path: root/include/asm-sparc64/hypervisor.h
2007-12-13[SPARC64]: Fix two kernel linear mapping setup bugs.David S. Miller
This was caught and identified by Greg Onufer. Since we setup the 256M/4M bitmap table after taking over the trap table, it's possible for some 4M mapping to get loaded in the TLB beforhand which later will be 256M mappings. This can cause illegal TLB multiple-match conditions. Fix this by setting up the bitmap before we take over the trap table. Next, __flush_tlb_all() was not doing anything on hypervisor platforms. Fix by adding sun4v_mmu_demap_all() and calling it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16[SPARC64]: Initial LDOM cpu hotplug support.David S. Miller
Only adding cpus is supports at the moment, removal will come next. When new cpus are configured, the machine description is updated. When we get the configure request we pass in a cpu mask of to-be-added cpus to the mdesc CPU node parser so it only fetches information for those cpus. That code also proceeds to update the SMT/multi-core scheduling bitmaps. cpu_up() does all the work and we return the status back over the DS channel. CPUs via dr-cpu need to be booted straight out of the hypervisor, and this requires: 1) A new trampoline mechanism. CPUs are booted straight out of the hypervisor with MMU disabled and running in physical addresses with no mappings installed in the TLB. The new hvtramp.S code sets up the critical cpu state, installs the locked TLB mappings for the kernel, and turns the MMU on. It then proceeds to follow the logic of the existing trampoline.S SMP cpu bringup code. 2) All calls into OBP have to be disallowed when domaining is enabled. Since cpus boot straight into the kernel from the hypervisor, OBP has no state about that cpu and therefore cannot handle being invoked on that cpu. Luckily it's only a handful of interfaces which can be called after the OBP device tree is obtained. For example, rebooting, halting, powering-off, and setting options node variables. CPU removal support will require some infrastructure changes here. Namely we'll have to process the requests via a true kernel thread instead of in a workqueue. workqueues run on a per-cpu thread, but when unconfiguring we might need to force the thread to execute on another cpu if the current cpu is the one being removed. Removal of a cpu also causes the kernel to destroy that cpu's workqueue running thread. Another issue on removal is that we may have interrupts still pointing to the cpu-to-be-removed. So new code will be needed to walk the active INO list and retarget those cpus as-needed. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-13[SPARC64]: Fix args to sun4v_ldc_revoke().David S. Miller
First argument is LDC channel ID, then mapping cookie, then the MTE revoke cookie. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-04[SPARC64]: Provide mmu statistics via sysfs.David Miller
If the system supports hypervisor based statistics, allow them to be fetched, enabled, and disabled via sysfs. Enable and disable via the boolean: /sys/devices/systems/cpu/cpuN/mmustat_enable Statistic values are provided under: /sys/devices/systems/cpu/cpuN/mmu_status/ Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[SPARC64]: Add missing NCS and SVC hypervisor interfaces.David S. Miller
2007-05-29[SPARC64]: Fill holes in hypervisor APIs and fix KTSB registry.David S. Miller
Several interfaces were missing and others misnumbered or improperly documented. Also, make sure to check the return value when registering the kernel TSBs with the hypervisor. This helped to find the 4MB kernel TSB alignment bug fixed in a previous changeset. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-29[SPARC64]: Use machine description and OBP properly for cpu probing.David S. Miller
2007-05-29[SPARC64]: Report proper system soft state to the hypervisor.David S. Miller
2007-05-15[SPARC64]: Add hypervisor API negotiation and fix console bugs.David S. Miller
Hypervisor interfaces need to be negotiated in order to use some API calls reliably. So add a small set of interfaces to request API versions and query current settings. This allows us to fix some bugs in the hypervisor console: 1) If we can negotiate API group CORE of at least major 1 minor 1 we can use con_read and con_write which can improve console performance quite a bit. 2) When we do a console write request, we should hold the spinlock around the whole request, not a byte at a time. What would happen is that it's easy for output from different cpus to get mixed with each other. 3) Use consistent udelay() based polling, udelay(1) each loop with a limit of 1000 polls to handle stuck hypervisor console. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Fix bugs in SUN4V cpu mondo dispatch.David S. Miller
There were several bugs in the SUN4V cpu mondo dispatch code. In fact, if we ever got a EWOULDBLOCK or other error from the hypervisor call, we'd potentially send a cpu mondo multiple times to the same cpu and even worse we could loop until the timeout resending the same mondo over and over to such cpus. So let's bulletproof this thing as follows: 1) Implement cpu_mondo_send() and cpu_state() hypervisor calls in arch/sparc64/kernel/entry.S, add prototypes to asm/hypervisor.h 2) Don't build and update the cpulist using inline functions, this was causing the cpu mask to not get updated in the caller. 3) Disable interrupts during the entire mondo send, otherwise our cpu list and/or mondo block could get overwritten if we take an interrupt and do a cpu mondo send on the current cpu. 4) Check for all possible error return types from the cpu_mondo_send() hypervisor call. In particular: HV_EOK) Our work is done, all cpus have received the mondo. HV_CPUERROR) One or more of the cpus in the cpu list we passed to the hypervisor are in error state. Use cpu_state() calls over the entries in the cpu list to see which ones. Record them in "error_mask" and report this after we are done sending the mondo to cpus which are not in error state. HV_EWOULDBLOCK) We need to keep trying. Any other error we consider fatal, we report the event and exit immediately. 5) We only timeout if forward progress is not made. Forward progress is defined as having at least one cpu get the mondo successfully in a given cpu_mondo_send() call. Otherwise we bump a counter and delay a little. If the counter hits a limit, we signal an error and report the event. Also, smp_call_function_mask() error handling reports the number of cpus incorrectly. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Add sun4v_cpu_yield().David S. Miller
2006-03-20[SPARC64]: Add sun4v_cpu_qconf() hypervisor call.David S. Miller
Call it from register_one_mondo(). Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Make error codes available from sun4v_intr_get*().David S. Miller
And check for errors at call sites. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Fix comment typo in asm/hypervisor.hDavid S. Miller
2006-03-20[SPARC64]: Implement rest of generic interrupt hypervisor calls.David S. Miller
2006-03-20[SPARC64]: Move devino_to_sysino out of pci_sun4v_asm.SDavid S. Miller
It is not PCI specific, it is for all system interrupts. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Add HV_PCI_TSBID() macro.David S. Miller
For constructing hypervisor PCI TSB IDs. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: Fix some comment typos in asm/hypervisor.hDavid S. Miller
2006-03-20[SPARC64]: SUN4V hypervisor interface defines.David S. Miller
