path: root/include/asm-sparc64/bbc.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc: copy sparc64 specific files to asm-sparcSam Ravnborg
Used the following script to copy the files: cd include set -e SPARC64=`ls asm-sparc64` for FILE in ${SPARC64}; do if [ -f asm-sparc/$FILE ]; then echo $FILE exist in asm-sparc else git mv asm-sparc64/$FILE asm-sparc/$FILE printf "#include <asm-sparc/$FILE>\n" > asm-sparc64/$FILE git add asm-sparc64/$FILE fi done Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
