path: root/include/asm-sparc
2005-10-05[PATCH] fix the breakage in sparc headersAl Viro
If we switch extern inline to static inline, we'd better switch the pre-declarations we use to say that these puppies have __attribute_const__ on them. Otherwise we get extern declaration followed by static inline one. Which makes gcc unhappy, and for a good reason... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-03[SPARC]: "extern inline" doesn't make much sense.Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-28[SPARC]: Declare paging_init() in asm/pgtable.hDavid S. Miller
2005-09-21[PATCH] Remove unused var from asm/futex.hPaolo 'Blaisorblade' Giarrusso
As recently done by Russell King for ARM, commit 4732efbeb997189d9f9b04708dc26bf8613ed721 introduces a generic asm/futex.h copied along most arches, which includes a "-ENOSYS support" to be changed if needed. However, it includes an unused var (taken from the "real" version) which GCC warns about. Remove it from all arches having that file version (i.e. same GIT id). $ git-diff-tree -r HEAD and $ git-ls-tree -r HEAD include/|grep 9feff4ce1424bc390608326240be369eb13aa648 may be more interesting than looking at the patch itself, to make sure I've just copied the arm header to all other archs having the original dummy version of this file. Cc: Jakub Jelinek <jakub@redhat.com> Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] spinlock consolidationIngo Molnar
This patch (written by me and also containing many suggestions of Arjan van de Ven) does a major cleanup of the spinlock code. It does the following things: - consolidates and enhances the spinlock/rwlock debugging code - simplifies the asm/spinlock.h files - encapsulates the raw spinlock type and moves generic spinlock features (such as ->break_lock) into the generic code. - cleans up the spinlock code hierarchy to get rid of the spaghetti. Most notably there's now only a single variant of the debugging code, located in lib/spinlock_debug.c. (previously we had one SMP debugging variant per architecture, plus a separate generic one for UP builds) Also, i've enhanced the rwlock debugging facility, it will now track write-owners. There is new spinlock-owner/CPU-tracking on SMP builds too. All locks have lockup detection now, which will work for both soft and hard spin/rwlock lockups. The arch-level include files now only contain the minimally necessary subset of the spinlock code - all the rest that can be generalized now lives in the generic headers: include/asm-i386/spinlock_types.h | 16 include/asm-x86_64/spinlock_types.h | 16 I have also split up the various spinlock variants into separate files, making it easier to see which does what. The new layout is: SMP | UP ----------------------------|----------------------------------- asm/spinlock_types_smp.h | linux/spinlock_types_up.h linux/spinlock_types.h | linux/spinlock_types.h asm/spinlock_smp.h | linux/spinlock_up.h linux/spinlock_api_smp.h | linux/spinlock_api_up.h linux/spinlock.h | linux/spinlock.h /* * here's the role of the various spinlock/rwlock related include files: * * on SMP builds: * * asm/spinlock_types.h: contains the raw_spinlock_t/raw_rwlock_t and the * initializers * * linux/spinlock_types.h: * defines the generic type and initializers * * asm/spinlock.h: contains the __raw_spin_*()/etc. lowlevel * implementations, mostly inline assembly code * * (also included on UP-debug builds:) * * linux/spinlock_api_smp.h: * contains the prototypes for the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. * * on UP builds: * * linux/spinlock_type_up.h: * contains the generic, simplified UP spinlock type. * (which is an empty structure on non-debug builds) * * linux/spinlock_types.h: * defines the generic type and initializers * * linux/spinlock_up.h: * contains the __raw_spin_*()/etc. version of UP * builds. (which are NOPs on non-debug, non-preempt * builds) * * (included on UP-non-debug builds:) * * linux/spinlock_api_up.h: * builds the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. */ All SMP and UP architectures are converted by this patch. arm, i386, ia64, ppc, ppc64, s390/s390x, x64 was build-tested via crosscompilers. m32r, mips, sh, sparc, have not been tested yet, but should be mostly fine. From: Grant Grundler <grundler@parisc-linux.org> Booted and lightly tested on a500-44 (64-bit, SMP kernel, dual CPU). Builds 32-bit SMP kernel (not booted or tested). I did not try to build non-SMP kernels. That should be trivial to fix up later if necessary. I converted bit ops atomic_hash lock to raw_spinlock_t. Doing so avoids some ugly nesting of linux/*.h and asm/*.h files. Those particular locks are well tested and contained entirely inside arch specific code. I do NOT expect any new issues to arise with them. If someone does ever need to use debug/metrics with them, then they will need to unravel this hairball between spinlocks, atomic ops, and bit ops that exist only because parisc has exactly one atomic instruction: LDCW (load and clear word). From: "Luck, Tony" <tony.luck@intel.com> ia64 fix Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjanv@infradead.org> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Mikael Pettersson <mikpe@csd.uu.se> Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09kbuild: arm26,sparc use generic asm-offset supportSam Ravnborg
