path: root/include/asm-x86/pgtable_64.h
2008-10-22x86, um: ... and asm-x86 moveAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-06Merge branches 'x86/alternatives', 'x86/cleanups', 'x86/commandline', ↵Ingo Molnar
'x86/crashdump', 'x86/debug', 'x86/defconfig', 'x86/doc', 'x86/exports', 'x86/fpu', 'x86/gart', 'x86/idle', 'x86/mm', 'x86/mtrr', 'x86/nmi-watchdog', 'x86/oprofile', 'x86/paravirt', 'x86/reboot', 'x86/sparse-fixes', 'x86/tsc', 'x86/urgent' and 'x86/vmalloc' into x86-v28-for-linus-phase1
2008-10-06Merge branch 'x86/header-guards' into x86-v28-for-linus-phase1Ingo Molnar
Conflicts: include/asm-x86/dma-mapping.h include/asm-x86/gpio.h include/asm-x86/idle.h include/asm-x86/kvm_host.h include/asm-x86/namei.h include/asm-x86/uaccess.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-10x86: unsigned long pte_pfnHugh Dickins
pte_pfn() has always been of type unsigned long, even on 32-bit PAE; but in the current tip/next/mm tree it works out to be unsigned long long on 64-bit, which gives an irritating warning if you try to printk a pfn with the usual %lx. Now use the same pte_pfn() function, moved from pgtable-3level.h to pgtable.h, for all models: as suggested by Jeremy Fitzhardinge. And pte_page() can well move along with it (remaining a macro to avoid dependence on mm_types.h). Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-15x86-64: fix overlap of modules and fixmap areasJan Beulich
Plus add a build time check so this doesn't go unnoticed again. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-26Merge branch 'linus' into x86/header-guardsIngo Molnar
Conflicts: include/asm-x86/gpio.h include/asm-x86/ide.h Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-22x86: consolidate header guardsVegard Nossum
This patch is the result of an automatic script that consolidates the format of all the headers in include/asm-x86/. The format: 1. No leading underscore. Names with leading underscores are reserved. 2. Pathname components are separated by two underscores. So we can distinguish between mm_types.h and mm/types.h. 3. Everything except letters and numbers are turned into single underscores. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2008-07-22x86: rename PTE_MASK to PTE_PFN_MASKJeremy Fitzhardinge
Rusty, in his peevish way, complained that macros defining constants should have a name which somewhat accurately reflects the actual purpose of the constant. Aside from the fact that PTE_MASK gives no clue as to what's actually being masked, and is misleadingly similar to the functionally entirely different PMD_MASK, PUD_MASK and PGD_MASK, I don't really see what the problem is. But if this patch silences the incessent noise, then it will have achieved its goal (TODO: write test-case). Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-16xen64: early mapping setupJeremy Fitzhardinge
Set up the initial pagetables to map the kernel mapping into the physical mapping space. This makes __va() usable, since it requires physical mappings. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Stephen Tweedie <sct@redhat.com> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86, 64-bit: split set_pte_vaddr()Eduardo Habkost
We will need to set a pte on l3_user_pgt. Extract set_pte_vaddr_pud() from set_pte_vaddr(), that will accept the l3 page table as parameter. This change should be a no-op for existing code. Signed-off-by: Eduardo Habkost <ehabkost@redhat.com> Signed-off-by: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: xen-devel <xen-devel@lists.xensource.com> Cc: Stephen Tweedie <sct@redhat.com> Cc: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: unify pgd_indexJeremy Fitzhardinge
pgd_index is common for 32 and 64-bit, so move it to a common place. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: xen-devel <xen-devel@lists.xensource.com> Cc: Stephen Tweedie <sct@redhat.com> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86, 64-bit: use __pgd() on mk_kernel_pgd()Eduardo Habkost
Use __pgd() on mk_kernel_pgd() Signed-off-by: Eduardo Habkost <ehabkost@redhat.com> Cc: xen-devel <xen-devel@lists.xensource.com> Cc: Stephen Tweedie <sct@redhat.com> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-20x86: strengthen 64-bit p?d_bad()Hugh Dickins
