This patch attempts to fix up shortcomings with the current calling
sequences.
1) There's a fastpath where no locking occurs and only io_mem_reserved is
called to obtain needed info for mapping. The fastpath is set per
memory type manager.
2) If the fastpath is disabled, io_mem_reserve and io_mem_free will be exactly
balanced and not called recursively for the same struct ttm_mem_reg.
3) Optionally the driver can choose to enable a per memory type manager LRU
eviction mechanism that, when io_mem_reserve returns -EAGAIN will attempt
to kill user-space mappings of memory in that manager to free up needed
resources
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Ben Skeggs <bskeggs@redhat.com>
The bo lock used only to protect the bo sync object members, and since it
is a per bo lock, fencing a buffer list will see a lot of locks and unlocks.
Replace it with a per-device lock that protects the sync object members on
*all* bos. Reading and setting these members will always be very quick, so
the risc of heavy lock contention is microscopic. Note that waiting for
sync objects will always take place outside of this lock.
The bo device fence lock will eventually be replaced with a seqlock /
rcu mechanism so we can determine that a bo is idle under a
rcu / read seqlock.
However this change will allow us to batch fencing and unreserving of
buffers with a minimal amount of locking.
Reviewed-by: Jerome Glisse <j.glisse@gmail.com>
Makes it possible to reserve a list of buffer objects with a single
spin lock / unlock if there is no contention.
Should improve cpu usage on SMP kernels.
v2: Initialize private list members on reserve and don't call
ttm_bo_list_ref_sub() with zero put_count.
Call destroy() on _all_ ttm_bo_init() failures, and make sure that
behavior is documented in the function description.
drivers/gpu/drm/i915/intel_fb.c
drivers/gpu/drm/radeon/r600_blit_kms.c
drivers/gpu/drm/ttm/ttm_bo.c
This fixes a race pointed out by Dave Airlie where we don't take a buffer
object about to be destroyed off the LRU lists properly. It also fixes a rare
case where a buffer object could be destroyed in the middle of an
accelerated eviction.
The patch also adds a utility function that can be used to prematurely
release GPU memory space usage of an object waiting to be destroyed.
For example during eviction or swapout.
The above mentioned commit didn't queue the buffer on the delayed destroy
list under some rare circumstances. It also didn't completely honor the
remove_all parameter.
Fixes:
https://bugzilla.redhat.com/show_bug.cgi?id=615505
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=591061
Nouveau will need this on GeForce 8 and up to account for the GPU
reordering physical VRAM for some memory types.
Reviewed-by: Jerome Glisse <jglisse@redhat.com>
Acked-by: Thomas Hellström <thellstrom@vmware.com>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
We want to be able to prevent the delayed workqueue from changing state
while we're reclocking, so add an API to block and unblock it.
On fault the driver is given the opportunity to perform any operation
it sees fit in order to place the buffer into a CPU visible area of
memory. This patch doesn't break TTM users, nouveau, vmwgfx and radeon
should keep working properly. Future patch will take advantage of this
infrastructure and remove the old path from TTM once driver are
converted.
V2 return VM_FAULT_NOPAGE if callback return -EBUSY or -ERESTARTSYS
V3 balance io_mem_reserve and io_mem_free call, fault_reserve_notify
is responsible to perform any necessary task for mapping to succeed
V4 minor cleanup, atomic_t -> bool as member is protected by reserve
mecanism from concurent access
V5 the callback is now responsible for iomapping the bo and providing
a virtual address this simplify TTM and will allow to get rid of
TTM_MEMTYPE_FLAG_NEEDS_IOREMAP
V6 use the bus addr data to decide to ioremap or this isn't needed
but we don't necesarily need to ioremap in the callback but still
allow driver to use static mapping
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
There is case where we want to be able to wait only for the
GPU while not waiting for other buffer to be unreserved. This
patch split the no_wait argument all the way down in the whole
ttm path so that upper level can decide on what to wait on or
not.
[airlied: squashed these 4 for bisectability reasons.]
drm/radeon/kms: update to TTM no_wait splitted argument
drm/nouveau: update to TTM no_wait splitted argument
drm/vmwgfx: update to TTM no_wait splitted argument
[vmwgfx patch: Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>]
Acked-by: Thomas Hellstrom <thellstrom@vmware.com>
Convert ttm_buffer_object_init to use struct ttm_placement and
rename to ttm_bo_init for consistency with function naming. This
allow to give more complex placement at buffer creation. For
instance you ask to allocate bo into vram first but if there is
not enough vram you can give system as a second possible
placement. It also allow to create buffer in a specific range.
Also rename ttm_buffer_object_validate to ttm_bo_validate.
Return -ERESTARTSYS instead of -ERESTART when interrupted by a signal.
The -ERESTARTSYS is converted to an -EINTR by the kernel signal layer
before returned to user-space.
This change allow driver to pass sorted memory placement,
from most prefered placement to least prefered placement.
In order to avoid long function prototype a structure is
used to gather memory placement informations such as range
restriction (if you need a buffer to be in given range).
Range restriction is determined by fpfn & lpfn which are
the first page and last page number btw which allocation
can happen. If those fields are set to 0 ttm will assume
buffer can be put anywhere in the address space (thus it
avoids putting a burden on the driver to always properly
set those fields).
This patch also factor few functions like evicting first
entry of lru list or getting a memory space. This avoid
code duplication.
V2: Change API to use placement flags and array instead
of packing placement order into a quadword.
V3: Make sure we set the appropriate mem.placement flag
when validating or allocation memory space.
[Pending Thomas Hellstrom further review but okay
from preliminary review so far].
Common resources, like memory accounting and swap lists should be
global and not per device. Introduce a struct ttm_bo_global to
accomodate this, and register it with sysfs. Add a small sysfs interface
to return the number of active buffer objects.
Signed-off-by: Dave Airlie <airlied@linux.ie>
A micro-optimization on the function ttm_kmap_obj_virtual().
By defining the values of enum ttm_bo_kmap_obj::bo_kmap_type to have a
bit indicating iomem, size of the function ttm_kmap_obj_virtual() will be
reduced by 16 bytes on x86_64 (gcc 4.1.2).
ttm_kmap_obj_virtual() may be heavily used, when buffer objects are
accessed via wrappers, that work for both kinds of memory addresses:
iomem cookies and kernel virtual.
Signed-off-by: Pekka Paalanen <pq@iki.fi>
TTM is a GPU memory manager subsystem designed for use with GPU
devices with various memory types (On-card VRAM, AGP,
PCI apertures etc.). It's essentially a helper library that assists
the DRM driver in creating and managing persistent buffer objects.
TTM manages placement of data and CPU map setup and teardown on
data movement. It can also optionally manage synchronization of
data on a per-buffer-object level.
TTM takes care to provide an always valid virtual user-space address
to a buffer object which makes user-space sub-allocation of
big buffer objects feasible.
TTM uses a fine-grained per buffer-object locking scheme, taking
care to release all relevant locks when waiting for the GPU.
Although this implies some locking overhead, it's probably a big
win for devices with multiple command submission mechanisms, since
the lock contention will be minimal.
TTM can be used with whatever user-space interface the driver
chooses, including GEM. It's used by the upcoming Radeon KMS DRM driver
and is also the GPU memory management core of various new experimental
DRM drivers.
