path: root/include/asm-sh/rwsem.h
2007-06-08sh: Warn against direct inclusion of <asm/rwsem.h>.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-12-06sh: stacktrace/lockdep/irqflags tracing support.Paul Mundt
Wire up all of the essentials for lockdep.. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-07-03[PATCH] lockdep: remove RWSEM_DEBUG remnantsIngo Molnar
RWSEM_DEBUG used to be a printk based 'tracing' facility, probably used for very early prototypes of the rwsem code. Remove it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] add sem_is_read/write_locked()Rik Van Riel
Add sem_is_read/write_locked functions to the read/write semaphores, along the same lines of the *_is_locked spinlock functions. The swap token tuning patch uses sem_is_read_locked; sem_is_write_locked is added for completeness. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