The x86_64 pgd_bad(), pud_bad(), pmd_bad() inlines have differed from their x86_32 counterparts in a couple of ways: they've been unnecessarily weak (e.g. letting 0 or 1 count as good), and were typed as unsigned long. Strengthen them and return int. The PAE pmd_bad was too weak before, allowing any junk in the upper half; but got strengthened by the patch correcting its ~PAGE_MASK to ~PTE_MASK. The PAE pud_bad already said ~PTE_MASK; and since it folds into pgd_bad, and we don't set the protection bits at that level, it'll do as is. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-06x86: fix PAE pmd_bad bootup warningHugh Dickins
Fix warning from pmd_bad() at bootup on a HIGHMEM64G HIGHPTE x86_32. That came from 9fc34113f6880b215cbea4e7017fc818700384c2 x86: debug pmd_bad(); but we understand now that the typecasting was wrong for PAE in the previous version: pagetable pages above 4GB looked bad and stopped Arjan from booting. And revert that cded932b75ab0a5f9181ee3da34a0a488d1a14fd x86: fix pmd_bad and pud_bad to support huge pages. It was the wrong way round: we shouldn't weaken every pmd_bad and pud_bad check to let huge pages slip through - in part they check that we _don't_ have a huge page where it's not expected. Put the x86 pmd_bad() and pud_bad() definitions back to what they have long been: they can be improved (x86_32 should use PTE_MASK, to stop PAE thinking junk in the upper word is good; and x86_64 should follow x86_32's stricter comparison, to stop thinking any subset of required bits is good); but that should be a later patch. Fix Hans' good observation that follow_page() will never find pmd_huge() because that would have already failed the pmd_bad test: test pmd_huge in between the pmd_none and pmd_bad tests. Tighten x86's pmd_huge() check? No, once it's a hugepage entry, it can get quite far from a good pmd: for example, PROT_NONE leaves it with only ACCESSED of the KERN_PGTABLE bits. However... though follow_page() contains this and another test for huge pages, so it's nice to keep it working on them, where does it actually get called on a huge page? get_user_pages() checks is_vm_hugetlb_page(vma) to to call alternative hugetlb processing, as does unmap_vmas() and others. Signed-off-by: Hugh Dickins <hugh@veritas.com> Earlier-version-tested-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jeff Chua <jeff.chua.linux@gmail.com> Cc: Hans Rosenfeld <hans.rosenfeld@amd.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24x86: unify pgd ctor/dtorJeremy Fitzhardinge
All pagetables need fundamentally the same setup and destruction, so just use the same code for everything. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17include/asm-x86/pgtable_64.h: checkpatch cleanups - formatting onlyJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: redo cded932b75ab0a5f9181eIngo Molnar
redo commit cded932b75ab0a5f9181e. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: add gbpages switchesIngo Molnar
These new controls toggle experimental support for a new CPU feature, the straightforward extension of largepages from the pmd level to the pud level, which allows 1GB (kernel) TLBs instead of 2MB TLBs. Turn it off by default, as this code has not been tested well enough yet. Use the CONFIG_DIRECT_GBPAGES=y .config option or gbpages on the boot line can be used to enable it. If enabled in the .config then nogbpages boot option disables it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17x86: increase the kernel text limit to 512 MBIngo Molnar
people sometimes do crazy stuff like building really large static arrays into their kernels or building allyesconfig kernels. Give more space to the kernel and push modules up a bit: kernel has 512 MB and modules have 1.5 GB. Should be enough for a few years ;-) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-03-03Revert "x86: fix pmd_bad and pud_bad to support huge pages"Linus Torvalds
This reverts commit cded932b75ab0a5f9181ee3da34a0a488d1a14fd. Arjan bisected down a boot-time hang to this, saying: ".. it prevents the kernel to finish booting on my (Penryn based) laptop. The boot stops right after freeing the init memory." and while it's not clear exactly what triggers it, at this stage we're better off just reverting it while Ingo tries to figure out what went wrong. Requested-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Hans Rosenfeld <hans.rosenfeld@amd.com> Cc: Nish Aravamudan <nish.aravamudan@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-29x86: fix pmd_bad and pud_bad to support huge pagesHans Rosenfeld
