path: root/include/asm-xtensa
2008-04-28mm: introduce pte_special pte bitNick Piggin
s390 for one, cannot implement VM_MIXEDMAP with pfn_valid, due to their memory model (which is more dynamic than most). Instead, they had proposed to implement it with an additional path through vm_normal_page(), using a bit in the pte to determine whether or not the page should be refcounted: vm_normal_page() { ... if (unlikely(vma->vm_flags & (VM_PFNMAP|VM_MIXEDMAP))) { if (vma->vm_flags & VM_MIXEDMAP) { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; #else if (!pfn_valid(pfn)) return NULL; #endif goto out; } ... } This is fine, however if we are allowed to use a bit in the pte to determine refcountedness, we can use that to _completely_ replace all the vma based schemes. So instead of adding more cases to the already complex vma-based scheme, we can have a clearly seperate and simple pte-based scheme (and get slightly better code generation in the process): vm_normal_page() { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; return pte_page(pte); #else ... #endif } And finally, we may rather make this concept usable by any architecture rather than making it s390 only, so implement a new type of pte state for this. Unfortunately the old vma based code must stay, because some architectures may not be able to spare pte bits. This makes vm_normal_page a little bit more ugly than we would like, but the 2 cases are clearly seperate. So introduce a pte_special pte state, and use it in mm/memory.c. It is currently a noop for all architectures, so this doesn't actually result in any compiled code changes to mm/memory.o. BTW: I haven't put vm_normal_page() into arch code as-per an earlier suggestion. The reason is that, regardless of where vm_normal_page is actually implemented, the *abstraction* is still exactly the same. Also, while it depends on whether the architecture has pte_special or not, that is the only two possible cases, and it really isn't an arch specific function -- the role of the arch code should be to provide primitive functions and accessors with which to build the core code; pte_special does that. We do not want architectures to know or care about vm_normal_page itself, and we definitely don't want them being able to invent something new there out of sight of mm/ code. If we made vm_normal_page an arch function, then we have to make vm_insert_mixed (next patch) an arch function too. So I don't think moving it to arch code fundamentally improves any abstractions, while it does practically make the code more difficult to follow, for both mm and arch developers, and easier to misuse. [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-02kvm: provide kvm.h for all architecture: fixes headers_installChristian Borntraeger
Currently include/linux/kvm.h is not considered by make headers_install, because Kbuild cannot handle " unifdef-$(CONFIG_FOO) += foo.h. This problem was introduced by commit fb56dbb31c4738a3918db81fd24da732ce3b4ae6 Author: Avi Kivity <avi@qumranet.com> Date: Sun Dec 2 10:50:06 2007 +0200 KVM: Export include/linux/kvm.h only if $ARCH actually supports KVM Currently, make headers_check barfs due to <asm/kvm.h>, which <linux/kvm.h> includes, not existing. Rather than add a zillion <asm/kvm.h>s, export kvm. only if the arch actually supports it. Signed-off-by: Avi Kivity <avi@qumranet.com> which makes this an 2.6.25 regression. One way of solving the issue is to enhance Kbuild, but Avi and David conviced me, that changing headers_install is not the way to go. This patch changes the definition for linux/kvm.h to unifdef-y. If  unifdef-y is used for linux/kvm.h "make headers_check" will fail on all architectures without asm/kvm.h. Therefore, this patch also provides asm/kvm.h on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Avi Kivity <avi@qumranet.com> Cc: Sam Ravnborg <sam@ravnborg.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13[XTENSA] Allow debugger to modify the WINDOWBASE register.Chris Zankel
For the 'return' command, GDB needs to adjust WINDOWBASE. In case WB is different from 0, we need to rotate the window register file and update WINDOWSTART and WMASK. This patch also removes some ret|= statements for __get_user/__put_user as the address range was alrady checked a couple of lines earlier. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Fix cache flush macro for D$/I$ aliasing/non-aliasingChris Zankel
For configurations that have aliasing in the data cache but not in the instruction cache, we don't need to flush the instruction cache. Thus, we didn't define the macros to flush the instruction cache. Some cache-flush functions, howerver, were using those macros. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Exclude thread-global registers from the xtregs structures.Chris Zankel