Rename all includes to use asm-offsets.h to match generic name Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-07[PATCH] Clean up struct flock64 definitionsStephen Rothwell
This patch gathers all the struct flock64 definitions (and the operations), puts them under !CONFIG_64BIT and cleans up the arch files. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Clean up struct flock definitionsStephen Rothwell
This patch just gathers together all the struct flock definitions except xtensa into asm-generic/fcntl.h. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Clean up the fcntl operationsStephen Rothwell
This patch puts the most popular of each fcntl operation/flag into asm-generic/fcntl.h and cleans up the arch files. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Clean up the open flagsStephen Rothwell
This patch puts the most popular of each open flag into asm-generic/fcntl.h and cleans up the arch files. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Create asm-generic/fcntl.hStephen Rothwell
This set of patches creates asm-generic/fcntl.h and consolidates as much as possible from the asm-*/fcntl.h files into it. This patch just gathers all the identical bits of the asm-*/fcntl.h files into asm-generic/fcntl.h. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] remove verify_area(): remove verify_area() from various uaccess.h ↵Jesper Juhl
headers Remove the deprecated (and unused) verify_area() from various uaccess.h headers. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] remove asm-*/hdreg.hChristoph Hellwig
unused and useless.. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] auxiliary vector cleanupsH. J. Lu
The size of auxiliary vector is fixed at 42 in linux/sched.h. But it isn't very obvious when looking at linux/elf.h. This patch adds AT_VECTOR_SIZE so that we can change it if necessary when a new vector is added. Because of include file ordering problems, doing this necessitated the extraction of the AT_* symbols into a standalone header file. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] FUTEX_WAKE_OP: pthread_cond_signal() speedupJakub Jelinek
ATM pthread_cond_signal is unnecessarily slow, because it wakes one waiter (which at least on UP usually means an immediate context switch to one of the waiter threads). This waiter wakes up and after a few instructions it attempts to acquire the cv internal lock, but that lock is still held by the thread calling pthread_cond_signal. So it goes to sleep and eventually the signalling thread is scheduled in, unlocks the internal lock and wakes the waiter again. Now, before 2003-09-21 NPTL was using FUTEX_REQUEUE in pthread_cond_signal to avoid this performance issue, but it was removed when locks were redesigned to the 3 state scheme (unlocked, locked uncontended, locked contended). Following scenario shows why simply using FUTEX_REQUEUE in pthread_cond_signal together with using lll_mutex_unlock_force in place of lll_mutex_unlock is not enough and probably why it has been disabled at that time: The number is value in cv->__data.__lock. thr1 thr2 thr3 0 pthread_cond_wait 1 lll_mutex_lock (cv->__data.__lock) 0 lll_mutex_unlock (cv->__data.__lock) 0 lll_futex_wait (&cv->__data.__futex, futexval) 0 pthread_cond_signal 1 lll_mutex_lock (cv->__data.__lock) 1 pthread_cond_signal 2 lll_mutex_lock (cv->__data.__lock) 2 lll_futex_wait (&cv->__data.__lock, 2) 2 lll_futex_requeue (&cv->__data.__futex, 0, 1, &cv->__data.__lock) # FUTEX_REQUEUE, not FUTEX_CMP_REQUEUE 2 lll_mutex_unlock_force (cv->__data.__lock) 0 cv->__data.__lock = 0 0 lll_futex_wake (&cv->__data.__lock, 1) 1 lll_mutex_lock (cv->__data.__lock) 0 lll_mutex_unlock (cv->__data.