path: root/include/asm-v850/system.h
2008-02-07Add cmpxchg_local to v850Mathieu Desnoyers
Use the new generic cmpxchg_local (disables interrupt). Also use the generic cmpxchg as fallback if SMP is not set. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Miles Bader <miles.bader@necel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20include/asm-*/system.h: remove unused set_rmb(), set_wmb() macrosStefan Richter
These don't appear anywhere else in the kernel anymore. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-05-08Remove tas()Jeff Dike
tas() has no users, so get rid of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: <linux-arch@vger.kernel.org> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-14[PATCH] remove set_wmb - arch removalSteven Rostedt
set_wmb should not be used in the kernel because it just confuses the code more and has no benefit. Since it is not currently used in the kernel this patch removes it so that new code does not include it. All archs define set_wmb(var, value) to do { var = value; wmb(); } while(0) except ia64 and sparc which use a mb() instead. But this is still moot since it is not used anyway. Hasn't been tested on any archs but x86 and x86_64 (and only compiled tested) Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] Remove unused prepare_to_switch macroHirokazu Takata
Remove unused prepare_to_switch() macros. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] include/asm-v850/ "extern inline" -> "static inline"Adrian Bunk
"extern inline" doesn't make much sense. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Miles Bader <miles@gnu.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
