path: root/include/asm-sparc64/uaccess.h
2008-07-27sparc, sparc64: use arch/sparc/includeSam Ravnborg
The majority of this patch was created by the following script: *** ASM=arch/sparc/include/asm mkdir -p $ASM git mv include/asm-sparc64/ftrace.h $ASM git rm include/asm-sparc64/* git mv include/asm-sparc/* $ASM sed -ie 's/asm-sparc64/asm/g' $ASM/* sed -ie 's/asm-sparc/asm/g' $ASM/* *** The rest was an update of the top-level Makefile to use sparc for header files when sparc64 is being build. And a small fixlet to pick up the correct unistd.h from sparc64 code. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-07-17sparc: join the remaining header filesSam Ravnborg
With this commit all sparc64 header files are moved to asm-sparc. The remaining files (71 files) were too different to be trivially merged so divide them up in a _32.h and a _64.h file which are both included from the file with no bit size. The following script were used: cd include FILES=`wc -l asm-sparc64/*h | grep -v '^ 1' | cut -b 20-` for FILE in ${FILES}; do echo $FILE: BASE=`echo $FILE | cut -d '.' -f 1` FN32=${BASE}_32.h FN64=${BASE}_64.h GUARD=___ASM_SPARC_`echo $BASE | tr '-' '_' | tr [:lower:] [:upper:]`_H git mv asm-sparc/$FILE asm-sparc/$FN32 git mv asm-sparc64/$FILE asm-sparc/$FN64 echo git mv done printf "#ifndef %s\n" $GUARD > asm-sparc/$FILE printf "#define %s\n" $GUARD >> asm-sparc/$FILE printf "#if defined(__sparc__) && defined(__arch64__)\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN64 >> asm-sparc/$FILE printf "#else\n" >> asm-sparc/$FILE printf "#include <asm-sparc/%s>\n" $FN32 >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE printf "#endif\n" >> asm-sparc/$FILE git add asm-sparc/$FILE echo new file done printf "#include <asm-sparc/%s>\n" $FILE > asm-sparc64/$FILE git add asm-sparc64/$FILE echo sparc64 file done done The guard contains three '_' to avoid conflict with existing guards. In additing the two Kbuild files are emptied to avoid breaking headers_* targets. We will reintroduce the exported header files when the necessary kbuild changes are merged. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-20sparc64: remove CVS keywordsAdrian Bunk
This patch removes the CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-08aout: remove unnecessary inclusions of {asm, linux}/a.out.hDavid Howells
Remove now unnecessary inclusions of {asm,linux}/a.out.h. [akpm@linux-foundation.org: fix alpha build] Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-31[SPARC64]: Fix linkage of enormous kernels.David S. Miller
This was found by make randconfig If the kernel .text is very large, the .fixup section branches are too far away to be relocated correctly. Use "sethi %hi(label), reg; jmpl reg + %lo(label); %g0" sequence instead of the branch to fix this. There is another case in switch_to() involving a branch, which is fixed similarly. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[SPARC64]: __bzero_noasi --> __clear_userDavid S. Miller
2006-03-20[SPARC]: Kill off these __put_user_ret things.David S. Miller
They are bogus and haven't been referenced in years. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-04[SPARC64]: Mark __ex_table section correctly.David S. Miller
We must use the "a" (allocate) attribute every time we emit an entry into the __ex_table section. For consistency, use "a" instead of #alloc which is some Solaris compat cruft GNU as provides on Sparc. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[SPARC64]: Simplify user fault fixup handling.David S. Miller
Instead of doing byte-at-a-time user accesses to figure out where the fault occurred, read the saved fault_address from the current thread structure. For the sake of defensive programming, if the fault_address does not fall into the user buffer range, simply assume the whole area faulted. This will cause the fixup for copy_from_user() to clear the entire kernel side buffer. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[SPARC64]: Fix fault handling in unaligned trap handler.David S. Miller
We were not calling kernel_mna_trap_fault() correctly. Instead of being fancy, just return 0 vs. -EFAULT from the assembler stubs, and handle that return value as appropriate. Create an "__retl_efault" stub for assembler exception table entries and use it where possible. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[SPARC64]: Convert to use generic exception table support.David S. Miller
The funny "range" exception table entries we had were only used by the compat layer socketcall assembly, and it wasn't even needed there. For free we now get proper exception table sorting and fast binary searching. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-07[PATCH] remove verify_area(): remove verify_area() from various uaccess.h ↵Jesper Juhl
headers Remove the deprecated (and unused) verify_area() from various uaccess.h headers. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
