fix the following 'make includecheck' warning:
include/drm/drm_memory.h: linux/vmalloc.h is included more than once.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
LKML-Reference: <1247068169.4382.99.camel@ht.satnam>
Acked-by: Dave Airlie <airlied@redhat.com>
Signed-off-by: Michel Dänzer <daenzer@vmware.com>
Userspace can query if acceleration is working or not true get
info ioctl and could fallback to software if for some reason
kernel failed to initialize KMS. This should allow to give a
working KMS setup in all case (even with non functionning accel).
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
Similar to the madvise() concept, the application may wish to mark some
data as volatile. That is in the event of memory pressure the kernel is
free to discard such buffers safe in the knowledge that the application
can recreate them on demand, and is simply using these as a cache.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Fabian Henze <hoacha@quantentunnel.de>
Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com>
Signed-off-by: Eric Anholt <eric@anholt.net>
Fixes a warning seen on powerpc.
Merge remote branch 'anholt/drm-intel-next' of ../anholt-2.6 into drm-next
drivers/gpu/drm/i915/intel_display.c
drivers/gpu/drm/i915/intel_drv.h
drivers/gpu/drm/i915/intel_sdvo.c
Add a function that can be used to add the default mode for the output device
without EDID.
It will add the default mode that meets with the requirements of given
hdisplay/vdisplay limit.
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
For shared tv-out and VGA encoders, we really need to know if
the encoder is just being switched off temporarily in blanking
or if we are really disabling it hard.
Also we need to try harder to disconnect encoders from unused
connectors so we can share more efficently.
(shared encoders stuff is coming in radeon tv-out support)
This adds code to the drm_mm to talk to debugfs, and adds
support to radeon to add the VRAM and GTT mm lists to debugfs.
I tested with spinlock debugging and it doesn't give out.
Initially I always meant this code to be shared, but things
ran away from me before I got to it.
This refactors the i915 and radeon kms fbdev interaction layers
out into generic helpers + driver specific pieces.
It moves all the panic/sysrq enhancements to the core file,
and stores a linked list of kernel fbs. This could possibly be
improved to only store the fb which has fbcon on it for panics
etc.
radeon retains some specific codes used for a big endian
workaround.
changes:
fix oops in v1
fix freeing path for crtc_info
Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org>
- The symbol was already exported.
Signed-off-by: Maarten Maathuis <madman2003@gmail.com>
Several functions in the GEM kernel API used int as handle type, but
user API has it __u32 which is also the intended type.
Replace int with u32.
Signed-off-by: Pekka Paalanen <pq@iki.fi>
This merges the TTM and drm cache flushing into one file in the
drm core.
Needed for occlusion queries on rv530 chips.
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
The previous patch assumes the ioctl already existed, when
it actually didn't.
It also didn't return the correct error code.
linux-next conflict reported needed resolution.
drivers/gpu/drm/drm_crtc.c
drivers/gpu/drm/drm_edid.c
drivers/gpu/drm/radeon/radeon_ttm.c
drivers/gpu/drm/ttm/ttm_bo.c
Common resources, like memory accounting and swap lists should be
global and not per device. Introduce a struct ttm_bo_global to
accomodate this, and register it with sysfs. Add a small sysfs interface
to return the number of active buffer objects.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Signed-off-by: Dave Airlie <airlied@linux.ie>
Use inclusive zones to simplify accounting and its sysfs representation.
Use DMA32 accounting where applicable.
Add a sysfs interface to make the heuristically determined limits
readable and configurable.
Export utility functions for drivers to add specialized devices in the
sysfs drm class subdirectory.
Initially this will be needed form TTM to add a virtual device that
handles power management.
A micro-optimization on the function ttm_kmap_obj_virtual().
By defining the values of enum ttm_bo_kmap_obj::bo_kmap_type to have a
bit indicating iomem, size of the function ttm_kmap_obj_virtual() will be
reduced by 16 bytes on x86_64 (gcc 4.1.2).
ttm_kmap_obj_virtual() may be heavily used, when buffer objects are
accessed via wrappers, that work for both kinds of memory addresses:
iomem cookies and kernel virtual.
