path: root/include/drm
2009-12-11drm/nouveau: Add DRM driver for NVIDIA GPUsBen Skeggs
This adds a drm/kms staging non-API stable driver for GPUs from NVIDIA. This driver is a KMS-based driver and requires a compatible nouveau userspace libdrm and nouveau X.org driver. This driver requires firmware files not available in this kernel tree, interested parties can find them via the nouveau project git archive. This driver is reverse engineered, and is in no way supported by nVidia. Support for nearly the complete range of nvidia hw from nv04->g80 (nv50) is available, and the kms driver should support driving nearly all output types (displayport is under development still) along with supporting suspend/resume. This work is all from the upstream nouveau project found at nouveau.freedesktop.org. The original authors list from nouveau git tree is: Anssi Hannula <anssi.hannula@iki.fi> Ben Skeggs <bskeggs@redhat.com> Francisco Jerez <currojerez@riseup.net> Maarten Maathuis <madman2003@gmail.com> Marcin Kościelnicki <koriakin@0x04.net> Matthew Garrett <mjg@redhat.com> Matt Parnell <mparnell@gmail.com> Patrice Mandin <patmandin@gmail.com> Pekka Paalanen <pq@iki.fi> Xavier Chantry <shiningxc@gmail.com> along with project founder Stephane Marchesin <marchesin@icps.u-strasbg.fr> Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-11drm/ttm: Convert ttm_buffer_object_init to use ttm_placementJerome Glisse
Convert ttm_buffer_object_init to use struct ttm_placement and rename to ttm_bo_init for consistency with function naming. This allow to give more complex placement at buffer creation. For instance you ask to allocate bo into vram first but if there is not enough vram you can give system as a second possible placement. It also allow to create buffer in a specific range. Also rename ttm_buffer_object_validate to ttm_bo_validate. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-10drm: Add memory manager debug functionJerome Glisse
drm_mm_debug_table will print the memory manager state in table allowing to give a snapshot of the manager at given point in time. Usefull for debugging. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-10drm/ttm: Have the TTM code return -ERESTARTSYS instead of -ERESTART.Thomas Hellstrom
Return -ERESTARTSYS instead of -ERESTART when interrupted by a signal. The -ERESTARTSYS is converted to an -EINTR by the kernel signal layer before returned to user-space. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-10drm/ttm: Rework validation & memory space allocation (V3)Jerome Glisse
This change allow driver to pass sorted memory placement, from most prefered placement to least prefered placement. In order to avoid long function prototype a structure is used to gather memory placement informations such as range restriction (if you need a buffer to be in given range). Range restriction is determined by fpfn & lpfn which are the first page and last page number btw which allocation can happen. If those fields are set to 0 ttm will assume buffer can be put anywhere in the address space (thus it avoids putting a burden on the driver to always properly set those fields). This patch also factor few functions like evicting first entry of lru list or getting a memory space. This avoid code duplication. V2: Change API to use placement flags and array instead of packing placement order into a quadword. V3: Make sure we set the appropriate mem.placement flag when validating or allocation memory space. [Pending Thomas Hellstrom further review but okay from preliminary review so far]. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-10drm: Add search/get functions to get a block in a specific rangeJerome Glisse
These are required for changes to TTM. Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-08Merge remote branch 'korg/drm-radeon-dp' into drm-linusDave Airlie
This merges the radeon KMS DisplayPort and hotplug detect support. Tested on RV635 DP card with a Dell 2408 monitor. Conflicts: drivers/gpu/drm/drm_fb_helper.c
2009-12-08Merge remote branch 'anholt/drm-intel-next' into drm-linusDave Airlie
This merges the upstream Intel tree and fixes up numerous conflicts due to patches merged into Linus tree later in -rc cycle. Conflicts: drivers/char/agp/intel-agp.c drivers/gpu/drm/drm_dp_i2c_helper.c drivers/gpu/drm/i915/i915_irq.c drivers/gpu/drm/i915/i915_suspend.c
2009-12-08drm/radeon/kms: add support for DP modesettingAlex Deucher
Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-08drm/radeon/kms: DP fixes and cleanup from the ddxAlex Deucher
- dpcp -> dpcd - fix up dig encoder routing - aux transaction table takes delay in 10 usec units Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-08drm/radeon/kms: initial radeon displayport portingDave Airlie
