path: root/include/asm-x86/ptrace.h
2008-06-02x86: break mutual header inclusionVegard Nossum
This breaks up the mutual inclusion between headers ptrace.h and vm86.h by moving some small part of vm86.h which is needed by ptrace.h into processor-flags.h. We also try to move #include lines to the top. This has been compile tested on x86_32 and x86_64 defconfig, and run through 'make headers_check'. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86_64 ia32 ptrace: convert to compat_arch_ptraceRoland McGrath
Now that there are no more special cases in sys32_ptrace, we can convert to using the generic compat_sys_ptrace entry point. The sys32_ptrace function gets simpler and becomes compat_arch_ptrace. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: cleanup - rename VM_MASK to X86_VM_MASKgorcunov@gmail.com
This patch renames VM_MASK to X86_VM_MASK (which in turn defined as alias to X86_EFLAGS_VM) to better distinguish from virtual memory flags. We can't just use X86_EFLAGS_VM instead because it is also used for conditional compilation Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17include/asm-x86/ptrace.h: checkpatch cleanups - formatting onlyJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: make X86_32 pt_regs members unsigned longHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17x86: change most X86_32 pt_regs members to unsigned longHarvey Harrison
2008-01-30x86: rename stack_pointer to kernel_trap_spHarvey Harrison
Choose a less generic name for such a special case. Add a comment explaining the odd use in X86_32. Change the one user of stack_pointer. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: clean up ptrace.hHarvey Harrison
Leave definition of pt_regs in its own section, move all kernel code to section afterwards, unify prototype definitions, has some conditional prototypes to make it clear what was only defined in 32 and 64 bit. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify pt_regs accessors ptrace.hHarvey Harrison
Unify the definiton of: v8086_mode user_mode user_mode_vm stack_pointer instruction_pointer frame_pointer in ptrace.h to make it clear where the differences are between 32 and 64 bit. Changes macros to static inlines as well. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: remove last user of get_segment_eipHarvey Harrison
is_prefetch was the last user of get_segment_eip and only on X86_32. This function returned the faulting instruction's address and set the upper segment limit. Instead, use the convert_ip_to_linear helper and rely on probe_kernel_address to do the segment checks which was already done everywhere the segment limit was being checked on X86_32. Remove get_segment_eip as well. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: common x86_32|64 namingHarvey Harrison
Rename convert_rip_to_linear to convert_ip_to_linear for shared X86_32|64 use. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: move get_segment_eip() to step.cHarvey Harrison
get_segment_eip has similarities to convert_rip_to_linear(), and is used in a similar context. Move get_segment_eip to step.c to allow easier consolidation. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86, ptrace: new ptrace BTS APIMarkus Metzger
Here's the new ptrace BTS API that supports two different overflow handling mechanisms (wrap-around and buffer-full-signal) to support two different use cases (debugging and profiling). It further combines buffer allocation and configuration. Opens: - memory rlimit - overflow signal What would be the right signal to use? Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86, ptrace: support for branch trace store(BTS)Markus Metzger
Resend using different mail client Changes to the last version: - split implementation into two layers: ds/bts and ptrace - renamed TIF's - save/restore ds save area msr in __switch_to_xtra() - make block-stepping only look at BTF bit Signed-off-by: Markus Metzger <markus.t.metzger@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: x86 ptrace merge completeRoland McGrath
This switches over the 64-bit build to use the shared ptrace code, instead of the old ptrace_64.c and arch/x86/ia32/ptrace32.c code. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: eflags enumRoland McGrath
This removes the EF_* enum from <asm/ptrace.h>. It is no longer used, and duplicates the X86_EFLAGS_* constants from <asm/processor-flags.h>. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: rename the struct pt_regs members for 32/64-bit consistencyH. Peter Anvin
We have a lot of code which differs only by the naming of specific members of structures that contain registers. In order to enable additional unifications, this patch drops the e- or r- size prefix from the register names in struct pt_regs, and drops the x- prefixes for segment registers on the 32-bit side. This patch also performs the equivalent renames in some additional places that might be candidates for unification in the future. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: debugctlmsr arch_has_block_stepRoland McGrath
This implements user-mode step-until-branch on x86 using the BTF bit in MSR_IA32_DEBUGCTLMSR. It's just like single-step, only less so. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: x86-64 ptrace debugreg cleanupRoland McGrath
This cleans up the 64-bit ptrace code to separate the guts of the debug register access from the implementation of PTRACE_PEEKUSR and PTRACE_POKEUSR. The new functions ptrace_[gs]et_debugreg are made global so that the ia32 code can later be changed to call them too. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: arch_has_single_stepRoland McGrath
This defines the new standard arch_has_single_step macro. It makes the existing set_singlestep and clear_singlestep entry points global, and renames them to the new standard names user_enable_single_step and user_disable_single_step, respectively. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: TLS cleanupRoland McGrath
This consolidates the four different places that implemented the same encoding magic for the GDT-slot 32-bit TLS support. The old tls32.c was renamed and is now only slightly modified to be the shared implementation. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Zachary Amsden <zach@vmware.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-11-14oprofile: fix oops on x86 32-bitJan Blunck
x86 32-bit isn't saving the stack pointer to pt_regs->esp when an interrupt occurs. Signed-off-by: Jan Blunck <jblunck@suse.de> Tested-by: Robert Fitzsimons <robfitz@273k.net> Cc: Andi Kleen <ak@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Philippe Elie <phil.el@wanadoo.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23x86: merge ptrace_32/64.hThomas Gleixner
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
