commit 8c3e434769b1707fd2d24de5a2eb25fedc634c4a upstream.
0x4c6e is a secondary device id so should not be used
by the driver.
Noticed-by: Mark Kettenis <mark.kettenis@xs4all.nl>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit c149dcb5c60bfea8871f16dfcc0690255eeb825f upstream.
For Haswell and Broadwell, if the display power well has been disabled,
the display audio controller divider values EM4 M VALUE and EM5 N VALUE
will have been lost. The CDCLK frequency is required for reprogramming them
to generate 24MHz HD-A link BCLK. So provide a private interface for the
audio driver to query CDCLK.
This is a stopgap solution until a more generic interface between audio
and display drivers has been implemented.
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Reviewed-by: Damien Lespiau <damien.lespiau@intel.com>
Signed-off-by: Mengdong Lin <mengdong.lin@intel.com>
Cc: <stable@vger.kernel.org>
commit 74b0c2d75fb4cc89173944e6d8f9eb47aca0c343 upstream.
When a machine is booted with nomodeset option, i915 driver skips the
whole initialization. Meanwhile, HD-audio tries to bind wth i915 just
by request_symbol() without knowing that the initialization was
skipped, and eventually it hits WARN_ON() in i915_request_power_well()
and i915_release_power_well() wrongly but still continues probing,
even though it doesn't work at all.
In this patch, both functions are changed to return an error in case
of uninitialized state instead of WARN_ON(), so that HD-audio driver
can give up HDMI controller initialization at the right time.
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: <stable@vger.kernel.org> [3.15]
commit 37dbeab788a8f23fd946c0be083e5484d6f929a1 upstream.
commit 5fc540edc8ea1297c76685f74bc82a2107fe6731 upstream.
commit 6dc14baf4ced769017c7a7045019c7a19f373865 upstream.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=82912
commit 3cf70dafd7bbbc91df0a9ecb081d46f9f3d867f6 upstream.
New helper function to set the preferred video mode. Can be called
after drm_add_modes_noedid if you don't want the largest supported
video mode be used by default.
Signed-off-by: Gerd Hoffmann <kraxel@redhat.com>
commit d00adcc8ae9e22eca9d8af5f66c59ad9a74c90ec upstream.
Fixes rendering corruption due to incorrect
gfx configuration.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=63599
This reverts commit 7c510133d93dd6f15ca040733ba7b2891ed61fd1.
Well looks like not enough digging was done, libdrm_nouveau before 2.4.33
used contexts,
292da616fe1f936ca78a3fa8e1b1b19883e343b6 nouveau: pull in major libdrm rewrite
got rid of them,
Reported-by: Paul Zimmerman <Paul.Zimmerman@synopsys.com>
Reported-by: Mikael Pettersson <mikpe@it.uu.se>
Cc: stable@vger.kernel.org
git://people.freedesktop.org/~danvet/drm-intel into drm-fixes
- Early stolen mem reservation from Jesse in x86 boot code. Acked by Ingo
and hpa. This was ready much earlier but somehow I've thought it'd go
in through x86 trees, hence why this is late. Avoids the pci resource
code to plant mmiobars in the middle of stolen mem and other ugliness.
- vgaarb improvements from Alex Williamson plus the fix from Ville for the
vgacon->fbcon smooth transition "feature".
- Render pageflips on ivb/hsw to avoid stalls due to the ring switching
when only flipping on the blitter (Chris).
- Deadlock fixes around our flush_workqueue which crept back in - lockdep
isn't clever enough :(
- Shrinker recursion fix from Chris - this is the thing that blew the vma
patches from Ben I've taken out of 3.12.
- Fixup for the relocation refactoring. Also an igt testcase to make sure
we don't break this again.
- Pile of smaller fixups all over, shortlog has full details.