This is enough to retrieve EDID and DPCP. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-08drm/intel: refactor DP i2c support and DP common header to drm helperDave Airlie
Both radeon and nouveau can re-use this code so move it up a level so they can. However the hw interfaces for aux ch are different enough that the code to translate from mode, address, bytes to actual hw interfaces isn't generic, so move that code into the Intel driver. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-07drm/ttm: Export symbols needed for the vmwgfx driver.Thomas Hellstrom
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-07drm/ttm: Add TTM execbuf utilities.Thomas Hellstrom
Utilities to reserve, unreserve and fence a list of TTM buffer objects in a deadlock-safe manner. Used by the vmwgfx driver. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-07drm/ttm: Add ttm lock functionality.Thomas Hellstrom
This is intended to be used by ttm-aware drivers to 1) Block clients to inactive masters when they try to validate buffers for GPU use. 2) Optionally block clients to the current master when there is thrashing due to GPU memory shortage. Used by the vmwgfx driver. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-07drm/ttm: Add user-space objects.Thomas Hellstrom
Add objects needed for user-space to maintain reference counts on ttm objects. This is used by the vmwgfx driver which allows user-space to maintain map-counts on dma buffers, lock-counts on the ttm lock and ref-counts on gpu surfaces, gpu contexts and dma buffer. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-04drm: Add dirty ioctl and propertyJakob Bornecrantz
This commit adds a ioctl and property to allow userspace to notify the kernel that a framebuffer has changed. Instead of snooping the command stream this allows finer grained tracking of which areas have changed. The primary user for this functionality is virtual hardware like the vmware svga device, but also Xen hardware likes to be notify. There is also real hardware like DisplayLink and DisplayPort that might take advantage of this ioctl. Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-04drm/ttm: Fix build failure due to missing struct pageMartin Michlmayr
drm/ttm fails to build on MIPS because "struct page" is not known: | In file included from drivers/gpu/drm/ttm/ttm_memory.c:28: | include/drm/ttm/ttm_memory.h:154: warning: 'struct page' declared inside parameter list | include/drm/ttm/ttm_memory.h:154: warning: its scope is only this definition or declaration, which is probably not what you want | include/drm/ttm/ttm_memory.h:156: warning: 'struct page' declared inside parameter list | drivers/gpu/drm/ttm/ttm_memory.c:540: error: conflicting types for 'ttm_mem_global_alloc_page' | include/drm/ttm/ttm_memory.h:154: error: previous declaration of 'ttm_mem_global_alloc_page' was here | drivers/gpu/drm/ttm/ttm_memory.c:561: error: conflicting types for 'ttm_mem_global_free_page' | include/drm/ttm/ttm_memory.h:156: error: previous declaration of 'ttm_mem_global_free_page' was here Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Cc: stable@kernel.org Acked-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-04drm: Add compatibility #ifdefs for *BSDKristian Høgsberg
This let's use use the linux drm headers as the canonical source for libdrm on all platforms. Signed-off-by: Kristian Høgsberg <krh@bitplanet.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-04drm: Add support for drm master_[set|drop] callbacks.Thomas Hellstrom
The vmwgfx driver has a per master rw lock around TTM, to guarantee mutual exclusion when needed. This is typically when all evictable buffers are evicted due to 1) vt switch 2) master switch 3) suspend / resume. In the multi-master case, on master switch the new master takes the previously active master lock in write mode, and then evicts all buffers. Any clients to previous masters will then block on that lock when trying to validate a buffer. fbdev also acts as a virtual master wrt this. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Jakob Bornecrantz <jakob@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-04drm/edid: Decode 3-byte CVT codes from EDID 1.4Adam Jackson
Signed-off-by: Adam Jackson <ajax@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-12-04drm/edid: Add new detailed block types from EDID 1.4Adam Jackson
2009-12-04drm/modes: Add drm_mode_hsync()Adam Jackson
2009-12-01drm/i915: Fix typo in ioctl struct name.Kristian Høgsberg
Signed-off-by: Kristian Høgsberg <krh@bitplanet.net> Signed-off-by: Eric Anholt <eric@anholt.net>
