Signed-off-by: H. Peter Anvin <hpa@zytor.com>
'core/printk' and 'core/misc' into core-v28-for-linus
PFN_PHYS, as its name suggests, turns a pfn into a physical address.
However, it is a macro which just operates on its argument without
modifying its type. pfns are typed unsigned long, but an unsigned
long may not be long enough to hold a physical address (32-bit systems
with more than 32 bits of physcial address).
Make sure we cast to phys_addr_t to return a complete result.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
include/asm-x86/gpio.h
include/asm-x86/ide.h
This patch is the result of an automatic script that consolidates the
format of all the headers in include/asm-x86/.
The format:
1. No leading underscore. Names with leading underscores are reserved.
2. Pathname components are separated by two underscores. So we can
distinguish between mm_types.h and mm/types.h.
3. Everything except letters and numbers are turned into single
underscores.
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
Rusty, in his peevish way, complained that macros defining constants
should have a name which somewhat accurately reflects the actual
purpose of the constant.
Aside from the fact that PTE_MASK gives no clue as to what's actually
being masked, and is misleadingly similar to the functionally entirely
different PMD_MASK, PUD_MASK and PGD_MASK, I don't really see what the
problem is.
But if this patch silences the incessent noise, then it will have
achieved its goal (TODO: write test-case).
Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org>
When building initial pagetables in 64-bit kernel the pud/pmd pointer may
be in ioremap/fixmap space, so we need to walk the pagetable to look up the
physical address.
Cc: Stephen Tweedie <sct@redhat.com>
Cc: Eduardo Habkost <ehabkost@redhat.com>
Cc: Mark McLoughlin <markmc@redhat.com>
We need extra pv_mmu_ops for 64-bit, to deal with the extra level of
pagetable.
Add a config option to set the max size of a Xen domain. This is used
to scale the size of the physical-to-machine array; it ends up using
around 1 page/GByte, so there's no reason to be very restrictive.
For a 32-bit guest, the default value of 8GB is probably sufficient;
there's not much point in giving a 32-bit machine much more memory
than that.
We now support the use of memory hotplug, so the physical to machine
page mapping structure must be dynamic. This is implemented as a
two-level radix tree structure, which allows us to efficiently
incrementally allocate memory for the p2m table as new pages are
added.
Non-PAE operation has been deprecated in Xen for a while, and is
rarely tested or used. xen-unstable has now officially dropped
non-PAE support. Since Xen/pvops' non-PAE support has also been
broken for a while, we may as well completely drop it altogether.
Use PTE_MASK to extract mfn from pte.
Tested-by: Hugh Dickins <hugh@veritas.com>
The definitions in include/asm/xen/page.h are arch specific.
ia64/xen wants to define its own version. So move them to arch specific
directory and keep include/xen/page.h in order not to break compilation.
Signed-off-by: Isaku Yamahata <yamahata@valinux.co.jp>
