path: root/include/asm-sh
2008-07-29Merge branch 'linus' into core/generic-dma-coherentIngo Molnar
Conflicts: arch/x86/Kconfig Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-28sh: Add SuperH Mobile CEU platform data for Migo-RMagnus Damm
Add Migo-R specific platform data for on-chip sh7722 CEU and ov772x camera. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Add SuperH Mobile LCDC platform data for Migo-RMagnus Damm
Add WVGA and QVGA LCD panel support to Migo-R. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Move asid_cache() out of ifdef to fix SH-3/4 nommu build.Paul Mundt
2008-07-28sh: Workaround for __put_user_asm() bug with gcc 4.x on big-endian.Yoshinori Sato
I think this problem is GCC(4.1.2) bug. Syscall "getdents" returned "dirent->d_off" is always 0. I think other EB enviroment have same problem. Problem code 0c03c954 <filldir>: : c03c97a: 58 f7 mov.l @(28,r15),r8 !-> offset (high) c03c97c: 59 f8 mov.l @(32,r15),r9 !-> offset (low) c03c97e: 53 f9 mov.l @(36,r15),r3 c03c980: 54 fa mov.l @(40,r15),r4 : c03c9a0: 21 82 mov.l r8,@r1 !offset(high) -> dirent->d_off It's workaround patch. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Wire up new syscalls.Paul Mundt
This wires up the signalfd4, eventfd2, epoll_create1, dup3, pipe2, and inotify_init1 syscalls. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Use clk_always_enable() on sh7343 / SE77343Magnus Damm
Use clk_always_enable() on the sh7343 processor and in the board code for Solution Engine 7343. Remove duplicate MSTPCR register definitions. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Use clk_always_enable() on sh7722 / Migo-R / SE7722Magnus Damm
Use clk_always_enable() on the sh7722 processor and in the board code for Migo-R and Solution Engine 7722. Remove duplicate MSTPCR register definitions. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Introduce clk_always_enable() functionMagnus Damm
Add SuperH specific funcion clk_always_enable(), useful to enable MSTPCR bits in processor or board specific code. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Add SuperH Mobile MSTPCR bits to clock frameworkMagnus Damm
Handle module stop clock bits in MSTPCRn through the clock framework. The clocks are named after the bits in the data sheet. The association between bit number and hardware block is processor specific. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Add arch_flags to struct clkMagnus Damm
Add arch_flags to struct clk so we can keep per-clock private data somewhere and share code between multiple clocks. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Renesas R0P7785LC0011RL board supportYoshihiro Shimoda
This adds initial support for the Renesas R0P7785LC0011RL board. This patch supports 29bit address mode only. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Add memory chunks to SH-Mobile UIO devicesMagnus Damm
This patch adds physically contiguous memory chunks to the UIO devices. The same strategy can be used in the future for the CEU as well. Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: update Solution Engine 7343Yoshihiro Shimoda
updated the following codes for Solution Endine 7343: - fix compile error in arch/sh/boards/se/7343/irq.c - add nor flash physmaps - update defconfig Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: update sh7343 codeYoshihiro Shimoda
updated the following codes for SH7343: - add register_intc_controller() - add EARLY_SCIF_CONSOLE_PORT - add define of CPG register Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: add interrupt ack code to sh4aYoshihiro Shimoda
This patch is based on interrupt acknowledge code for external interrupt sources on sh3 processors and adds on sh4a processors. Signed-off-by: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Optimized flush_icache_range() implementation.Chris Smith
Add implementation of flush_icache_range() suitable for signal handler and kprobes. Remove flush_cache_sigtramp() and change signal.c to use flush_icache_range(). Signed-off-by: Chris Smith <chris.smith@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Stub in silicon cut in CPU info.Stuart Menefy
Signed-off-by: Stuart Menefy <stuart.menefy@st.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Clean up code of Solution Engine 770xNobuhiro Iwamatsu
Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Solution Enginge 7710/7712 SH-Ether supportNobuhiro Iwamatsu
Add support SH-Ether for Hitachi Solution Engine. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh/kernel/ cleanupsAdrian Bunk
This patch contains the following cleanups: - make the following needlessly global code static: - cf-enabler.c: cf_init() - cpu/clock.c: __clk_enable() - cpu/clock.c: __clk_disable() - process_32.c: default_idle() - time_32.c: struct clocksource_sh - timers/timer-tmu.c: struct tmu_timer_ops - remove the following unused functions (no CONFIG_BLK_DEV_FD on sh): - process_{32,64}.c: disable_hlt() - process_{32,64}.c: enable_hlt() Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Renesas Solutions SH7763RDP board supportNobuhiro Iwamatsu
This patch adds basic support for the SH7763RDP board. This supports a basic stuff provided in SH7763, like SCIF, NOR Flash and USB host. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Initial consolidation of the _32/_64 uaccess split.Paul Mundt
This consolidates everything but the bare assembly routines, which we will sync up in a follow-up patch. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Consolidate addr/access_ok across mmu/nommu on 32bit.Paul Mundt
2008-07-28sh: Use the common segment definitions for the _64 uaccess routines.Paul Mundt
2008-07-28sh: Add support for 16kB PAGE_SIZE.Paul Mundt
16kB is a useful size on nommu, while 64kB still tends to be too big to be useful. Newer MMUs are likely to support this as well, so plug it in in anticipation of those, too. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Consolidate segment modifiers across mmu/nommu systems.Paul Mundt
This moves get_fs/set_fs() and friends in to asm/segment.h. The mm_segment_t definition is likewise consolidated from the _32/_64 split. This is prepatory groundwork for using the generic address space limit and verification routines across mmu/nommu configs. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Initial ELF FDPIC support.Paul Mundt
This adds initial support for ELF FDPIC on MMU-less SH, as per version 0.2 of the ABI definition at: http://www.codesourcery.com/public/docs/sh-fdpic/sh-fdpic-abi.txt Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-28sh: Prevent leaking of CONFIG_SUPERH32 to userspace in asm/unistd.h.Khem Raj
CONFIG_SUPERH32 is currently trickling into userspace unistd.h. Attached patch uses __SH5__ define in userspace. Signed-off-by: Khem Raj <raj.khem@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-07-26[PATCH] kill altrootAl Viro
long overdue... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25Merge git://git.infradead.org/~dwmw2/random-2.6Linus Torvalds
* git://git.infradead.org/~dwmw2/random-2.6: remove dummy asm/kvm.h files firmware: create firmware binaries during 'make modules'.