2009-12-01drm/i915: Fix sync to vblank when VGA output is turned offLi Peng
In current vblank-wait implementation, if we turn off VGA output, drm_wait_vblank will still wait on the disabled pipe until timeout, because vblank on the pipe is assumed be enabled. This would cause slow system response on some system such as moblin. This patch resolve the issue by adding a drm helper function drm_vblank_off which explicitly clear vblank_enabled[crtc], wake up any waiting queue and save last vblank counter before turning off crtc. It also slightly change drm_vblank_get to ensure that we will will return immediately if trying to wait on a disabled pipe. Signed-off-by: Li Peng <peng.li@intel.com> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> [anholt: hand-applied for conflicts with overlay changes] Signed-off-by: Eric Anholt <eric@anholt.net>
2009-12-01drm/i915: add GETPARAM request for page flippingJesse Barnes
Add a GETPARAM request for checking if page flipping is supported. Useful for the 2D driver to enable the flipping path. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Eric Anholt <eric@anholt.net>
2009-12-01drm: use page flip event to signal flip completionJesse Barnes
We don't actually know which frame number the flip will complete on, so userspace needs a specific flip notification to tell it when the last flip completed. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Eric Anholt <eric@anholt.net> Acked-by: Kristian Høgsberg <krh@bitplanet.net>
2009-12-01Merge remote branch 'airlied/drm-next' into drm-intel-nextEric Anholt
2009-11-25drm/i915: Replace a calloc followed by copying data over it with malloc.Eric Anholt
Execbufs involve quite a bit of payload, to the extent that cache misses show up in the profiles here, and a suspicion that some of those cachelines may get evicted and then reloaded in the subsequent copy. This is still abstracted like drm_calloc_large since we want to check for size overflow, and because we want to choose between kmalloc and vmalloc on the fly. cairo's interface for malloc-with-calloc's-args was used as the model. Signed-off-by: Eric Anholt <eric@anholt.net>
2009-11-19drm: set the type of the drm_framebuffer::fbdev fieldClemens Ladisch
The fbdev field of the drm_framebuffer structure is always used to store a pointer to a fb_info, so there is no reason for it to be void*. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-11-18drm/kms: add page flipping ioctlKristian Høgsberg
This adds a page flipping ioctl to the KMS API. The ioctl takes an fb ID and a ctrc ID and flips the crtc to the given fb at the next vblank. The ioctl returns immediately but the flip doesn't happen until after any rendering that's currently queued up against the new framebuffer is done. After submitting a page flip, any execbuffer involving the old front buffer will block until the flip is completed. Optionally, a vblank event can be generated when the swap eventually happens. Signed-off-by: Kristian Høgsberg <krh@bitplanet.net> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-11-18drm: kill more unused DRM macrosAndres Salomon
There are a few more macros in drmP.h that are unused; DRM_GET_PRIV_SAREA, DRM_ARRAY_SIZE, and DRM_WAITCOUNT can go away completely. Unfortunately, DRM_COPY is still used in one place, but we can at least move it to where it's used. It's an awful looking macro.. [akpm: fix overeagerness] Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-11-18drm: kill some unused DRM_PROC macros from drmP.hAndres Salomon
i915_gem_proc.c appears to have been the last user of the DRM_PROC_* macros, and it has gone away. The macros should die as well. Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-11-18drm: Add async event synchronization for drmWaitVblankKristian Høgsberg
This patch adds a new flag to the drmWaitVblank ioctl, which asks the drm to return immediately and notify userspace when the specified vblank sequence happens by sending an event back on the drm fd. The event mechanism works with the other flags supported by the ioctls, specifically, the vblank sequence can be specified relatively or absolutely, and works for primary and seconday crtc. The signal field of the vblank request is used to provide user data, which will be sent back to user space in the vblank event. Signed-off-by: Kristian Høgsberg <krh@redhat.com> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-11-05Merge remote branch 'airlied/drm-next' into drm-intel-nextEric Anholt
2009-11-05drm/i915: implement drmmode overlay support v4Daniel Vetter