I recently stumbled upon a problem in the support for huge pages. If a program using huge pages does not explicitly unmap them, they remain mapped (and therefore, are lost) after the program exits. I observed that the free huge page count in /proc/meminfo decreased when running my program, and it did not increase after the program exited. After running the program a few times, no more huge pages could be allocated. The reason for this seems to be that the x86 pmd_bad and pud_bad consider pmd/pud entries having the PSE bit set invalid. I think there is nothing wrong with this bit being set, it just indicates that the lowest level of translation has been reached. This bit has to be (and is) checked after the basic validity of the entry has been checked, like in this fragment from follow_page() in mm/memory.c: if (pmd_none(*pmd) || unlikely(pmd_bad(*pmd))) goto no_page_table; if (pmd_huge(*pmd)) { BUG_ON(flags & FOLL_GET); page = follow_huge_pmd(mm, address, pmd, flags & FOLL_WRITE); goto out; } Note that this code currently doesn't work as intended if the pmd refers to a huge page, the pmd_huge() check can not be reached if the page is huge. Extending pmd_bad() (and, for future 1GB page support, pud_bad()) to allow for the PSE bit being set fixes this. For similar reasons, allowing the NX bit being set is necessary, too. I have seen huge pages having the NX bit set in their pmd entry, which would cause the same problem. Signed-Off-By: Hans Rosenfeld <hans.rosenfeld@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-19x86: add pgd_large() on 64-bit, for consistencyH. Peter Anvin
In order to have it at all levels, add pgd_large() which only returns 0. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-18x86: zap invalid and unused pmds in early bootThomas Gleixner
The early boot code maps KERNEL_TEXT_SIZE (currently 40MB) starting from __START_KERNEL_map. The kernel itself only needs _text to _end mapped in the high alias. On relocatible kernels the ASM setup code adjusts the compile time created high mappings to the relocation. This creates invalid pmd entries for negative offsets: 0xffffffff80000000 -> pmd entry: ffffffffff2001e3 It points outside of the physical address space and is marked present. This starts at the virtual address __START_KERNEL_map and goes up to the point where the first valid physical address (0x0) is mapped. Zap the mappings before _text and after _end right away in early boot. This removes also the invalid entries. Furthermore it simplifies the range check for high aliases. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-04x86: add pgtable accessor functions for gbpagesAndi Kleen
Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-04x86: remove now unused clear_kernel_mappingAndi Kleen
2008-01-30x86: use the same pgd_list for PAE and 64-bitJeremy Fitzhardinge
Use a standard list threaded through page->lru for maintaining the pgd list on PAE. This is the same as 64-bit, and seems saner than using a non-standard list via page->index. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: clean up lookup_address() declarationsThomas Gleixner
2008-01-30x86: clean up arch/x86/mm/pageattr.cIngo Molnar
do some leftover cleanups in the now unified arch/x86/mm/pageattr.c file. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: introduce native_set_pte_atomic() on 64-bit tooIngo Molnar
2008-01-30x86: add pte_pgprot to 32-bitAndi Kleen
64bit already had it. Needed for later patches. Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: return the page table level in lookup_address()Ingo Molnar
based on this patch from Andi Kleen: | Subject: CPA: Return the page table level in lookup_address() | From: Andi Kleen <ak@suse.de> | | Needed for the next change. | | And change all the callers. and ported it to x86.git. Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify paravirt pagetable accessorsJeremy Fitzhardinge
Put all the defines for mapping pagetable operations to their native versions (for the non-paravirt case) into one place. Make the corresponding changes to paravirt.h. The tricky part here is that when a pagetable entry can't be updated atomically (ie, 32-bit PAE), we need special handlers for pte_clear, set_pte_atomic and set_pte_present. However, the other two modes don't need special handling for these, and can use a common set_pte(_at) path. [ mingo@elte.hu: fixes ] Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify zero_page definitionJeremy Fitzhardinge
