path: root/include/asm-sparc64/uaccess.h
2006-03-04[SPARC64]: Mark __ex_table section correctly.David S. Miller
We must use the "a" (allocate) attribute every time we emit an entry into the __ex_table section. For consistency, use "a" instead of #alloc which is some Solaris compat cruft GNU as provides on Sparc. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[SPARC64]: Simplify user fault fixup handling.David S. Miller
Instead of doing byte-at-a-time user accesses to figure out where the fault occurred, read the saved fault_address from the current thread structure. For the sake of defensive programming, if the fault_address does not fall into the user buffer range, simply assume the whole area faulted. This will cause the fixup for copy_from_user() to clear the entire kernel side buffer. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[SPARC64]: Fix fault handling in unaligned trap handler.David S. Miller
We were not calling kernel_mna_trap_fault() correctly. Instead of being fancy, just return 0 vs. -EFAULT from the assembler stubs, and handle that return value as appropriate. Create an "__retl_efault" stub for assembler exception table entries and use it where possible. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[SPARC64]: Convert to use generic exception table support.David S. Miller
The funny "range" exception table entries we had were only used by the compat layer socketcall assembly, and it wasn't even needed there. For free we now get proper exception table sorting and fast binary searching. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-07[PATCH] remove verify_area(): remove verify_area() from various uaccess.h ↵Jesper Juhl
headers Remove the deprecated (and unused) verify_area() from various uaccess.h headers. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