This implements intel overlay support for kms via a device-specific ioctl. Thomas Hellstrom brought up the idea of a general ioctl (on dri-devel). We've reached the conclusion that such an infrastructure only makes sense when multiple kms overlay implementations exists, which atm don't (and it doesn't look like this is gonna change). Open issues: - Runs in sync with the gpu, i.e. unnecessary waiting. I've decided to wait on this because the hw tends to hang when changing something in this area. I left some dummy functions as infrastructure. - polyphase filtering uses a static table. - uses uninterruptible sleeps. Unfortunately the alternatives may unnecessarily wedged the hw if/when we timeout too early (and userspace only overloaded the batch buffers with stuff worth a few secs of gpu time). Changes since v1: - fix off-by-one misconception on my side. This fixes fullscreen playback. Changes since v2: - add underrun detection as spec'ed for i965. - flush caches properly, fixing visual corruptions. Changes since v4: - fix up cache flushing of overlay memory regs. - killed require_pipe_a logic - it hangs the chip. Tested-By: diego.abelenda@gmail.com (on a 865G) Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> [anholt: Resolved against the MADVISE ioctl going in before this one] Signed-off-by: Eric Anholt <eric@anholt.net>
2009-11-05drm/i915: add i915_lp_ring_sync helperDaniel Vetter
This just waits until the hw passed the current ring position with cmd execution. This slightly changes the existing i915_wait_request function to make uninterruptible waiting possible - no point in returning to userspace while mucking around with the overlay, that piece of hw is just too fragile. Also replace a magic 0 with the symbolic constant (and kill the then superflous comment) while I was looking at the code. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Eric Anholt <eric@anholt.net>
2009-11-05drm: make drm_mode_object_find typesafeDaniel Vetter
I've wasted half a day hunting a bug that could easily be spotted by gcc. Prevent this from reoccurring. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Eric Anholt <eric@anholt.net>
2009-10-26drm: Add async event synchronization for drmWaitVblankKristian Høgsberg
2009-10-08Merge branch 'drm-next' of ../drm-next into drm-linusDave Airlie
conflict in radeon since new init path merged with vga arb code. Conflicts: drivers/gpu/drm/radeon/radeon.h drivers/gpu/drm/radeon/radeon_asic.h drivers/gpu/drm/radeon/radeon_device.c
2009-10-06drm/fb: add more correct 8/16/24/32 bpp fb support.Dave Airlie
The previous patches had some unwanted side effects, I've fixed the lack of 32bpp working, and fixed up 16bpp so it should also work. this also adds the interface to allow the driver to set a preferred console depth so for example low memory rn50 can set it to 8bpp. It also catches 24bpp on cards that can't do it and forces 32bpp. Tested on r100/r600/i945. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-10-05drm/fb: add setcmap and fix 8-bit support.Dave Airlie
This adds support for the setcmap api and fixes the 8bpp support at least on radeon hardware. It adds a new load_lut hook which can be called once the color map is setup. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-10-05drm/radeon/kms: respect single crtc cards, only create one crtc. (v2)Dave Airlie
Also add single crtc for RN50 chips. changes in v2: fix vblank init to respect single crtc flag fix r100 mode bandwidth to respect single crtc flag Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-30Merge branch 'drm-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (25 commits) drm/radeon/kms: Convert R520 to new init path and associated cleanup drm/radeon/kms: Convert RV515 to new init path and associated cleanup drm: fix radeon DRM warnings when !CONFIG_DEBUG_FS drm: fix drm_fb_helper warning when !CONFIG_MAGIC_SYSRQ drm/r600: fix memory leak introduced with 64k malloc avoidance fix. drm/kms: make fb helper work for all drivers. drm/radeon/r600: fix offset handling in CS parser drm/radeon/kms/r600: fix forcing pci mode on agp cards drm/radeon/kms: fix for the extra pages copying. drm/radeon/kms/r600: add support for vline relocs drm/radeon/kms: fix some bugs in vline reloc drm/radeon/kms/r600: clamp vram to aperture size drm/kms: protect against fb helper not being created. drm/r600: get values from the passed in IB not the copy. drm: create gitignore file for radeon drm/radeon/kms: remove unneeded master create/destroy functions. drm/kms: start adding command line interface using fb. fb: change rules for global rules match. drm/radeon/kms: don't require up to 64k allocations. (v2) drm/radeon/kms: enable dac load detection by default. ... Trivial conflicts in drivers/gpu/drm/radeon/radeon_asic.h due to adding '->vga_set_state' function pointers.