__lock) # Here, lll_mutex_unlock doesn't know there are threads waiting # on the internal cv's lock Now, I believe it is possible to use FUTEX_REQUEUE in pthread_cond_signal, but it will cost us not one, but 2 extra syscalls and, what's worse, one of these extra syscalls will be done for every single waiting loop in pthread_cond_*wait. We would need to use lll_mutex_unlock_force in pthread_cond_signal after requeue and lll_mutex_cond_lock in pthread_cond_*wait after lll_futex_wait. Another alternative is to do the unlocking pthread_cond_signal needs to do (the lock can't be unlocked before lll_futex_wake, as that is racy) in the kernel. I have implemented both variants, futex-requeue-glibc.patch is the first one and futex-wake_op{,-glibc}.patch is the unlocking inside of the kernel. The kernel interface allows userland to specify how exactly an unlocking operation should look like (some atomic arithmetic operation with optional constant argument and comparison of the previous futex value with another constant). It has been implemented just for ppc*, x86_64 and i?86, for other architectures I'm including just a stub header which can be used as a starting point by maintainers to write support for their arches and ATM will just return -ENOSYS for FUTEX_WAKE_OP. The requeue patch has been (lightly) tested just on x86_64, the wake_op patch on ppc64 kernel running 32-bit and 64-bit NPTL and x86_64 kernel running 32-bit and 64-bit NPTL. With the following benchmark on UP x86-64 I get: for i in nptl-orig nptl-requeue nptl-wake_op; do echo time elf/ld.so --library-path .:$i /tmp/bench; \ for j in 1 2; do echo ( time elf/ld.so --library-path .:$i /tmp/bench ) 2>&1; done; done time elf/ld.so --library-path .:nptl-orig /tmp/bench real 0m0.655s user 0m0.253s sys 0m0.403s real 0m0.657s user 0m0.269s sys 0m0.388s time elf/ld.so --library-path .:nptl-requeue /tmp/bench real 0m0.496s user 0m0.225s sys 0m0.271s real 0m0.531s user 0m0.242s sys 0m0.288s time elf/ld.so --library-path .:nptl-wake_op /tmp/bench real 0m0.380s user 0m0.176s sys 0m0.204s real 0m0.382s user 0m0.175s sys 0m0.207s The benchmark is at: http://sourceware.org/ml/libc-alpha/2005-03/txt00001.txt Older futex-requeue-glibc.patch version is at: http://sourceware.org/ml/libc-alpha/2005-03/txt00002.txt Older futex-wake_op-glibc.patch version is at: http://sourceware.org/ml/libc-alpha/2005-03/txt00003.txt Will post a new version (just x86-64 fixes so that the patch applies against pthread_cond_signal.S) to libc-hacker ml soon. Attached is the kernel FUTEX_WAKE_OP patch as well as a simple-minded testcase that will not test the atomicity of the operation, but at least check if the threads that should have been woken up are woken up and whether the arithmetic operation in the kernel gave the expected results. Acked-by: Ingo Molnar <mingo@redhat.com> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Jamie Lokier <jamie@shareable.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6 Linus Torvalds
2005-09-05[PATCH] sab: consolidate kmem_bufctl_tKyle Moffett
This is used only in slab.c and each architecture gets to define whcih underlying type is to be used. Seems a bit silly - move it to slab.c and use the same type for all architectures: unsigned int. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mm: consolidate get_orderStephen Rothwell
Someone mentioned that almost all the architectures used basically the same implementation of get_order. This patch consolidates them into asm-generic/page.h and includes that in the appropriate places. The exceptions are ia64 and ppc which have their own (presumably optimised) versions. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-01[SPARC]: Kill io_remap_page_range()David S. Miller
It's been deprecated long enough and there are no in-tree users any longer. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Introduce SO_{SND,RCV}BUFFORCE socket optionsPatrick McHardy
Allows overriding of sysctl_{wmem,rmrm}_max Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[SPARC]: remove use of asm/segment.hKumar Gala
Removed sparc architecture specific users of asm/segment.h and asm-sparc/segment.h itself Signed-off-by: Kumar Gala <kumar.gala@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-27[SPARC]: Add inotify syscall entries.David S. Miller
2005-07-26[PATCH] Add emergency_restart()Eric W. Biederman
When the kernel is working well and we want to restart cleanly kernel_restart is the function to use. But in many instances the kernel wants to reboot when thing are expected to be working very badly such as from panic or a software watchdog handler. This patch adds the function emergency_restart() so that callers can be clear what semantics they expect when calling restart. emergency_restart() is expected to be callable from interrupt context and possibly reliable in even more trying circumstances. This is an initial generic implementation for all architectures. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[ACPI] merge acpi-2.6.12 branch into latest Linux 2.6.13-rc...Len Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-12[ACPI] PNPACPI vs sound IRQDavid Shaohua Li