2008-07-25remove dummy asm/kvm.h filesAdrian Bunk
This patch removes the dummy asm/kvm.h files on architectures not (yet) supporting KVM and uses the same conditional headers installation as already used for a.out.h . Also removed are superfluous install rules in the s390 and x86 Kbuild files (they are already in Kbuild.asm). Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-25include/asm/ptrace.h userspace headers cleanupAdrian Bunk
This patch contains the following cleanups for the asm/ptrace.h userspace headers: - include/asm-generic/Kbuild.asm already lists ptrace.h, remove the superfluous listings in the Kbuild files of the following architectures: - cris - frv - powerpc - x86 - don't expose function prototypes and macros to userspace: - arm - blackfin - cris - mn10300 - parisc - remove #ifdef CONFIG_'s around #define's: - blackfin - m68knommu - sh: AFAIK __SH5__ should work in both kernel and userspace, no need to leak CONFIG_SUPERH64 to userspace - xtensa: cosmetical change to remove empty #ifndef __ASSEMBLY__ #else #endif from the userspace headers Not changed by this patch is the fact that the following architectures have a different struct pt_regs depending on CONFIG_ variables: - h8300 - m68knommu - mips This does not work in userspace. Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: <linux-arch@vger.kernel.org> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Grant Grundler <grundler@parisc-linux.org> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Chris Zankel <chris@zankel.net> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25clean up duplicated alloc/free_thread_infoFUJITA Tomonori
We duplicate alloc/free_thread_info defines on many platforms (the majority uses __get_free_pages/free_pages). This patch defines common defines and removes these duplicated defines. __HAVE_ARCH_THREAD_INFO_ALLOCATOR is introduced for platforms that do something different. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (76 commits) ide: use proper printk() KERN_* levels in ide-probe.c ide: fix for EATA SCSI HBA in ATA emulating mode ide: remove stale comments from drivers/ide/Makefile ide: enable local IRQs in all handlers for TASKFILE_NO_DATA data phase ide-scsi: remove kmalloced struct request ht6560b: remove old history ht6560b: update email address ide-cd: fix oops when using growisofs gayle: release resources on ide_host_add() failure palm_bk3710: add UltraDMA/100 support ide: trivial sparse annotations ide: ide-tape.c sparse annotations and unaligned access removal ide: drop 'name' parameter from ->init_chipset method ide: prefix messages from IDE PCI host drivers by driver name it821x: remove DECLARE_ITE_DEV() macro it8213: remove DECLARE_ITE_DEV() macro ide: include PCI device name in messages from IDE PCI host drivers ide: remove <asm/ide.h> for some archs ide-generic: remove ide_default_{io_base,irq}() inlines (take 3) ide-generic: is no longer needed on ppc32 ...
