path: root/include/asm-x86/acpi.h
2008-04-17include/asm-x86/acpi.h: checkpatch cleanups - formatting onlyJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-09x86: fix sparse warnings in acpi/bus.cHarvey Harrison
Add function definition and extern variables to asm-x86/acpi.h. All of these are used in bus.c in ifdef(CONFIG_X86) sections, so are only added to the x86 include headers. boot.c already includes acpi.h so no changes are needed there. Fixes the following: arch/x86/kernel/acpi/boot.c:83:4: warning: symbol 'acpi_sci_flags' was not declared. Should it be static? arch/x86/kernel/acpi/boot.c:84:5: warning: symbol 'acpi_sci_override_gsi' was not declared. Should it be static? arch/x86/kernel/acpi/boot.c:421:13: warning: symbol 'acpi_pic_sci_set_trigger' was not declared. Should it be static? Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: voluntary leave_mm before entering ACPI C3Venki Pallipadi
Aviod TLB flush IPIs during C3 states by voluntary leave_mm() before entering C3. The performance impact of TLB flush on C3 should not be significant with respect to C3 wakeup latency. Also, CPUs tend to flush TLB in hardware while in C3 anyways. On a 8 logical CPU system, running make -j2, the number of tlbflush IPIs goes down from 40 per second to ~ 0. Total number of interrupts during the run of this workload was ~1200 per second, which makes it ~3% savings in wakeups. There was no measurable performance or power impact however. [ akpm@linux-foundation.org: symbol export fixes. ] Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: remove __init modifier from header declarationGlauber de Oliveira Costa
This patch removes the __init modifier from an extern function declaration in acpi.h. Besides not being strictly needed, it requires the inclusion of linux/init.h, which is usually not even included directly, increasing header mess by a lot. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: merge acpi_32/64.hThomas Gleixner
Merge the files. [ mingo@elte.hu: build fix ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-11-26ACPI: Set max_cstate to 1 for early Opterons.Alexey Starikovskiy
AMD Opteron processors before CG revision don't like C-states > 1. This solves the long standing bugzilla #5303 and probably some more on affected machines: http://bugzilla.kernel.org/show_bug.cgi?id=5303 [ tglx@linutronix.de: reworked the patch so it does not wreck ia64 ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