2009-09-28drm/kms: make fb helper work for all drivers.Dave Airlie
This initialises the fb helper with the connector helper, so that the fb cmdline code works for intel as well. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-25drm/kms: start adding command line interface using fb.Dave Airlie
[note this requires an fb patch posted to linux-fbdev-devel already] This uses the normal video= command line option to control the kms output setup at boot time. It is used to override the autodetection done by kms. video= normally takes a framebuffer as the first parameter, in kms it will take a connector name, DVI-I-1, or LVDS-1 etc. If no output connector is specified the mode string will apply to all connectors. The mode specification used will match down the probed modes, and if no mode is found it will add a CVT mode that matches. video=1024x768 - all connectors match a 1024x768 mode or add a CVT on video=VGA-1:1024x768, VGA-1 connector gets mode only. The same strings as used in current fb modedb.c are used, except I've added three more letters, e, D, d, e = enable, D = enable Digital, d = disable, which allow a connector to be forced into a certain state. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-24Merge branch 'drm-intel-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel * 'drm-intel-next' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel: (57 commits) drm/i915: Handle ERESTARTSYS during page fault drm/i915: Warn before mmaping a purgeable buffer. drm/i915: Track purged state. drm/i915: Remove eviction debug spam drm/i915: Immediately discard any backing storage for uneeded objects drm/i915: Do not mis-classify clean objects as purgeable drm/i915: Whitespace correction for madv drm/i915: BUG_ON page refleak during unbind drm/i915: Search harder for a reusable object drm/i915: Clean up evict from list. drm/i915: Add tracepoints drm/i915: framebuffer compression for GM45+ drm/i915: split display functions by chip type drm/i915: Skip the sanity checks if the current relocation is valid drm/i915: Check that the relocation points to within the target drm/i915: correct FBC update when pipe base update occurs drm/i915: blacklist Acer AspireOne lid status ACPI: make ACPI button funcs no-ops if not built in drm/i915: prevent FIFO calculation overflows on 32 bits with high dotclocks drm/i915: intel_display.c handle latency variable efficiently ... Fix up trivial conflicts in drivers/gpu/drm/i915/{i915_dma.c|i915_drv.h}
2009-09-23drm/i915: Track purged state.Chris Wilson
In order to correctly prevent the invalid reuse of a purged buffer, we need to track such events and warn the user before something bad happens. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2009-09-21Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (133 commits) drm/vgaarb: add VGA arbitration support to the drm and kms. drm/radeon: some r420s have a CP race with the DMA engine. drm/radeon/r600/kms: rv670 is not DCE3 drm/radeon/kms: r420 idle after programming GA_ENHANCE drm/radeon/kms: more fixes to rv770 suspend/resume path. drm/radeon/kms: more alignment for rv770.c with r600.c drm/radeon/kms: rv770 blit init called too late. drm/radeon/kms: move around new init path code to avoid posting at init drm/radeon/r600: fix some issues with suspend/resume. drm/radeon/kms: disable VGA rendering engine before taking over VRAM drm/radeon/kms: Move radeon_get_clock_info() call out of radeon_clocks_init(). drm/radeon/kms: add initial connector properties drm/radeon/kms: Use surfaces for scanout / cursor byte swapping on big endian. drm/radeon/kms: don't fail if we fail to init GPU acceleration drm/r600/kms: fixup number of loops per blit calculation. drm/radeon/kms: reprogram format in set base. drm/radeon: avivo chips have no separate int bit for display drm/radeon/r600: don't do interrupts drm: fix _DRM_GEM addmap error message drm: update crtc x/y when only fb changes ... Fixed up trivial conflicts in firmware/Makefile due to network driver (cxgb3) and drm (mga/r128/radeon) firmware being listed next to each other.
2009-09-21drm/vgaarb: add VGA arbitration support to the drm and kms.Dave Airlie
VGA arb requires DRM support for non-kms drivers, to turn on/off irqs when disabling the mem/io regions. VGA arb requires KMS support for GPUs where we can turn off VGA decoding. Currently we know how to do this for intel and radeon kms drivers, which allows them to be removed from the arbiter. This patch comes from Fedora rawhide kernel. Signed-off-by: Dave Airlie <airlied@redhat.com>