* tag 'drm-intel-fixes-2013-09-06' of git://people.freedesktop.org/~danvet/drm-intel: (29 commits)
drm/i915: Delay disabling of VGA memory until vgacon->fbcon handoff is done
drm/i915: try not to lose backlight CBLV precision
drm/i915: Confine page flips to BCS on Valleyview
drm/i915: Skip stolen region initialisation if none is reserved
drm/i915: fix gpu hang vs. flip stall deadlocks
drm/i915: Hold an object reference whilst we shrink it
drm/i915: fix i9xx_crtc_clock_get for multiplied pixels
drm/i915: handle sdvo input pixel multiplier correctly again
drm/i915: fix hpd work vs. flush_work in the pageflip code deadlock
drm/i915: fix up the relocate_entry refactoring
drm/i915: Fix pipe config warnings when dealing with LVDS fixed mode
drm/i915: Don't call sg_free_table() if sg_alloc_table() fails
i915: Update VGA arbiter support for newer devices
vgaarb: Fix VGA decodes changes
vgaarb: Don't disable resources that are not owned
drm/i915: Pin pages whilst mapping the dma-buf
drm/i915: enable trickle feed on Haswell
x86: add early quirk for reserving Intel graphics stolen memory v5
drm/i915: split PCI IDs out into i915_drm.h v4
i915_gem: Convert kmem_cache_alloc(...GFP_ZERO) to kmem_cache_zalloc
The patch replaces all occurrences of struct fb_videomode by
more accurate struct videomode. The change allows to remove
mode conversion function and simplifies clock divider calculation.
Clock configuration is moved to separate function.
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Inki Dae <inki.dae@samsung.com>
Systems with Intel graphics controllers set aside memory exclusively for
gfx driver use. This memory is not always marked in the E820 as
reserved or as RAM, and so is subject to overlap from E820 manipulation
later in the boot process. On some systems, MMIO space is allocated on
top, despite the efforts of the "RAM buffer" approach, which simply
rounds memory boundaries up to 64M to try to catch space that may decode
as RAM and so is not suitable for MMIO.
v2: use read_pci_config for 32 bit reads instead of adding a new one
(Chris)
add gen6 stolen size function (Chris)
v3: use a function pointer (Chris)
drop gen2 bits (Daniel)
v4: call e820_sanitize_map after adding the region
v5: fixup comments (Peter)
simplify loop (Chris)
Acked-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=66726
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=66844
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
For use by userspace (at some point in the future) and other kernel code.
v2: move PCI IDs to uabi (Chris)
move PCI IDs to drm/ (Dave)
v3: fixup Quanta detection - needs to come first (Daniel)
v4: fix up PCI match structure init for easier use by userspace (Chris)
This patch adds the notion of a drm_bridge. A bridge is a chained
device which hangs off an encoder. The drm driver using the bridge
should provide the association between encoder and bridge. Once a
bridge is associated with an encoder, it will participate in mode
set, and dpms (via the enable/disable hooks).
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Reviewed-by: Rob Clark <robdclark@gmail.com>
into drm-next
Alex writes:
This is the radeon drm-next request. Big changes include:
- support for dpm on CIK parts
- support for ASPM on CIK parts
- support for berlin GPUs
- major ring handling cleanup
- remove the old 3D blit code for bo moves in favor of CP DMA or sDMA
- lots of bug fixes
[airlied: fix up a bunch of conflicts from drm_order removal]
* 'drm-next-3.12' of git://people.freedesktop.org/~agd5f/linux: (898 commits)
drm/radeon/dpm: make sure dc performance level limits are valid (CI)
drm/radeon/dpm: make sure dc performance level limits are valid (BTC-SI) (v2)
drm/radeon: gcc fixes for extended dpm tables
drm/radeon: gcc fixes for kb/kv dpm
drm/radeon: gcc fixes for ci dpm
drm/radeon: gcc fixes for si dpm
drm/radeon: gcc fixes for ni dpm
drm/radeon: gcc fixes for trinity dpm
drm/radeon: gcc fixes for sumo dpm
drm/radeonn: gcc fixes for rv7xx/eg/btc dpm
drm/radeon: gcc fixes for rv6xx dpm
drm/radeon: gcc fixes for radeon_atombios.c
drm/radeon: enable UVD interrupts on CIK
drm/radeon: fix init ordering for r600+
drm/radeon/dpm: only need to reprogram uvd if uvd pg is enabled
drm/radeon: check the return value of uvd_v1_0_start in uvd_v1_0_init
drm/radeon: split out radeon_uvd_resume from uvd_v4_2_resume
radeon kms: fix uninitialised hotplug work usage in r100_irq_process()
drm/radeon/audio: set up the sads on DCE3.2 asics
drm/radeon: fix handling of variable sized arrays for router objects
drivers/gpu/drm/i915/i915_dma.c
drivers/gpu/drm/i915/i915_gem_dmabuf.c
drivers/gpu/drm/i915/intel_pm.c
drivers/gpu/drm/radeon/cik.c
drivers/gpu/drm/radeon/ni.c
drivers/gpu/drm/radeon/r600.c
This adds the pci ids for the berlin GPU core.
