path: root/include/asm-sh/se7722.h
2008-04-18sh: SuperH KEYSC keypad data for Solution Engine 7722Magnus Damm
Add KEYSC platform data for the Solution Engine 7722 board. Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-20sh: clean up interrupt code for solution engine 7722 boardMagnus Damm
This patch cleans up solution engine 7722 specific interrupt code. The main purpose is to replace the mux function with use of set_irq_chained_handler() and replace hard coded register poking code with set_irq_type(). The board specific interrupts are also moved to start from SE7722_FPGA_IRQ_BASE. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-07sh: Solution Engine 7722 board support.Ryusuke Sakato
This adds more full-featured support for the SH7722 Solution Engine. Previously this was using the generic board, and lacked most of the peripheral support. Signed-off-by: Ryusuke Sakato <sakato.ryusuke@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