2008-02-13[XTENSA] Add support for configurable registers and coprocessorsChris Zankel
The Xtensa architecture allows to define custom instructions and registers. Registers that are bound to a coprocessor are only accessible if the corresponding enable bit is set, which allows to implement a 'lazy' context switch mechanism. Other registers needs to be saved and restore at the time of the context switch or during interrupt handling. This patch adds support for these additional states: - save and restore registers that are used by the compiler upon interrupt entry and exit. - context switch additional registers unbound to any coprocessor - 'lazy' context switch of registers bound to a coprocessor - ptrace interface to provide access to additional registers - update configuration files in include/asm-xtensa/variant-fsf Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Clean up stat structs.Bob Wilson
Avoid using typedefs for stat fields. Make stat64.st_blocks an unsigned long long to avoid endian-specific padding with 32-bit values. Clean up signed vs. unsigned and int vs. long types to be consistent with other uses of these values. Signed-off-by: Bob Wilson <bob.wilson@acm.org> Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Add volatile keyword to asm statements accessing counter registersChris Zankel
The compiler get's sometimes to smart and doesn't reread the counter registers and the kernel doesn't schedule until the counter wraps around. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Fix modules for non-exec processor configurationsChris Zankel
We need to use vmalloc_exec for module loading. Also remove the definitions MODULE_START and MODULE_END, which wasn't used, and increase the VMALLOC memory range accordingly. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Add missing cast in elf.h ELF_CORE_COPY_REGS()Marc Gauthier
Avoids compiler warning. Signed-off-by: Marc Gauthier <marc@tensilica.com>
2008-02-13[XTENSA] Remove oldmask from sigcontext and fix register flushChris Zankel
Remove oldmask from the sigcontext structure. Also update wmask and windowstart when we flush the AR registers to stack. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Clean up elf-gregset.Chris Zankel
Remove additional registers from the ELF gregset structure that are only used by the kernel or are not required or invalid in user-space. The ar registers are always aligned to a windowbase value of 0, and the WB register is always assumed to be 0. Increase the size of the structure to 128 entries. This will provide enough space in future. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Fix clobbered register in asm macroChris Zankel
We dangerously re-used an input operand to an asm macro without defining a constraint. By defining a separate output operand (instead of input/output operand), the compiler is more flexible during register allocation. Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-13[XTENSA] Fix non-existent pte_token_t typedef to pgtable_tChris Zankel
This bug was introduced in 2f569afd9ced9ebec9a6eb3dbf6f83429be0a7b4. (CONFIG_HIGHPTE vs. sub-page page tables) Signed-off-by: Chris Zankel <chris@zankel.net>
2008-02-08fix xtensa timerfd breakageAdrian Bunk
In file included from /home/bunk/linux/kernel-2.6/git/linux-2.6/arch/xtensa/kernel/syscall.c:39: include2/asm/unistd.h:681: error: 'sys_timerfd' undeclared here (not in a function) Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Christian Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08CONFIG_HIGHPTE vs. sub-page page tables.Martin Schwidefsky
Background: I've implemented 1K/2K page tables for s390. These sub-page page tables are required to properly support the s390 virtualization instruction with KVM. The SIE instruction requires that the page tables have 256 page table entries (pte) followed by 256 page status table entries (pgste). The pgstes are only required if the process is using the SIE instruction. The pgstes are updated by the hardware and by the hypervisor for a number of reasons, one of them is dirty and reference bit tracking. To avoid wasting memory the standard pte table allocation should return 1K/2K (31/64 bit) and 2K/4K if the process is using SIE. Problem: Page size on s390 is 4K, page table size is 1K or 2K. That means the s390 version for pte_alloc_one cannot return a pointer to a struct page. Trouble is that with the CONFIG_HIGHPTE feature on x86 pte_alloc_one cannot return a pointer to a pte either, since that would require more than 32 bit for the return value of pte_alloc_one (and the pte * would not be accessible since its not kmapped). Solution: The only solution I found to this dilemma is a new typedef: a pgtable_t. For s390 pgtable_t will be a (pte *) - to be introduced with a later patch. For everybody else it will be a (struct page *). The additional problem with the initialization of the ptl lock and the NR_PAGETABLE accounting is solved with a constructor pgtable_page_ctor and a destructor pgtable_page_dtor. The page table allocation and free functions need to call these two whenever a page table page is allocated or freed. pmd_populate will get a pgtable_t instead of a struct page pointer. To get the pgtable_t back from a pmd entry that has been installed with pmd_populate a new function pmd_pgtable is added. It replaces the pmd_page call in free_pte_range and apply_to_pte_range. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08avoid overflows in kernel/time.cH. Peter Anvin