(v3)
This adds a helper function to extract the speaker allocation
data block from the EDID. This data block describes what speakers
are present on the display device.
v2: update per Ville Syrjälä's comments
v3: fix copy/paste typo in memory allocation
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Tested-by: Rafał Miłecki <zajec5@gmail.com>
Let applications know whether the kernel supports asynchronous page
flipping.
Signed-off-by: Keith Packard <keithp@keithp.com>
Signed-off-by: Dave Airlie <airlied@gmail.com>
This lets drivers see the flags requested by the application
[airlied: fixup for rcar/imx/msm]
Unfortunately, I haven't been thorough enough in:
commit ddecb10cf402a8325579f298fd4986a90f33496b
Author: Lespiau, Damien <damien.lespiau@intel.com>
Date: Tue Aug 20 00:53:04 2013 +0100
drm: Remove drm_mode_create_dithering_property()
And forgot to remove the dithering_mode_property member of struct
drm_mode_config.
Signed-off-by: Damien Lespiau <damien.lespiau@intel.com>
Render nodes provide an API for userspace to use non-privileged GPU
commands without any running DRM-Master. It is useful for offscreen
rendering, GPGPU clients, and normal render clients which do not perform
modesetting.
Compared to legacy clients, render clients no longer need any
authentication to perform client ioctls. Instead, user-space controls
render/client access to GPUs via filesystem access-modes on the
render-node. Once a render-node was opened, a client has full access to
the client/render operations on the GPU. However, no modesetting or ioctls
that affect global state are allowed on render nodes.
To prevent privilege-escalation, drivers must explicitly state that they
support render nodes. They must mark their render-only ioctls as
DRM_RENDER_ALLOW so render clients can use them. Furthermore, they must
support clients without any attached master.
If filesystem access-modes are not enough for fine-grained access control
to render nodes (very unlikely, considering the versaitlity of FS-ACLs),
you may still fall-back to fd-passing from server to client (which allows
arbitrary access-control). However, note that revoking access is
currently impossible and unlikely to get implemented.
Note: Render clients no longer have any associated DRM-Master as they are
supposed to be independent of any server state. DRM core highly depends on
file_priv->master to be non-NULL for modesetting/ctx/etc. commands.
Therefore, drivers must be very careful to not require DRM-Master if they
support DRIVER_RENDER.
So far render-nodes are protected by "drm_rnodes". As long as this
module-parameter is not set to 1, a driver will not create render nodes.
This allows us to experiment with the API a bit before we stabilize it.
v2: drop insecure GEM_FLINK to force use of dmabuf
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
This can then be used by DRM drivers to setup their vendor infoframes.
v2: Fix hmdi typo (Simon Farnsworth)
v3: Adapt to the hdmi_vendor_infoframe rename
Reviewed-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk>
Reviewed-by: Thierry Reding <treding@nvidia.com>
This function is only used inside drm_edid.c.
The VMA offset manager uses a device-global address-space. Hence, any
user can currently map any offset-node they want. They only need to guess
the right offset. If we wanted per open-file offset spaces, we'd either
need VM_NONLINEAR mappings or multiple "struct address_space" trees. As
both doesn't really scale, we implement access management in the VMA
manager itself.
