path: root/include/asm-x86/ipi.h
2008-04-17include/asm-x86/ipi.h: checkpatch cleanups - formatting onlyJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-19x86: convert cpu_to_apicid to be a per cpu variableMike Travis
This patch converts the x86_cpu_to_apicid array to be a per cpu variable. This saves sizeof(apicid) * NR unused cpus. Access is mostly from startup and CPU HOTPLUG functions. MP_processor_info() is one of the functions that require access to the x86_cpu_to_apicid array before the per_cpu data area is setup. For this case, a pointer to the __initdata array is initialized in setup_arch() and removed in smp_prepare_cpus() after the per_cpu data area is initialized. A second change is included to change the initial array value of ARCH i386 from 0xff to BAD_APICID to be consistent with ARCH x86_64. Signed-off-by: Mike Travis <travis@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: Christoph Lameter <clameter@sgi.com> Cc: "Siddha, Suresh B" <suresh.b.siddha@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