When the conversion factor between jiffies and milli- or microseconds is not a single multiply or divide, as for the case of HZ == 300, we currently do a multiply followed by a divide. The intervening result, however, is subject to overflows, especially since the fraction is not simplified (for HZ == 300, we multiply by 300 and divide by 1000). This is exposed to the user when passing a large timeout to poll(), for example. This patch replaces the multiply-divide with a reciprocal multiplication on 32-bit platforms. When the input is an unsigned long, there is no portable way to do this on 64-bit platforms there is no portable way to do this since it requires a 128-bit intermediate result (which gcc does support on 64-bit platforms but may generate libgcc calls, e.g. on 64-bit s390), but since the output is a 32-bit integer in the cases affected, just simplify the multiply-divide (*3/10 instead of *300/1000). The reciprocal multiply used can have off-by-one errors in the upper half of the valid output range. This could be avoided at the expense of having to deal with a potential 65-bit intermediate result. Since the intent is to avoid overflow problems and most of the other time conversions are only semiexact, the off-by-one errors were considered an acceptable tradeoff. At Ralf Baechle's suggestion, this version uses a Perl script to compute the necessary constants. We already have dependencies on Perl for kernel compiles. This does, however, require the Perl module Math::BigInt, which is included in the standard Perl distribution starting with version 5.8.0. In order to support older versions of Perl, include a table of canned constants in the script itself, and structure the script so that Math::BigInt isn't required if pulling values from said table. Running the script requires that the HZ value is available from the Makefile. Thus, this patch also adds the Kconfig variable CONFIG_HZ to the architectures which didn't already have it (alpha, cris, frv, h8300, m32r, m68k, m68knommu, sparc, v850, and xtensa.) It does *not* touch the sh or sh64 architectures, since Paul Mundt has dealt with those separately in the sh tree. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Ralf Baechle <ralf@linux-mips.org>, Cc: Sam Ravnborg <sam@ravnborg.org>, Cc: Paul Mundt <lethal@linux-sh.org>, Cc: Richard Henderson <rth@twiddle.net>, Cc: Michael Starvik <starvik@axis.com>, Cc: David Howells <dhowells@redhat.com>, Cc: Yoshinori Sato <ysato@users.sourceforge.jp>, Cc: Hirokazu Takata <takata@linux-m32r.org>, Cc: Geert Uytterhoeven <geert@linux-m68k.org>, Cc: Roman Zippel <zippel@linux-m68k.org>, Cc: William L. Irwin <sparclinux@vger.kernel.org>, Cc: Chris Zankel <chris@zankel.net>, Cc: H. Peter Anvin <hpa@zytor.com>, Cc: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08asm-*/posix_types.h: scrub __GLIBC__Mike Frysinger
Some arches (like alpha and ia64) already have a clean posix_types.h header. This brings all the others in line by removing all references to __GLIBC__ (and some undocumented __USE_ALL). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: move STACK_TOP[_MAX] to asm/processor.hDavid Howells
Move STACK_TOP[_MAX] out of asm/a.out.h and into asm/processor.h as they're required whether or not A.OUT format is available. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Add cmpxchg_local to xtensaMathieu Desnoyers
Use the architecture specific __cmpxchg_u32 for 32 bits cmpxchg)_local. Else, use the new generic cmpxchg_local (disables interrupt). Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Cleanup asm/{elf,page,user}.h: #ifdef __KERNEL__ is no longer neededKirill A. Shutemov
asm/elf.h, asm/page.h and asm/user.h don't export to userspace now, so we can drop #ifdef __KERNEL__ for them. [k.shutemov@gmail.com: remove #ifdef __KERNEL_] Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Reviewed-by: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05add mm argument to pte/pmd/pud/pgd_freeBenjamin Herrenschmidt