Cc: Francisco Jerez <currojerez@riseup.net>
Now that we're using the scaling property in the Intel driver I noticed
that the names were a bit confusing. I've corrected them according to
our discussion on IRC and the mailing list, though I've left out
potential new additions for a new scaling property with an integer (or
two) for the scaling factor. None of the drivers implement that today,
but if someone wants to do it, I think it could be done with the
addition of a single new type and a new property to describe the
scaling factor in the X and Y directions.
Acked-by: Alex Deucher <alexdeucher@gmail.com>
This implements the busy ioctl along with a current domain check.
returns 0 or -EBUSY
puts the current domain no matter what the answer.
Overscan, saturation, hue. Used in the nouveau driver for GPUs with
integrated TV encoders.
Signed-off-by: Francisco Jerez <currojerez@riseup.net>
These are new AMD IGP chips
Namely "brightness", "contrast" and "flicker reduction".
The existing TV connector types are often unsuitable either because
there is no way to probe them until they're actually plugged in or
because they can change during run time (e.g. 7-pin DIN connectors
that behave as S-Video, Component, Composite or SCART depending on the
adaptor plugged in).
Define some helper functions to make easier to detach a KMS encoder
implementation from the drm module of the GPU it's used in. This is
mainly useful for some external I2C encoders known to be present on
cards with GPUs from several different manufacturers.
Add the explanation about DRM debug level in the drmP header file. This is to
explain how/where to use the different DRM debug level.
Two macro definitions of DRM_DEBUG_KMS/MODE can be used to add the debug
info related with KMS. It is confusing.
So remove the macro definition of DRM_DEBUG_MODE. Instead it can be replaced
by the DRM_DEBUG_KMS.
Acked-by: Ian Romanick <ian.d.romanick@intel.com>
We will have to add a prefix when using the macro defintion of DRM_DEBUG_KMS
/DRM_DEBUG_DRIVER/MODE. It is not convenient. We should use the DRM_NAME
as default prefix.
So remove the prefix in the macro definition of DRM_DEBUG_KMS/DRIVER/MODE.
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-radeon-kms' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (35 commits)
drm/radeon: set fb aperture sizes for framebuffer handoff.
drm/ttm: fix highuser vs dma32 confusion.
drm/radeon: Fix size used for benchmarking BO copies.
drm/radeon: Add radeon.test parameter for running BO GPU copy tests.
drm/radeon/kms: allow interruptible waits for objects.
drm/ttm: powerpc: Fix Highmem cache flushing.
x86: Export kmap_atomic_prot() needed for TTM.
drm/ttm: Fix ttm in-kernel copying of pages with non-standard caching attributes.
drm/ttm: Fix an oops and sync object leak.
drm/radeon/kms: vram sizing on certain r100 chips needs workaround.
drm/radeon: Pay more attention to object placement requested by userspace.
drm/radeon: Fall back to evicting BOs with memcpy if necessary.
drm/radeon: Don't unreserve twice on failure to validate.
drm/radeon/kms: fix bandwidth computation on avivo hardware
drm/radeon/kms: add initial colortiling support.
drm/radeon/kms: fix hotspot handling on pre-avivo chips
drm/radeon/kms: enable frac fb divs on rs600/rs690/rs740
drm/radeon/kms: add PLL flag to prefer frequencies <= the target freq
drm/radeon/kms: block RN50 from using 3D engine.
drm/radeon/kms: fix VRAM sizing like DDX does it.
This adds new set/get tiling interfaces where the pitch
and macro/micro tiling enables can be set. Along with
a flag to decide if this object should have a surface when mapped.
The only thing we need to allocate with a mapped surface should be
the frontbuffer. Note rotate scanout shouldn't require one, and
back/depth shouldn't either, though mesa needs some fixes.
It fixes the TTM interfaces along Thomas's suggestions, and I've tested
the surface stealing code with two X servers and not seen any lockdep issues.
I've stopped tiling the fbcon frontbuffer, as I don't see there being
any advantage other than testing, I've left the testing commands in there,
just flip the fb_tiled to true in radeon_fb.c
Open: Can we integrate endian swapping in with this?
Future features:
texture tiling - need to relocate texture registers TXOFFSET* with tiling info.