We use an rb-tree to store open-files for each VMA node. On each mmap
call, GEM, TTM or the drivers must check whether the current user is
allowed to map this file.
We add a separate lock for each node as there is no generic lock available
for the caller to protect the node easily.
As we currently don't know whether an object may be used for mmap(), we
have to do access management for all objects. If it turns out to slow down
handle creation/deletion significantly, we can optimize it in several
ways:
- Most times only a single filp is added per bo so we could use a static
"struct file *main_filp" which is checked/added/removed first before we
fall back to the rbtree+drm_vma_offset_file.
This could be even done lockless with rcu.
- Let user-space pass a hint whether mmap() should be supported on the
bo and avoid access-management if not.
- .. there are probably more ideas once we have benchmarks ..
v2: add drm_vma_node_verify_access() helper
... not only when the dma-buf is freshly created. In contrived
examples someone else could have exported/imported the dma-buf already
and handed us the gem object with a flink name. If such on object gets
reexported as a dma_buf we won't have it in the handle cache already,
which breaks the guarantee that for dma-buf imports we always hand
back an existing handle if there is one.
This is exercised by igt/prime_self_import/with_one_bo_two_files
Now if we extend the locked sections just a notch more we can also
plug th racy buf/handle cache setup in handle_to_fd:
If evil userspace races a concurrent gem close against a prime export
operation we can end up tearing down the gem handle before the dma buf
handle cache is set up. When handle_to_fd gets around to adding the
handle to the cache there will be no one left to clean it up,
effectily leaking the bo (and the dma-buf, since the handle cache
holds a ref on the dma-buf):
Thread A Thread B
handle_to_fd:
lookup gem object from handle
creates new dma_buf
gem_close on the same handle
obj->dma_buf is set, but file priv buf
handle cache has no entry
obj->handle_count drops to 0
drm_prime_add_buf_handle sets up the handle cache
-> We have a dma-buf reference in the handle cache, but since the
handle_count of the gem object already dropped to 0 no on will clean
it up. When closing the drm device fd we'll hit the WARN_ON in
drm_prime_destroy_file_private.
The important change is to extend the critical section of the
filp->prime.lock to cover the gem handle lookup. This serializes with
a concurrent gem handle close.
This leak is exercised by igt/prime_self_import/export-vs-gem_close-race
... and move it to the top of the function to avoid a forward
declaration.
with the reworking semantics and locking of the obj->dma_buf pointer
this pointer is always set as long as there's still a gem handle
around and a dma_buf associated with this gem object.
Also, the per file-priv lookup-cache for dma-buf importing is also
unified between foreign and native objects.
Hence we don't need to special case the clean any more and can simply
drop the clause which only runs for foreing objects, i.e. with
obj->import_attach set.
Note that with this change (actually with the previous one to always
set up obj->dma_buf even for foreign objects) it is no longer required
to set obj->import_attach when importing a foreing object. So update
comments accordingly, too.
The export dma-buf cache is semantically similar to an flink name. So
semantically it makes sense to treat it the same and remove the name
(i.e. the dma_buf pointer) and its references when the last gem handle
disappears.
Again we need to be careful, but double so: Not just could someone
race and export with a gem close ioctl (so we need to recheck
obj->handle_count again when assigning the new name), but multiple
exports can also race against each another. This is prevented by
holding the dev->object_name_lock across the entire section which
touches obj->dma_buf.
With the new scheme we also need to reinstate the obj->dma_buf link at
import time (in case the only reference userspace has held in-between
was through the dma-buf fd and not through any native gem handle). For
simplicity we don't check whether it's a native object but
unconditionally set up that link - with the new scheme of removing the
obj->dma_buf reference when the last handle disappears we can do that.
To make it clear that this is not just for exported buffers anymore
als rename it from export_dma_buf to dma_buf.
To make sure that now one can race a fd_to_handle or handle_to_fd with
gem_close we use the same tricks as in flink of extending the
dev->object_name_locking critical section. With this change we finally
have a guaranteed 1:1 relationship (at least for native objects)
between gem objects and dma-bufs, even accounting for races (which can
happen since the dma-buf itself holds a reference while in-flight).