(with Martin Schwidefsky <schwidefsky@de.ibm.com>) The pgd/pud/pmd/pte page table allocation functions get a mm_struct pointer as first argument. The free functions do not get the mm_struct argument. This is 1) asymmetrical and 2) to do mm related page table allocations the mm argument is needed on the free function as well. [kamalesh@linux.vnet.ibm.com: i386 fix] [akpm@linux-foundation.org: coding-syle fixes] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[NET]: Introducing socket mark socket option.Laszlo Attila Toth
A userspace program may wish to set the mark for each packets its send without using the netfilter MARK target. Changing the mark can be used for mark based routing without netfilter or for packet filtering. It requires CAP_NET_ADMIN capability. Signed-off-by: Laszlo Attila Toth <panther@balabit.hu> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-24xtensa: dma-mapping.h is using linux/scatterlist.h functions, so include itJens Axboe
It's currently using asm/scatterlist.h, but that is not enough. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-23xtensa: fix sg->page falloutEmil Medve
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22Add CONFIG_DEBUG_SG sg validationJens Axboe
Add a Kconfig entry which will toggle some sanity checks on the sg entry and tables. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22Change table chaining layoutJens Axboe
Change the page member of the scatterlist structure to be an unsigned long, and encode more stuff in the lower bits: - Bits 0 and 1 zero: this is a normal sg entry. Next sg entry is located at sg + 1. - Bit 0 set: this is a chain entry, the next real entry is at ->page_link with the two low bits masked off. - Bit 1 set: this is the final entry in the sg entry. sg_next() will return NULL when passed such an entry. It's thus important that sg table users use the proper accessors to get and set the page member. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-19forbid asm/bitops.h direct inclusionJiri Slaby
forbid asm/bitops.h direct inclusion Because of compile errors that may occur after bit changes if asm/bitops.h is included directly without e.g. linux/kernel.h which includes linux/bitops.h, forbid direct inclusion of asm/bitops.h. Thanks to Adrian Bunk. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19remove unused flush_tlb_pgtablesBenjamin Herrenschmidt
Nobody uses flush_tlb_pgtables anymore, this patch removes all remaining traces of it from all archs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18bitops: introduce lock opsNick Piggin
Introduce test_and_set_bit_lock / clear_bit_unlock bitops with lock semantics. Convert all architectures to use the generic implementation. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-By: David Howells <dhowells@redhat.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <bryan.wu@analog.com> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Cc: Richard Curnow <rc@rc0.org.uk> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Andi Kleen <ak@muc.de> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17remove strict ansi check from __u64 in asm/types.hOlaf Hering
Remove the __STRICT_ANSI__ check from the __u64/__s64 declaration on 32bit targets. GCC can be made to warn about usage of long long types with ISO C90 (-ansi), but only with -pedantic. You can write this in a way that even then it doesn't cause warnings, namely by: #ifdef __GNUC__ __extension__ typedef __signed__ long long __s64; __extension__ typedef unsigned long long __u64; #endif The __extension__ keyword in front of this switches off any pedantic warnings for this expression. Signed-off-by: Olaf Hering <olh@suse.de> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17kill DECLARE_MUTEX_LOCKEDChristoph Hellwig
DECLARE_MUTEX_LOCKED was used for semaphores used as completions and we've got rid of them. Well, except for one in libusual that the maintainer explicitly wants to keep as semaphore. So convert that useage to an explicit sema_init and kill of DECLARE_MUTEX_LOCKED so that new code is reminded to use a completion. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: "Satyam Sharma" <satyam.sharma@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-27[patch 1/2] Xtensa: enable arbitary tty speed setting ioctlsAlan Cox
Adding the defines/constants activates the existing code in the tty layer and allows arbitary tty speeds to be requested on this platform Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Chris Zankel <chris@zankel.net>
2007-08-27[XTENSA] Add support for cache-aliasingChris Zankel
Add support for processors that have cache-aliasing issues, such as the Stretch S5000 processor. Cache-aliasing means that the size of the cache (for one way) is larger than the page size, thus, a page can end up in several places in cache depending on the virtual to physical translation. The method used here is to map a user page temporarily through the auto-refill way 0 and of of the DTLB. We probably will want to revisit this issue and use a better approach with kmap/kunmap. Signed-off-by: Chris Zankel <chris@zankel.net>