2008-07-24ide: remove <asm/ide.h> for some archsBartlomiej Zolnierkiewicz
* Remove <linux/irq.h> include from <asm-ia64.h> (<linux/ide.h> includes <linux/interrupt.h> which is enough). * Remove <asm/ide.h> for alpha/blackfin/h8300/ia64/m32r/sh/x86/xtensa (this leaves us with arm/frv/m68k/mips/mn10300/parisc/powerpc/sparc[64]). There should be no functional changes caused by this patch. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-07-24Merge branch 'semaphore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc * 'semaphore' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: Remove __DECLARE_SEMAPHORE_GENERIC Remove asm/semaphore.h Remove use of asm/semaphore.h Add missing semaphore.h includes Remove mention of semaphores from kernel-locking
2008-07-24video: sh7760fb: SH7760/SH7763 LCDC framebuffer driverNobuhiro Iwamatsu
Framebuffer driver for the SH7760/SH7763 integrated LCD controller. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu.nobuhiro@renesas.com> Reviewed-by: Paul Mundt <lethal@linux-sh.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Siegfried Schaefer <s.schaefer@schaefer-edv.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24fbdev: SuperH Mobile LCDC DriverMagnus Damm
This is the SuperH Mobile LCDC frame buffer driver V2, adding support for the LCDC block found in SuperH Mobile processors. The hardware supports up to two LCD panels per LCDC block, and both RGB and SYS interfaces can be used to hook up LCD panels/modules. The device driver is a regular platform driver, so LCD configuration and board specific hooks are passed to the driver using platform data. LCD modules using SYS interface often require special configuration using the SYS bus, and to solve this cleanly the driver provides SYS interface operations to the board code. Tested on sh7723 and sh7722 processors with a SYS16A QVGA panel and WVGA panels using RGB16 and RGB18 interfaces. Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: Paul Mundt <lethal@linux-sh.org> Reviewed-by: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24PAGE_ALIGN(): correctly handle 64-bit values on 32-bit architecturesAndrea Righi
On 32-bit architectures PAGE_ALIGN() truncates 64-bit values to the 32-bit boundary. For example: u64 val = PAGE_ALIGN(size); always returns a value < 4GB even if size is greater than 4GB. The problem resides in PAGE_MASK definition (from include/asm-x86/page.h for example): #define PAGE_SHIFT 12 #define PAGE_SIZE (_AC(1,UL) << PAGE_SHIFT) #define PAGE_MASK (~(PAGE_SIZE-1)) ... #define PAGE_ALIGN(addr) (((addr)+PAGE_SIZE-1)&PAGE_MASK) The "~" is performed on a 32-bit value, so everything in "and" with PAGE_MASK greater than 4GB will be truncated to the 32-bit boundary. Using the ALIGN() macro seems to be the right way, because it uses typeof(addr) for the mask. Also move the PAGE_ALIGN() definitions out of include/asm-*/page.h in include/linux/mm.h. See also lkml discussion: http://lkml.org/lkml/2008/6/11/237 [akpm@linux-foundation.org: fix drivers/media/video/uvc/uvc_queue.c] [akpm@linux-foundation.org: fix v850] [akpm@linux-foundation.org: fix powerpc] [akpm@linux-foundation.org: fix arm] [akpm@linux-foundation.org: fix mips] [akpm@linux-foundation.org: fix drivers/media/video/pvrusb2/pvrusb2-dvb.c] [akpm@linux-foundation.org: fix drivers/mtd/maps/uclinux.c] [akpm@linux-foundation.org: fix powerpc] Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24hugetlb: modular state for hugetlb page sizeAndi Kleen
The goal of this patchset is to support multiple hugetlb page sizes. This is achieved by introducing a new struct hstate structure, which encapsulates the important hugetlb state and constants (eg. huge page size, number of huge pages currently allocated, etc). The hstate structure is then passed around the code which requires these fields, they will do the right thing regardless of the exact hstate they are operating on. This patch adds the hstate structure, with a single global instance of it (default_hstate), and does the basic work of converting hugetlb to use the hstate. Future patches will add more hstate structures to allow for different hugetlbfs mounts to have different page sizes. [akpm@linux-foundation.org: coding-style fixes] Acked-by: Adam Litke <agl@us.ibm.com> Acked-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24mm: remove double indirection on tlb parameter to free_pgd_range() & CoJan Beulich
The double indirection here is not needed anywhere and hence (at least) confusing. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24Remove asm/semaphore.hMatthew Wilcox
All users have now been converted to linux/semaphore.h and we don't need to keep these files around any longer. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2008-07-18Sh: use generic per-device coherent dma allocatorDmitry Baryshkov
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-26sh: convert to generic helpers for IPI function callsJens Axboe
This converts sh to use the new helpers for smp_call_function() and friends, and adds support for smp_call_function_single(). Not tested, but it compiles. Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-06-02sh: fix miscompilation of ip_fast_csum with gcc >= 4.3Paul Mundt
As noted by Matthew Wilcox: Kyle McMartin just tracked down a bug on parisc to a missing "memory" clobber in the inline assembly implementation of ip_fast_csum. The FRV, SH and Xtensa ports are also missing a memory clobber, so I thought it would be polite to let you know. The bug manifests as dropped network packets (obviously they have the wrong checksum). It started appearing for parisc with GCC 4.3. The GCC manual says: If your assembler instructions access memory in an unpredictable fashion, add `memory' to the list of clobbered registers. This will cause GCC to not keep memory values cached in registers across the assembler instruction and not optimize stores or loads to that memory. I see that FRV has a 400 byte memory output which may prevent this problem from appearing, but SH and Xtensa have nothing to prevent this bug. Hope this saves you a few days of debugging. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-16sh: use the common ascii hex helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-09sh: Fix DMAC base address for SH7709SSteve Glendinning
On SH7709S, DMAC can be found at 0xa4000020 (as with most of the other sh3 cpu subtypes). Split out definition of DMAC base address from definitions of DMTE irqs. Signed-off-by: Steve Glendinning <steve.glendinning@smsc.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2008-05-08sh: Stub in cpu_to_node() and friends for NUMA build.Paul Mundt