This prevent igt/prime_self_import/export-vs-gem_close-race from
Oopsing the kernel. There is still a leak though since the per-file
priv dma-buf/handle cache handling is racy. That will be fixed in a
later patch.
v2: Remove the bogus dma_buf_put from the export_and_register_object
failure path if we've raced with the handle count dropping to 0.
The gem flink name holds a reference onto the object itself, and this
self-reference would prevent an flink'ed object from every being
freed. To break that loop we remove the flink name when the last
userspace handle disappears, i.e. when obj->handle_count reaches 0.
Now in gem_open we drop the dev->object_name_lock between the flink
name lookup and actually adding the handle. This means a concurrent
gem_close of the last handle could result in the flink name getting
reaped right inbetween, i.e.
Thread 1 Thread 2
gem_open gem_close
flink -> obj lookup
remove flink name
create_handle
handle_count++
If someone now flinks this object again, we'll get a new flink name.
We can close this race by removing the lock dropping and making the
entire lookup+handle_create sequence atomic. Unfortunately to still be
able to share the handle_create logic this requires a
handle_create_tail function which drops the lock - we can't hold the
object_name_lock while calling into a driver's ->gem_open callback.
Note that for flink fixing this race isn't really important, since
racing gem_open against gem_close is clearly a userspace bug. And no
matter how the race ends, we won't leak any references.
But with dma-buf where the userspace dma-buf fd itself is refcounted
this is a valid sequence and hence we should fix it. Therefore this
patch here is just a warm-up exercise (and for consistency between
flink buffer sharing and dma-buf buffer sharing with self-imports).
Also note that this extension of the critical section in gem_open
protected by dev->object_name_lock only works because it's now a
mutex: A spinlock would conflict with the potential memory allocation
in idr_preload().
This is exercises by igt/gem_flink_race/flink_name.
I want to wrap the creation of a dma-buf from a gem object in it,
so that the obj->export_dma_buf cache can be atomically filled in.
Instead of creating a new mutex just for that variable I've figured
I can reuse the existing dev->object_name_lock, especially since
the new semantics will exactly mirror the flink obj->name already
protected by that lock.
v2: idr_preload/idr_preload_end is now an atomic section, so need to
move the mutex locking outside.
[airlied: fix up conflict with patch to make debugfs use lock]
No one outside of drm should use this, the official interfaces are
drm_gem_handle_create and drm_gem_handle_delete. The handle refcounting
is purely an implementation detail of gem.
This is the 2nd attempt, I've always been a bit dissatisified with the
tricky nature of the first one:
http://lists.freedesktop.org/archives/dri-devel/2012-July/025451.html
The issue is that the flink ioctl can race with calling gem_close on
the last gem handle. In that case we'll end up with a zero handle
count, but an flink name (and it's corresponding reference). Which
results in a neat space leak.
In my first attempt I've solved this by rechecking the handle count.
But fundamentally the issue is that ->handle_count isn't your usual
refcount - it can be resurrected from 0 among other things.
For those special beasts atomic_t often suggest way more ordering that
it actually guarantees. To prevent being tricked by those hairy
semantics take the easy way out and simply protect the handle with the
existing dev->object_name_lock.
With that change implemented it's dead easy to fix the flink vs. gem
close reace: When we try to create the name we simply have to check
whether there's still officially a gem handle around and if not refuse
to create the flink name. Since the handle count decrement and flink
name destruction is now also protected by that lock the reace is gone
and we can't ever leak the flink reference again.
Outside of the drm core only the exynos driver looks at the handle
count, and tbh I have no idea why (it's just for debug dmesg output
luckily).
I've considered inlining the drm_gem_object_handle_free, but I plan to
add more name-like things (like the exported dma_buf) to this scheme,
so it's clearer to leave the handle freeing in its own function.
