path: root/include/asm-x86/vm86.h
2008-06-02x86: break mutual header inclusionVegard Nossum
This breaks up the mutual inclusion between headers ptrace.h and vm86.h by moving some small part of vm86.h which is needed by ptrace.h into processor-flags.h. We also try to move #include lines to the top. This has been compile tested on x86_32 and x86_64 defconfig, and run through 'make headers_check'. Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-25x86 - hide X86_VM_MASK from userland programs v3Cyrill Gorcunov
X86_VM_MASK is kernel specific flags so hide it from userland programs. It should be defined *before* ptrace.h inclusion because of circular link between these files Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17x86: replace most VM86 flags with flags from processor-flags.hgorcunov@gmail.com
2008-04-17x86: cleanup - rename VM_MASK to X86_VM_MASKgorcunov@gmail.com
This patch renames VM_MASK to X86_VM_MASK (which in turn defined as alias to X86_EFLAGS_VM) to better distinguish from virtual memory flags. We can't just use X86_EFLAGS_VM instead because it is also used for conditional compilation Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17include/asm-x86/vm86.h: checkpatch cleanups - formatting onlyJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-04x86: add function prototype to vm86.hHarvey Harrison
Global functions should include their prototypes. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-11i386/x86_64: move headers to include/asm-x86Thomas Gleixner
Move the headers to include/asm-x86 and fixup the header install make rules Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