2007-08-27[XTENSA] Add kernel module supportChris Zankel
Add kernel module support. Signed-off-by: Chris Zankel <chris@zankel.net>
2007-08-27[XTENSA] Add support for executable/non-executable feature in the mmuChris Zankel
Newer processor versions starting with Xtensa6/LX2 support an 'executable' bit for memory pages. This bit replaces the 'valid' bit, so it must be always set to one for older processor versions. To mark a page invalid, we now set the cache-attributes to b11, which is backward compatible. Signed-off-by: Chris Zankel <chris@zankel.net>
2007-08-27[XTENSA] Use the generic version of get_orderChris Zankel
Use the generic version of get_order for processor configurations that don't have the 'nsa/nsau' instructions. Signed-off-by: Chris Zankel <chris@zankel.net>
2007-08-27[XTENSA] Add typecast macro for constantsChris Zankel
Add macros (__XTENSA_UL and __XTENSA_UL_CONST) for typecasting constants. Signed-off-by: Chris Zankel <chris@zankel.net>
2007-08-27[XTENSA] Fix timer instabilities.Chris Zankel
The timer code could have missed a tick. Signed-off-by: Chris Zankel <chris@zankel.net>
2007-08-27[XTENSA] Fix fadvise64_64Chris Zankel
Xtensa passes long long arguments in a even/odd register pair, so we also need to shuffle the arguments when passed through the system call to avoid an empty argument register. Signed-off-by: Chris Zankel <chris@zankel.net>
2007-08-27[XTENSA] Remove extraneous include statementChris Zankel
We don't need to include processor.h in bug.h. Signed-off-by: Chris Zankel <chris@zankel.net>
2007-08-27[XTENSA] Add getpgrp system-call to unistd.hChris Zankel
Although __ARCH_WANT_SYS_GETPGRP was defined, the actualy entry for the getpgrp system-call was missing. Signed-off-by: Chris Zankel <chris@zankel.net>
2007-08-27[XTENSA] add missing system callsChris Zankel
Add missing system calls that have been recently added to the kernel for the Xtensa architecture and define __IGNORE macros for system calls that we don't need for Xtensa. Signed-off-by: Chris Zankel <chris@zankel.net>
2007-07-31remove unused TIF_NOTIFY_RESUME flagStephane Eranian
Remove unused TIF_NOTIFY_RESUME flag for all processor architectures. The flag was not used excecpt on IA-64 where the patch replaces it with TIF_PERFMON_WORK. Signed-off-by: stephane eranian <eranian@hpl.hp.com> Cc: <linux-arch@vger.kernel.org> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-24include/asm-xtensa/io.h must #include <asm/page.h>Adrian Bunk
CC kernel/time/clocksource.o In file included from /home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/include/linux/clocksource.h:18, from /home/bunk/linux/kernel-2.6/linux-2.6.22-rc6-mm1/kernel/time/clocksource.c:27: include2/asm/io.h: In function 'virt_to_phys': include2/asm/io.h:46: error: implicit declaration of function '__pa' include2/asm/io.h: In function 'phys_to_virt': include2/asm/io.h:51: error: implicit declaration of function '__va' include2/asm/io.h:51: warning: return makes pointer from integer without a cast make[3]: *** [kernel/time/clocksource.o] Error 1 Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Christian Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19arch: personality independent stack topPeter Zijlstra
New arch macro STACK_TOP_MAX it gives the larges valid stack address for the architecture in question. It differs from STACK_TOP in that it will not distinguish between personalities but will always return the largest possible address. This is used to create the initial stack on execve, which we will move down to the proper location once the binfmt code has figured out where that is. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ollie Wild <aaw@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17fbdev: detect primary display deviceAntonino A. Daplas
Add function helper, fb_is_primary_device(). Given struct fb_info, it will return a nonzero value if the device is the primary display. Currently, only the i386 is supported where the function checks for the IORESOURCE_ROM_SHADOW flag. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17fbdev: move arch-specific bits to their respective subdirectoriesAntonino A. Daplas
Move arch-specific bits of fb_mmap() to their respective subdirectories [bob.picco@hp.com: efi_range_is_wc is referenced but not declared] [bunk@stusta.de: fix include/asm-m68k/fb.h] Signed-off-by: Antonino Daplas <adaplas@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17mm: remove ptep_test_and_clear_dirty and ptep_clear_flush_dirtyMartin Schwidefsky
Nobody is using ptep_test_and_clear_dirty and ptep_clear_flush_dirty. Remove the functions from all architectures. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