This is exercised by the new gem_flink_race i-g-t testcase, which on
my snb leaks gem objects at a rate of roughly 1k objects/s.
v2: Fix up the error path handling in handle_create and make it more
robust by simply calling object_handle_unreference.
v3: Fix up the handle_unreference logic bug - atomic_dec_and_test
retursn 1 for 0. Oops.
v4: Squash in inlining of drm_gem_object_handle_reference as suggested
by Dave Airlie and add a note that we now have a testcase.
Cc: Dave Airlie <airlied@gmail.com>
Cc: Inki Dae <inki.dae@samsung.com>
It's only used in drm_platform.c.
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
This function is only used in drm_fb_cma_helper.c.
These were introduced in the very first DRM commit:
commit f453ba0460742ad027ae0c4c7d61e62817b3e7ef
Author: Dave Airlie <airlied@redhat.com>
Date: Fri Nov 7 14:05:41 2008 -0800
DRM: add mode setting support
Add mode setting support to the DRM layer.
But are unused.
It's only used in drm_crtc.c.
The last user was removed in
commit 575dc34ee0de867ba83abf25998e0963bff451fa
Date: Mon Sep 7 18:43:26 2009 +1000
drm/kms: remove old std mode fallback code.
The new code adds modes in the helper, which makes more sense
I disliked the non-driver code adding modes.
This was last used by nouveau, replaced by a driver-specific property
in:
commit de69185573586302ada2e59ba41835df36986277
Author: Ben Skeggs <bskeggs@redhat.com>
Date: Mon Oct 17 12:23:41 2011 +1000
drm/nouveau: improve dithering properties, and implement proper auto mode
A few prototypes have been left in the headers, their function friends
long gone.
So almost two years ago I've tried to nuke the procfs code already
once before:
http://lists.freedesktop.org/archives/dri-devel/2011-October/015707.html
The conclusion was that userspace drivers (specifically libdrm device
node detection) stopped relying on procfs in 2001. But after some
digging it turned out that the drmstat tool in libdrm is still using
those files (but only when certain options are set). So we've decided
to keep profcs.
But I when I've started to dig around again what exactly this tool
does I've noticed that it tries to read the "mem", "vm", and "vma"
files from procfs. Now as far my git history digging shows "mem" never
did anything useful (at least in the version that first showed up in
upstream history in 2004) and the file was remove in
commit 955b12def42e83287c1bdb1411d99451753c1391
Author: Ben Gamari <bgamari@gmail.com>
Date: Tue Feb 17 20:08:49 2009 -0500
drm: Convert proc files to seq_file and introduce debugfs
Which means that for over 4 years drmstat has been broken, and no one
cared. In my opinion that's proof enough that no one is actually using
drmstat, and so that we can savely nuke the procfs support from drm.
While at it fix up the error case cleanup for debugfs in drm_get_minor.
v2: Fix dates, libdrm stopped relying on procfs for drm node detection
in 2001.
v3: fixup compilation warning for !CONFIG_DEBUG_FS, reported by
Fengguang Wu.
Cc: kbuild test robot <fengguang.wu@intel.com>
Cc: Dave Airlie <airlied@linux.ie>
We might as well have a real ioctl function which checks for the
callbacks. This seems to be a remnant from back in the days when each
drm driver had their own complete ioctl table, with no shared core
drm table at all.
To make really sure no mis-guided user in a kms driver pops up again
explicitly check for that in the new ioctl implementation.
v2: Drop the unused variable I've accidentally left in the code,
spotted by David Herrmann.
Cc: David Herrmann <dh.herrmann@gmail.com>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
The new arch_phys_wc_add/del functions do the right thing both with
and without MTRR support in the kernel. So we can drop these
additional checks.