http://bugme.osdl.org/show_bug.cgi?id=4016 Written-by: David Shaohua Li <shaohua.li@intel.com> Acked-by: Adam Belay <abelay@novell.com> Signed-off-by: Len Brown <len.brown@intel.com>
2005-07-10[SPARC]: Add ioprio system call support.David S. Miller
2005-06-27[PATCH] PCI: fix up errors after dma bursting patch and CONFIG_PCI=nAndrew Morton
With CONFIG_PCI=n: In file included from include/linux/pci.h:917, from lib/iomap.c:6: include/asm/pci.h:104: warning: `enum pci_dma_burst_strategy' declared inside parameter list include/asm/pci.h:104: warning: its scope is only this definition or declaration, which is probably not what you want. include/asm/pci.h: In function `pci_dma_burst_advice': include/asm/pci.h:106: dereferencing pointer to incomplete type include/asm/pci.h:106: `PCI_DMA_BURST_INFINITY' undeclared (first use in this function) include/asm/pci.h:106: (Each undeclared identifier is reported only once include/asm/pci.h:106: for each function it appears in.) make[1]: *** [lib/iomap.o] Error 1 Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] PCI: DMA bursting adviceDavid S. Miller
After seeing, at best, "guesses" as to the following kind of information in several drivers, I decided that we really need a way for platforms to specifically give advice in this area for what works best with their PCI controller implementation. Basically, this new interface gives DMA bursting advice on PCI. There are three forms of the advice: 1) Burst as much as possible, it is not necessary to end bursts on some particular boundary for best performance. 2) Burst on some byte count multiple. A DMA burst to some multiple of number of bytes may be done, but it is important to end the burst on an exact multiple for best performance. The best example of this I am aware of are the PPC64 PCI controllers, where if you end a burst mid-cacheline then chip has to refetch the data and the IOMMU translations which hurts performance a lot. 3) Burst on a single byte count multiple. Bursts shall end exactly on the next multiple boundary for best performance. Sparc64 and Alpha's PCI controllers operate this way. They disconnect any device which tries to burst across a cacheline boundary. Actually, newer sparc64 PCI controllers do not have this behavior. That is why the "pdev" is passed into the interface, so I can add code later to check which PCI controller the system is using and give advice accordingly. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-25[PATCH] sched: cleanup context switch lockingNick Piggin
Instead of requiring architecture code to interact with the scheduler's locking implementation, provide a couple of defines that can be used by the architecture to request runqueue unlocked context switches, and ask for interrupts to be enabled over the context switch. Also replaces the "switch_lock" used by these architectures with an oncpu flag (note, not a potentially slow bitflag). This eliminates one bus locked memory operation when context switching, and simplifies the task_running function. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] streamline preempt_count type across archsJesper Juhl
The preempt_count member of struct thread_info is currently either defined as int, unsigned int or __s32 depending on arch. This patch makes the type of preempt_count an int on all archs. Having preempt_count be an unsigned type prevents the catching of preempt_count < 0 bugs, and using int on some archs and __s32 on others is not exactely "neat" - much nicer when it's just int all over. A previous version of this patch was already ACK'ed by Robert Love, and the only change in this version of the patch compared to the one he ACK'ed is that this one also makes sure the preempt_count member is consistently commented. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] smp_processor_id() cleanupIngo Molnar
