path: root/include/asm-sparc64/rtc.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc: when header files are equal use asm-sparc versionSam Ravnborg
Used the following script to find equal header files: SPARC64=`ls asm-sparc64` for FILE in ${SPARC64}; do cmp -s asm-sparc/$FILE asm-sparc64/$FILE; if [ $? = 0 ]; then printf "#include <asm-sparc/%s>\n" $FILE > asm-sparc64/$FILE fi done A few of the equal files are a simple include from asm-generic, but by including the file from asm-sparc we know they are equal for sparc and sparc64. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
