path: root/include/asm-sparc/mbus.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc/mm/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code static: - fault.c: force_user_fault() - init.c: calc_max_low_pfn() - init.c: pgt_cache_water[] - init.c: map_high_region() - srmmu.c: hwbug_bitmask - srmmu.c: srmmu_swapper_pg_dir - srmmu.c: srmmu_context_table - srmmu.c: is_hypersparc - srmmu.c: srmmu_cache_pagetables - srmmu.c: srmmu_nocache_size - srmmu.c: srmmu_nocache_end - srmmu.c: srmmu_get_nocache() - srmmu.c: srmmu_free_nocache() - srmmu.c: srmmu_early_allocate_ptable_skeleton() - srmmu.c: srmmu_nocache_calcsize() - srmmu.c: srmmu_nocache_init() - srmmu.c: srmmu_alloc_thread_info() - srmmu.c: early_pgtable_allocfail() - srmmu.c: srmmu_early_allocate_ptable_skeleton() - srmmu.c: srmmu_allocate_ptable_skeleton() - srmmu.c: srmmu_inherit_prom_mappings() - sunami.S: tsunami_copy_1page - remove the following unused code: - init.c: struct sparc_aliases Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-03[SPARC]: "extern inline" doesn't make much sense.Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
