path: root/include/asm-x86/ide.h
2008-04-18ide: remove ide_init_default_irq() macroBartlomiej Zolnierkiewicz
* Use ide_default_irq() instead of ide_init_default_irq() in ide_generic host driver (so the correct IRQ is always set regardless of CONFIG_PCI / CONFIG_BLK_DEV_IDEPCI). * Remove no longer needed ide_init_default_irq() macro. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove ide_default_io_ctl() macroBartlomiej Zolnierkiewicz
It is always == '((base) + 0x206)' if CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=y and it is not needed otherwise (arm, blackfin, parisc, ppc64, sh, sparc[64]). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2)Bartlomiej Zolnierkiewicz
* Add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS to drivers/ide/Kconfig and use it instead of defining IDE_ARCH_OBSOLETE_DEFAULTS in <arch/ide.h>. v2: * Define ide_default_irq() in ide-probe.c/ns87415.c if not already defined and drop defining ide_default_irq() for CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=n. [ Thanks to Stephen Rothwell and David Miller for noticing the problem. ] Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Miller <davem@davemloft.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-01-30x86: remove more bogus filenames in comments.Dave Jones
Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-20ide: add CONFIG_IDE_ARCH_OBSOLETE_INITBartlomiej Zolnierkiewicz
Add CONFIG_IDE_ARCH_OBSOLETE_INIT to drivers/ide/Kconfig and use it instead of defining IDE_ARCH_OBSOLETE_INIT in <arch/ide.h>. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
