path: root/include/asm-sparc/timer.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc: join the remaining header filesSam Ravnborg
With this commit all sparc64 header files are moved to asm-sparc. The remaining files (71 files) were too different to be trivially merged so divide them up in a _32.h and a _64.h file which are both included from the file with no bit size. The following script were used: cd include FILES=`wc -l asm-sparc64/*h | grep -v '^ 1' | cut -b 20-` for FILE in ${FILES}; do echo $FILE: BASE=`echo $FILE | cut -d '.' -f 1` FN32=${BASE}_32.h FN64=${BASE}_64.h GUARD=___ASM_SPARC_`echo $BASE | tr '-' '_' | tr [:lower:] [:upper:]`_H git mv asm-sparc/$FILE asm-sparc/$FN32 git mv asm-sparc64/$FILE asm-sparc/$FN64 echo git mv done printf "#ifndef %s\n" $GUARD > asm-sparc/$FILE printf "#define %s\n" $GUARD >> asm-sparc/$FILE printf "#if defined(__sparc__) && defined(__arch64__)\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN64 >> asm-sparc/$FILE printf "#else\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN32 >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE git add asm-sparc/$FILE echo new file done printf "#include <asm-sparc/%s>\n" $FILE > asm-sparc64/$FILE git add asm-sparc64/$FILE echo sparc64 file done done The guard contains three '_' to avoid conflict with existing guards. In additing the two Kbuild files are emptied to avoid breaking headers_* targets. We will reintroduce the exported header files when the necessary kbuild changes are merged. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17sparc/kernel/: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global code static: - apc.c: apc_swift_idle() - ebus.c: ebus_blacklist_irq() - ebus.c: fill_ebus_child() - ebus.c: fill_ebus_device() - entry.S: syscall_is_too_hard - etra: tsetup_sun4c_stackchk - head.S: cputyp - head.S: prom_vector_p - idprom.c: Sun_Machines[] - ioport.c: _sparc_find_resource() - ioport.c: create_proc_read_entry() - irq.c: struct sparc_irq[] - rtrap.S: sun4c_rett_stackchk - setup.c: prom_sync_me() - setup.c: boot_flags - sun4c_irq.c: sun4c_sbint_to_irq() - sun4d_irq.c: sbus_tid[] - sun4d_irq.c: struct sbus_actions - sun4d_irq.c: sun4d_sbint_to_irq() - sun4m_irq.c: sun4m_sbint_to_irq() - sun4m_irq.c: sun4m_get_irqmask() - sun4m_irq.c: sun4m_timers - sun4m_smp.c: smp4m_cross_call() - sun4m_smp.c: smp4m_blackbox_id() - sun4m_smp.c: smp4m_blackbox_current() - time.c: sp_clock_typ - time.c: sbus_time_init() - traps.c: instruction_dump() - wof.S: spwin_sun4c_stackchk - wuf.S: sun4c_fwin_stackchk - #if 0 the following unused code: - process.c: sparc_backtrace_lock - process.c: __show_backtrace() - process.c: show_backtrace() - process.c: smp_show_backtrace_all_cpus() - remove the following unused code: - entry.S: __handle_exception - smp.c: smp_num_cpus - smp.c: smp_activated - smp.c: __cpu_number_map[] - smp.c: __cpu_logical_map[] - smp.c: bitops_spinlock - traps.c: trap_curbuf - traps.c: trapbuf[] - traps.c: linux_smp_still_initting - traps.c: thiscpus_tbr - traps.c: thiscpus_mid Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