Move ZERO_PAGE/empty_zero_page to common place. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: pgtable: unify pte accessorsJeremy Fitzhardinge
Make various pte accessors common. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: page.h: make pte_t a union to always includeJeremy Fitzhardinge
Make sure pte_t, whatever its definition, has a pte element with type pteval_t. This allows common code to access it without needing to be specifically parameterised on what pagetable mode we're compiling for. For 32-bit, this means that pte_t becomes a union with "pte" and "{ pte_low, pte_high }" (PAE) or just "pte_low" (non-PAE). Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify pgtable accessors which useJeremy Fitzhardinge
Make users of supported_pte_mask common. This has the side-effect of introducing the variable for 32-bit non-PAE, but I think its a pretty small cost to simplify the code. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86/pgtable: unify pagetable accessors, #6Jeremy Fitzhardinge
Unify functions to test and set bits in pagetable entries. NOP: only moves existing code around, without any change to it. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86/pgtable: unify pagetable accessors, #1Ingo Molnar
based on: Subject: x86/pgtable: unify pagetable accessors From: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: move all asm/pgtable constants into one placeJeremy Fitzhardinge
32 and 64-bit use the same flags for pagetable entries, so make them all common. [ mingo@elte.hu: fixes ] Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: add PWT to NOCACHE flagsIngo Molnar
add PWT bit to NOCACHE flags. No real difference to CPUs, but needed later for PAT. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: page.h: move and unify types for pagetable entry, #2Ingo Molnar
based on: Subject: x86: page.h: move and unify types for pagetable entry From: Jeremy Fitzhardinge <jeremy@goop.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: kill mk_pte_hugeJeremy Fitzhardinge
It only has a single use, which can be trivially replaced. Signed-off-by: Jeremy Fitzhardinge <Jeremy.Fitzhardinge@citrix.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: some whitespace cleanups in paging codeJoerg Roedel
This patch does some whitespace cleanups in the paging code to fix some checkpatch.pl warnings of my formerly merged cleanup patches. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: PIE executable randomizationJiri Kosina
main executable of (specially compiled/linked -pie/-fpie) ET_DYN binaries onto a random address (in cases in which mmap() is allowed to perform a randomization). The code has been extraced from Ingo's exec-shield patch http://people.redhat.com/mingo/exec-shield/ [akpm@linux-foundation.org: fix used-uninitialsied warning] [kamezawa.hiroyu@jp.fujitsu.com: fixed ia32 ELF on x86_64 handling] Signed-off-by: Jiri Kosina <jkosina@suse.cz> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Roland McGrath <roland@redhat.com> Cc: Jakub Jelinek <jakub@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: define all _PAGE_* in terms of _PAGE_BIT_* on 64-bitJoerg Roedel
This patch defines the _PAGE_* paging attributes in pgtable_64.h in terms of the former defined _PAGE_BIT_* values. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-19remove asm/bitops.h includesJiri Slaby
remove asm/bitops.h includes including asm/bitops directly may cause compile errors. don't include it and include linux/bitops instead. next patch will deny including asm header directly. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16x86_64: SPARSEMEM_VMEMMAP 2M page size supportChristoph Lameter
x86_64 uses 2M page table entries to map its 1-1 kernel space. We also implement the virtual memmap using 2M page table entries. So there is no additional runtime overhead over FLATMEM, initialisation is slightly more complex. As FLATMEM still references memory to obtain the mem_map pointer and SPARSEMEM_VMEMMAP uses a compile time constant, SPARSEMEM_VMEMMAP should be superior. With this SPARSEMEM becomes the most efficient way of handling virt_to_page, pfn_to_page and friends for UP, SMP and NUMA on x86_64. [apw@shadowen.org: code resplit, style fixups] [apw@shadowen.org: vmemmap x86_64: ensure end of section memmap is initialised] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andy Whitcroft <apw@shadowen.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Andi Kleen <ak@suse.de> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
