path: root/include/asm-sh64/pgtable.h
2008-01-28sh: Split out pgtable.h in to _32 and _64 variants.Paul Mundt
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-07-16page table handling cleanupJan Beulich
Kill pte_rdprotect(), pte_exprotect(), pte_mkread(), pte_mkexec(), pte_read(), pte_exec(), and pte_user() except where arch-specific code is making use of them. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Clean up mostly unused IOSPACE macrosDavid Gibson
Most architectures defined three macros, MK_IOSPACE_PFN(), GET_IOSPACE() and GET_PFN() in pgtable.h. However, the only callers of any of these macros are in Sparc specific code, either in arch/sparc, arch/sparc64 or drivers/sbus. This patch removes the redundant macros from all architectures except sparc and sparc64. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26[PATCH] Standardize pxx_page macrosDave McCracken
One of the changes necessary for shared page tables is to standardize the pxx_page macros. pte_page and pmd_page have always returned the struct page associated with their entry, while pte_page_kernel and pmd_page_kernel have returned the kernel virtual address. pud_page and pgd_page, on the other hand, return the kernel virtual address. Shared page tables needs pud_page and pgd_page to return the actual page structures. There are very few actual users of these functions, so it is simple to standardize their usage. Since this is basic cleanup, I am submitting these changes as a standalone patch. Per Hugh Dickins' comments about it, I am also changing the pxx_page_kernel macros to pxx_page_vaddr to clarify their meaning. Signed-off-by: Dave McCracken <dmccr@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-01-10[PATCH] include/asm-sh64/: "extern inline" -> "static inline"Adrian Bunk
"extern inline" doesn't make much sense. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fix remaining missing includesTim Schmielau
Fix more include file problems that surfaced since I submitted the previous fix-missing-includes.patch. This should now allow not to include sched.h from module.h, which is done by a followup patch. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] vm: remove unused/broken page_pte[_prot] macrosTejun Heo
This patch removes page_pte_prot and page_pte macros from all architectures. Some architectures define both, some only page_pte (broken) and others none. These macros are not used anywhere. page_pte_prot(page, prot) is identical to mk_pte(page, prot) and page_pte(page) is identical to page_pte_prot(page, __pgprot(0)). * The following architectures define both page_pte_prot and page_pte arm, arm26, ia64, sh64, sparc, sparc64 * The following architectures define only page_pte (broken) frv, i386, m32r, mips, sh, x86-64 * All other architectures define neither Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] feature removal of io_remap_page_range()Randy Dunlap
As written in Documentation/feature-removal-schedule.txt, remove the io_remap_page_range() kernel API. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] Hugepage consolidationDavid Gibson
A lot of the code in arch/*/mm/hugetlbpage.c is quite similar. This patch attempts to consolidate a lot of the code across the arch's, putting the combined version in mm/hugetlb.c. There are a couple of uglyish hacks in order to covert all the hugepage archs, but the result is a very large reduction in the total amount of code. It also means things like hugepage lazy allocation could be implemented in one place, instead of six. Tested, at least a little, on ppc64, i386 and x86_64. Notes: - this patch changes the meaning of set_huge_pte() to be more analagous to set_pte() - does SH4 need s special huge_ptep_get_and_clear()?? Acked-by: William Lee Irwin <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-19[PATCH] freepgt: arch FIRST_USER_ADDRESS 0Hugh Dickins
Replace misleading definition of FIRST_USER_PGD_NR 0 by definition of FIRST_USER_ADDRESS 0 in all the MMU architectures beyond arm and arm26. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
