path: root/include/asm-sparc64/io.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc: join the remaining header filesSam Ravnborg
With this commit all sparc64 header files are moved to asm-sparc. The remaining files (71 files) were too different to be trivially merged so divide them up in a _32.h and a _64.h file which are both included from the file with no bit size. The following script were used: cd include FILES=`wc -l asm-sparc64/*h | grep -v '^ 1' | cut -b 20-` for FILE in ${FILES}; do echo $FILE: BASE=`echo $FILE | cut -d '.' -f 1` FN32=${BASE}_32.h FN64=${BASE}_64.h GUARD=___ASM_SPARC_`echo $BASE | tr '-' '_' | tr [:lower:] [:upper:]`_H git mv asm-sparc/$FILE asm-sparc/$FN32 git mv asm-sparc64/$FILE asm-sparc/$FN64 echo git mv done printf "#ifndef %s\n" $GUARD > asm-sparc/$FILE printf "#define %s\n" $GUARD >> asm-sparc/$FILE printf "#if defined(__sparc__) && defined(__arch64__)\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN64 >> asm-sparc/$FILE printf "#else\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN32 >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE git add asm-sparc/$FILE echo new file done printf "#include <asm-sparc/%s>\n" $FILE > asm-sparc64/$FILE git add asm-sparc64/$FILE echo sparc64 file done done The guard contains three '_' to avoid conflict with existing guards. In additing the two Kbuild files are emptied to avoid breaking headers_* targets. We will reintroduce the exported header files when the necessary kbuild changes are merged. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-30sparc64: IO accessors fixBenjamin Herrenschmidt
From: Benjamin Herrenschmidt <benh@kernel.crashing.org> I added a full memory clobber on all asm accessors except the _raw ones. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-09[SPARC64]: Add SG merging support back into IOMMU code.David S. Miller
Mimicks almost perfectly the powerpc IOMMU code, except that it doesn't have the IOMMU_PAGE_SIZE != PAGE_SIZE handling, and it also lacks the device dma mask support bits. I'll add that later as time permits, but this gets us at least back to where we were beforehand. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-06[SPARC64]: Temporarily remove IOMMU merging code.David S. Miller
Changeset fde6a3c82d67f592eb587be4d12222b0ae6d4321 ("iommu sg merging: sparc64: make iommu respect the segment size limits") broke sparc64 because whilst it added the segment limiting code to the first pass of SG mapping (in prepare_sg()) it did not add matching code to the second pass handling (in fill_sg()) As a result the two passes disagree where the segment boundaries should be, resulting in OOPSes, DMA corruption, and corrupted superblocks. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-27[SPARC64]: __inline__ --> inlineDavid S. Miller
2007-10-17Remove dma_cache_(wback|inv|wback_inv) functionsRalf Baechle
dma_cache_(wback|inv|wback_inv) were the earliest attempt on a generalized cache managment API for I/O purposes. Originally it was basically the raw MIPS low level cache API exported to the entire world. The API has suffered from a lack of documentation, was not very widely used unlike it's more modern brothers and can easily be replaced by dma_cache_sync. So remove it rsp. turn the surviving bits back into an arch private API, as discussed on linux-arch. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-18[SPARC]: Mark sparc and sparc64 as not having virt_to_busStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[SPARC64]: Internalize pci_memspace_mask.David S. Miller
The only user was bus_dvma_to_mem() which is no longer used by any driver, so kill that, and the export of pci_memspace_mask. The only user now is the PCI mmap support code. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-11[PATCH] Consolidate check_signatureMatthew Wilcox
There's nothing arch-specific about check_signature(), so move it to <linux/io.h>. Use a cross between the Alpha and i386 implementations as the generic one. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-31[SPARC64]: Use 'unsigned long' for port argument to I/O string ops.David S. Miller
This kills warnings when building drivers/ide/ide-iops.c and puts us in-line with what other platforms do here. Signed-off-by: David S. Miller <davem@davemloft.net>
