path: root/include/asm-x86/uv
2008-04-17x86: define the macros and tables for blade functionsJack Steiner
Add UV macros for converting between cpu numbers, blade numbers and node numbers. Note that these are used ONLY within x86_64 UV modules, and are not for general kernel use. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: define the macros and tables for the basic UV infrastructure.Jack Steiner
Define the macros and tables for the basic UV infrastructure. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: add UV specific header for MMR definitionsJack Steiner
Definitions of UV MMRs. Note: this file is auto-generated by hardware design tools. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