David Herrmann suggest to also kill the DRIVER_USE_MTRR flag since
it's now unused, which spurred me to do a bit a better audit of the
affected drivers. David helped a lot in that. Quoting our mail
discussion:
On Wed, Jul 10, 2013 at 5:41 PM, David Herrmann <dh.herrmann@gmail.com> wrote:
> On Wed, Jul 10, 2013 at 5:22 PM, Daniel Vetter <daniel.vetter@ffwll.ch> wrote:
>> On Wed, Jul 10, 2013 at 3:51 PM, David Herrmann <dh.herrmann@gmail.com> wrote:
>>>> -#if __OS_HAS_MTRR
>>>> -static inline int drm_core_has_MTRR(struct drm_device *dev)
>>>> - return drm_core_check_feature(dev, DRIVER_USE_MTRR);
>>>> -#else
>>>> -#define drm_core_has_MTRR(dev) (0)
>>>> -#endif
>>> That was the last user of DRIVER_USE_MTRR (apart from drivers setting
>>> it in .driver_features). Any reason to keep it around?
>> Yeah, I guess we could rip things out. Which will also force me to
>> properly audit drivers for the eventual behaviour change this could
>> entail (in case there's an x86 driver which did not ask for an mtrr,
>> but iirc there isn't).
> david@david-mb ~/dev/kernel/linux $ for i in drivers/gpu/drm/* ; do if
> test -d "$i" ; then if ! grep -q USE_MTRR -r $i ; then echo $i ; fi ;
> fi ; done
> drivers/gpu/drm/exynos
> drivers/gpu/drm/gma500
> drivers/gpu/drm/i2c
> drivers/gpu/drm/nouveau
> drivers/gpu/drm/omapdrm
> drivers/gpu/drm/qxl
> drivers/gpu/drm/rcar-du
> drivers/gpu/drm/shmobile
> drivers/gpu/drm/tilcdc
> drivers/gpu/drm/ttm
> drivers/gpu/drm/udl
> drivers/gpu/drm/vmwgfx
> So for x86 gma500,nouveau,qxl,udl,vmwgfx don't set DRIVER_USE_MTRR.
> But I cannot tell whether they break if we call arch_phys_wc_add/del,
> anyway. At least nouveau seemed to work here, but it doesn't use AGP
> or drm_bufs, I guess.
Cool, thanks a lot for stitching together the list of drivers to look
at. So for real KMS drivers it's the drives responsibility to add an
mtrr if it needs one. nouvea, radeon, mgag200, i915 and vmwgfx do that
already. Somehow the savage driver also ends up doing that, I have no
idea why.
Note that gma500 as a pure KMS driver doesn't need MTRR setup since
the platforms that it supports all support PAT. So no MTRRs needed to
get wc iomappings.
The mtrr support in the drm core is all for legacy mappings of garts,
framebuffers and registers. All legacy drivers set the USE_MTRR flag,
so we're good there.
All in all I think we can really just ditch this
/endquote
v2: Also kill DRIVER_USE_MTRR as suggested by David Herrmann
v3: Rebase on top of David Herrmann's agp setup/cleanup changes.
Acked-by: Andy Lutomirski <luto@amacapital.net>
We have three callers of this function now and it's neither
performance critical nor really small. So an inline function feels
like overkill and unecessarily separates the different parts of the
code.
Since all callers of drm_gem_object_handle_free are now in drm_gem.c
we can make that static (and remove the unused EXPORT_SYMBOL). To
avoid a forward declaration move it (and drm_gem_object_free_bug) up a
bit.
Lifetime rules seem to be solid around ->import_attach. So this patch
just properly documents them.
Note that pointing directly at the attachment might have issues for
devices that have multiple struct device *dev parts constituting the
logical gpu and so might need multiple attachment points. Similarly
for drm devices which don't need a dma attachment at all (like udl).
But fixing that up is material for different patches.
Note that this is slightly tricky since both drivers store their
native objects in dma_buf->priv. But both also embed the base
drm_gem_object at the first position, so the implicit cast is ok.
To use the release helper we need to export it, too.
Cc: Intel Graphics Development <intel-gfx@lists.freedesktop.org>
This makes it so that reloading a module does not cause all the
connector ids to change, which are user-visible and sometimes used
for configuration.
Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu>
Basically just extracting some code duplicated in gma500, omapdrm, udl,
and upcoming msm driver.
Signed-off-by: Rob Clark <robdclark@gmail.com>