This also merges Michel's cleanup surfaces regs at init time patch
even though it makes sense on its own, this patch really relies on it.
Some PowerMac firmwares set up a tiling surface at the beginning of VRAM
which messes us up otherwise.
that patch is:
This add support for using dma32 memory on gpus that really need it.
Currently IGPs are left without DMA32 but we might need to change
that unless we can fix rs690.
Add the GTF algorithm in kernel space. And this function can be called to
generate the required modeline.
I copied it from the file of xserver/hw/xfree86/modes/xf86gtf.c. What I have
done is to translate it by using integer calculation. This is to avoid
the float-point calculation in kernel space.
At the same tie I also refer to the function of fb_get_mode in
drivers/video/fbmon.c
Add the CVT algorithm in kernel space. And this function can be called to
I copied it from the file of xserver/hw/xfree86/modes/xf86cvt.c. What I have
[airlied:- cleaned up some bits]
Also, fix ordering for a couple others
Looks like I managed to mess up most shifts when converting from bitfields. :(
The patch below works on my Thinkpad T500 (as well as on my PowerBook,
where the previous change worked as well, maybe out of luck...). I'd
appreciate more testing and eyes looking over it though.
Tested-by: Michael Pyne <mpyne@kde.org>
Mostly replacing bitfields with explicit masks and shifts.
also for the atomic path by using a common code-path.
It hasn't been used in ages, and having the user tell your how much
memory is being freed at free time is a recipe for disaster even if it
was ever used.
* 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/radeon: switch to using late_initcall
radeon legacy chips: tv dac bg/dac adj updates
drm/radeon: introduce kernel modesetting for radeon hardware
drm: Add the TTM GPU memory manager subsystem.
drm: Memory fragmentation from lost alignment blocks
drm/radeon: fix mobility flags on new PCI IDs.
Add kernel modesetting support to radeon driver, use the ttm memory
manager to manage memory and DRM/GEM to provide userspace API.
In order to avoid backward compatibility issue and to allow clean
design and code the radeon kernel modesetting use different code path
than old radeon/drm driver.
When kernel modesetting is enabled the IOCTL of radeon/drm
driver are considered as invalid and an error message is printed
in the log and they return failure.
KMS enabled userspace will use new API to talk with the radeon/drm
driver. The new API provide functions to create/destroy/share/mmap
buffer object which are then managed by the kernel memory manager
(here TTM). In order to submit command to the GPU the userspace
provide a buffer holding the command stream, along this buffer
userspace have to provide a list of buffer object used by the
command stream. The kernel radeon driver will then place buffer
in GPU accessible memory and will update command stream to reflect
the position of the different buffers.
The kernel will also perform security check on command stream
provided by the user, we want to catch and forbid any illegal use
of the GPU such as DMA into random system memory or into memory
not owned by the process supplying the command stream. This part
of the code is still incomplete and this why we propose that patch
as a staging driver addition, future security might forbid current
experimental userspace to run.
This code support the following hardware : R1XX,R2XX,R3XX,R4XX,R5XX
(radeon up to X1950). Works is underway to provide support for R6XX,
R7XX and newer hardware (radeon from HD2XXX to HD4XXX).
Authors:
TTM is a GPU memory manager subsystem designed for use with GPU
devices with various memory types (On-card VRAM, AGP,
PCI apertures etc.). It's essentially a helper library that assists
the DRM driver in creating and managing persistent buffer objects.
TTM manages placement of data and CPU map setup and teardown on
data movement. It can also optionally manage synchronization of
data on a per-buffer-object level.
TTM takes care to provide an always valid virtual user-space address
to a buffer object which makes user-space sub-allocation of
big buffer objects feasible.
TTM uses a fine-grained per buffer-object locking scheme, taking
care to release all relevant locks when waiting for the GPU.
Although this implies some locking overhead, it's probably a big
win for devices with multiple command submission mechanisms, since
the lock contention will be minimal.
TTM can be used with whatever user-space interface the driver
chooses, including GEM. It's used by the upcoming Radeon KMS DRM driver
and is also the GPU memory management core of various new experimental
DRM drivers.
These aren't used that much on r600, but may be needed in the future,
so get them correct now.