This patch implements a number of smp_processor_id() cleanup ideas that Arjan van de Ven and I came up with. The previous __smp_processor_id/_smp_processor_id/smp_processor_id API spaghetti was hard to follow both on the implementational and on the usage side. Some of the complexity arose from picking wrong names, some of the complexity comes from the fact that not all architectures defined __smp_processor_id. In the new code, there are two externally visible symbols: - smp_processor_id(): debug variant. - raw_smp_processor_id(): nondebug variant. Replaces all existing uses of _smp_processor_id() and __smp_processor_id(). Defined by every SMP architecture in include/asm-*/smp.h. There is one new internal symbol, dependent on DEBUG_PREEMPT: - debug_smp_processor_id(): internal debug variant, mapped to smp_processor_id(). Also, i moved debug_smp_processor_id() from lib/kernel_lock.c into a new lib/smp_processor_id.c file. All related comments got updated and/or clarified. I have build/boot tested the following 8 .config combinations on x86: {SMP,UP} x {PREEMPT,!PREEMPT} x {DEBUG_PREEMPT,!DEBUG_PREEMPT} I have also build/boot tested x64 on UP/PREEMPT/DEBUG_PREEMPT. (Other architectures are untested, but should work just fine.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-08[PATCH] sparc32: silence access_ok() warningsWilliam Lee Irwin III
The fact that access_ok() doesn't use some of its arguments trips some unused variable warnings. This patch silences them permanently. Signed-off-by: William Irwin <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-04[PATCH] asm/signal.h unificationAl Viro
New file - asm-generic/signal.h. Contains declarations of __sighandler_t, __sigrestore_t, SIG_DFL, SIG_IGN, SIG_ERR and default definitions of SIG_BLOCK, SIG_UNBLOCK and SIG_SETMASK. asm-*/signal.h switched to including it. The only exception is asm-parisc/signal.h that wants its own declaration of __sighandler_t; that one is left as-is. asm-ppc64/signal.h required one more thing - unlike everybody else it used __sigrestorer_t instead of usual __sigrestore_t. PPC64 switched to common spelling. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-04[PATCH] sparc NULL noise removalAl Viro
2005-05-01[PATCH] misc verify_area cleanupsJesper Juhl
There were still a few comments left refering to verify_area, and two functions, verify_area_skas & verify_area_tt that just wrap corresponding access_ok_skas & access_ok_tt functions, just like verify_area does for access_ok - deprecate those. There was also a few places that still used verify_area in commented-out code, fix those up to use access_ok. After applying this one there should not be anything left but finally removing verify_area completely, which will happen after a kernel release or two. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] add EOWNERDEAD and ENOTRECOVERABLE version 2Joe Korty
Add EOWNERDEAD and ENOTRECOVERABLE to all architectures. This is to support the upcoming patches for robust mutexes. We normally don't reserve parts of the name/number space for external patches, but robust mutexes are sufficiently popular and important to justify it in this case. Signed-off-by: Joe Korty <joe.korty@ccur.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] move SA_xxx defines to linux/signal.hStas Sergeev
The attached patch moves the IRQ-related SA_xxx flags (namely, SA_PROBE, SA_SAMPLE_RANDOM and SA_SHIRQ) from all the arch-specific headers to linux/signal.h. This looks like a left-over after the irq-handling code was consolidated. The code was moved to kernel/irq/*, but the flags are still left per-arch. Right now, adding a new IRQ flag to the arch-specific header, like this patch does: http://cvs.sourceforge.net/viewcvs.py/*checkout*/alsa/alsa-driver/utils/patches/pcsp-kernel-2.6.10-03.diff?rev=1.1 no longer works, it breaks the compilation for all other arches, unless you add that flag to all the other arch-specific headers too. So I think such a clean-up makes sense. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] remove all kernel BUGsMatt Mackall
This patch eliminates all kernel BUGs, trims about 35k off the typical kernel, and makes the system slightly faster. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-24[SPARC]: Fix mxcc warningTom 'spot' Callaway
Peter Jones uncovered this one while we were debugging the framebuffer issues. There are some references to -1 in the mxcc asm code, which should be 0xffffffff. This patch gets rid of the -1s. Signed-off-by: Tom 'spot' Callaway <tcallawa@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-19[PATCH] freepgt: arch FIRST_USER_ADDRESS 0Hugh Dickins
Replace misleading definition of FIRST_USER_PGD_NR 0 by definition of FIRST_USER_ADDRESS 0 in all the MMU architectures beyond arm and arm26. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-18[PATCH] sparc64: Fix statDavid S. Miller
Like Alpha, sparc64's struct stat was defined before we had the nanosecond et al. fields added. So like Alpha I have to cons up a struct stat64 to get this stuff. I'll work on the glibc bits soon. Also, we were forgetting to fill in the nanosecond fields in the sparc compat stat64 syscalls. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
