path: root/include/crypto/cast6.h
2012-12-06crypto: cast5/cast6 - move lookup tables to shared moduleJussi Kivilinna
CAST5 and CAST6 both use same lookup tables, which can be moved shared module 'cast_common'. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-09-07crypto: cast6 - fix sparse warnings (symbol was not declared, should be static?)Jussi Kivilinna
Fix "symbol 'x' was not declared. Should it be static?" sparse warnings. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2012-08-01crypto: cast6 - prepare generic module for optimized implementationsJohannes Goetzfried
Rename cast6 module to cast6_generic to allow autoloading of optimized implementations. Generic functions and s-boxes are exported to be able to use them within optimized implementations. Signed-off-by: Johannes Goetzfried <Johannes.Goetzfried@informatik.stud.uni-erlangen.de> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
