390] Force link error if xchg/cmpxchg gets called with unsupported size.Heiko Carstens
2007-07-19[PATCH] sched: sched_cacheflush is now unusedRalf Baechle
Since Ingo's recent scheduler rewrite which was merged as commit 0437e109e1841607f2988891eaa36c531c6aa6ac sched_cacheflush is unused. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-02-05[S390] noexec protectionGerald Schaefer
This provides a noexec protection on s390 hardware. Our hardware does not have any bits left in the pte for a hw noexec bit, so this is a different approach using shadow page tables and a special addressing mode that allows separate address spaces for code and data. As a special feature of our "secondary-space" addressing mode, separate page tables can be specified for the translation of data addresses (storage operands) and instruction addresses. The shadow page table is used for the instruction addresses and the standard page table for the data addresses. The shadow page table is linked to the standard page table by a pointer in page->lru.next of the struct page corresponding to the page that contains the standard page table (since page->private is not really private with the pte_lock and the page table pages are not in the LRU list). Depending on the software bits of a pte, it is either inserted into both page tables or just into the standard (data) page table. Pages of a vma that does not have the VM_EXEC bit set get mapped only in the data address space. Any try to execute code on such a page will cause a page translation exception. The standard reaction to this is a SIGSEGV with two exceptions: the two system call opcodes 0x0a77 (sys_sigreturn) and 0x0aad (sys_rt_sigreturn) are allowed. They are stored by the kernel to the signal stack frame. Unfortunately, the signal return mechanism cannot be modified to use an SA_RESTORER because the exception unwinding code depends on the system call opcode stored behind the signal stack frame. This feature requires that user space is executed in secondary-space mode and the kernel in home-space mode, which means that the addressing modes need to be switched and that the noexec protection only works for user space. After switching the addressing modes, we cannot use the mvcp/mvcs instructions anymore to copy between kernel and user space. A new mvcos instruction has been added to the z9 EC/BC hardware which allows to copy between arbitrary address spaces, but on older hardware the page tables need to be walked manually. Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] pfault code cleanup.Heiko Carstens
2006-09-28[S390] Inline assembly cleanup.Martin Schwidefsky
Major cleanup of all s390 inline assemblies. They now have a common coding style. Quite a few have been shortened, mainly by using register asm variables. Use of the EX_TABLE macro helps as well. The atomic ops, bit ops and locking inlines new use the Q-constraint if a newer gcc is used. That results in slightly better code. Thanks to Christian Borntraeger for proof reading the changes. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-07-17[S390] Fix gcc warning about unused return values.Heiko Carstens
2006-07-14[PATCH] remove set_wmb - arch removalSteven Rostedt
set_wmb should not be used in the kernel because it just confuses the code more and has no benefit. Since it is not currently used in the kernel this patch removes it so that new code does not include it. All archs define set_wmb(var, value) to do { var = value; wmb(); } while(0) except ia64 and sparc which use a mb() instead. But this is still moot since it is not used anyway. Hasn't been tested on any archs but x86 and x86_64 (and only compiled tested) Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: irqtrace subsystem, s390 supportHeiko Carstens
irqtrace support for s390. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-06[PATCH] s390: fix compile with VIRT_CPU_ACCOUNTING=nJan Blunck
When CONFIG_VIRT_CPU_ACCOUNTING is not defined compiling fails with an undefined reference to account_vtime(). Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] s390: cputime misaccountingMartin Schwidefsky
finish_arch_switch needs to update the user cpu time as well, not just the system cpu time. Otherwise the partial user cpu time of a process that is stored in the lowcore will be (mis-)accounted to the next process. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] sched: add cacheflush() asmIngo Molnar
Add per-arch sched_cacheflush() which is a write-back cacheflush used by the migration-cost calibration code at bootup time. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] s390: fix finish_arch_switchHeiko Carstens
Commit 4866cde064afbb6c2a488c265e696879de616daa requires finish_arch_switch to have only one parameter instead of two. Also fix another compile error (double declaration of account_system_vtime) if CONFIG_VIRT_CPU_ACCOUNTING is not defined. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] sched: cleanup context switch lockingNick Piggin
Instead of requiring architecture code to interact with the scheduler's locking implementation, provide a couple of defines that can be used by the architecture to request runqueue unlocked context switches, and ask for interrupts to be enabled over the context switch. Also replaces the "switch_lock" used by these architectures with an oncpu flag (note, not a potentially slow bitflag). This eliminates one bus locked memory operation when context switching, and simplifies the task_running function. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] s390: improved machine check handlingHeiko Carstens
Improved machine check handling. Kernel is now able to receive machine checks while in kernel mode (system call, interrupt and program check handling). Also register validation is now performed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
