Signed-off-by: H. Peter Anvin <hpa@zytor.com>
This patch is the result of an automatic script that consolidates the
format of all the headers in include/asm-x86/.
The format:
1. No leading underscore. Names with leading underscores are reserved.
2. Pathname components are separated by two underscores. So we can
distinguish between mm_types.h and mm/types.h.
3. Everything except letters and numbers are turned into single
underscores.
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
Instead of prefetching all segment bases before emulation, read them at the
last moment. Since most of them are unneeded, we save some cycles on
Intel machines where this is a bit expensive.
Signed-off-by: Avi Kivity <avi@qumranet.com>
rip relative decoding is relative to the instruction pointer of the next
instruction; by moving address adjustment until after decoding is complete,
we remove the need to determine the instruction size.
A register destination encoded with a mod=3 encoding left dst.ptr NULL.
Normally we don't trap writes to registers, but in the case of smsw, we do.
Fix by pointing dst.ptr at the destination register.
This paves the way for multiple architecture support. Note that while
ioapic.c could potentially be shared with ia64, it is also moved.
