path: root/include/drm
2009-09-30Merge branch 'drm-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (25 commits) drm/radeon/kms: Convert R520 to new init path and associated cleanup drm/radeon/kms: Convert RV515 to new init path and associated cleanup drm: fix radeon DRM warnings when !CONFIG_DEBUG_FS drm: fix drm_fb_helper warning when !CONFIG_MAGIC_SYSRQ drm/r600: fix memory leak introduced with 64k malloc avoidance fix. drm/kms: make fb helper work for all drivers. drm/radeon/r600: fix offset handling in CS parser drm/radeon/kms/r600: fix forcing pci mode on agp cards drm/radeon/kms: fix for the extra pages copying. drm/radeon/kms/r600: add support for vline relocs drm/radeon/kms: fix some bugs in vline reloc drm/radeon/kms/r600: clamp vram to aperture size drm/kms: protect against fb helper not being created. drm/r600: get values from the passed in IB not the copy. drm: create gitignore file for radeon drm/radeon/kms: remove unneeded master create/destroy functions. drm/kms: start adding command line interface using fb. fb: change rules for global rules match. drm/radeon/kms: don't require up to 64k allocations. (v2) drm/radeon/kms: enable dac load detection by default. ... Trivial conflicts in drivers/gpu/drm/radeon/radeon_asic.h due to adding '->vga_set_state' function pointers.
2009-09-28drm/kms: make fb helper work for all drivers.Dave Airlie
This initialises the fb helper with the connector helper, so that the fb cmdline code works for intel as well. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-25drm/kms: start adding command line interface using fb.Dave Airlie
[note this requires an fb patch posted to linux-fbdev-devel already] This uses the normal video= command line option to control the kms output setup at boot time. It is used to override the autodetection done by kms. video= normally takes a framebuffer as the first parameter, in kms it will take a connector name, DVI-I-1, or LVDS-1 etc. If no output connector is specified the mode string will apply to all connectors. The mode specification used will match down the probed modes, and if no mode is found it will add a CVT mode that matches. video=1024x768 - all connectors match a 1024x768 mode or add a CVT on video=VGA-1:1024x768, VGA-1 connector gets mode only. The same strings as used in current fb modedb.c are used, except I've added three more letters, e, D, d, e = enable, D = enable Digital, d = disable, which allow a connector to be forced into a certain state. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-24Merge branch 'drm-intel-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel * 'drm-intel-next' of git://git.kernel.org/pub/scm/linux/kernel/git/anholt/drm-intel: (57 commits) drm/i915: Handle ERESTARTSYS during page fault drm/i915: Warn before mmaping a purgeable buffer. drm/i915: Track purged state. drm/i915: Remove eviction debug spam drm/i915: Immediately discard any backing storage for uneeded objects drm/i915: Do not mis-classify clean objects as purgeable drm/i915: Whitespace correction for madv drm/i915: BUG_ON page refleak during unbind drm/i915: Search harder for a reusable object drm/i915: Clean up evict from list. drm/i915: Add tracepoints drm/i915: framebuffer compression for GM45+ drm/i915: split display functions by chip type drm/i915: Skip the sanity checks if the current relocation is valid drm/i915: Check that the relocation points to within the target drm/i915: correct FBC update when pipe base update occurs drm/i915: blacklist Acer AspireOne lid status ACPI: make ACPI button funcs no-ops if not built in drm/i915: prevent FIFO calculation overflows on 32 bits with high dotclocks drm/i915: intel_display.c handle latency variable efficiently ... Fix up trivial conflicts in drivers/gpu/drm/i915/{i915_dma.c|i915_drv.h}
2009-09-23drm/i915: Track purged state.Chris Wilson
In order to correctly prevent the invalid reuse of a purged buffer, we need to track such events and warn the user before something bad happens. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
2009-09-21Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (133 commits) drm/vgaarb: add VGA arbitration support to the drm and kms. drm/radeon: some r420s have a CP race with the DMA engine. drm/radeon/r600/kms: rv670 is not DCE3 drm/radeon/kms: r420 idle after programming GA_ENHANCE drm/radeon/kms: more fixes to rv770 suspend/resume path. drm/radeon/kms: more alignment for rv770.c with r600.c drm/radeon/kms: rv770 blit init called too late. drm/radeon/kms: move around new init path code to avoid posting at init drm/radeon/r600: fix some issues with suspend/resume. drm/radeon/kms: disable VGA rendering engine before taking over VRAM drm/radeon/kms: Move radeon_get_clock_info() call out of radeon_clocks_init(). drm/radeon/kms: add initial connector properties drm/radeon/kms: Use surfaces for scanout / cursor byte swapping on big endian. drm/radeon/kms: don't fail if we fail to init GPU acceleration drm/r600/kms: fixup number of loops per blit calculation. drm/radeon/kms: reprogram format in set base. drm/radeon: avivo chips have no separate int bit for display drm/radeon/r600: don't do interrupts drm: fix _DRM_GEM addmap error message drm: update crtc x/y when only fb changes ... Fixed up trivial conflicts in firmware/Makefile due to network driver (cxgb3) and drm (mga/r128/radeon) firmware being listed next to each other.
2009-09-21drm/vgaarb: add VGA arbitration support to the drm and kms.Dave Airlie
VGA arb requires DRM support for non-kms drivers, to turn on/off irqs when disabling the mem/io regions. VGA arb requires KMS support for GPUs where we can turn off VGA decoding. Currently we know how to do this for intel and radeon kms drivers, which allows them to be removed from the arbiter. This patch comes from Fedora rawhide kernel. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-20includecheck fix: include/drm, drm_memory.hJaswinder Singh Rajput
fix the following 'make includecheck' warning: include/drm/drm_memory.h: linux/vmalloc.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> LKML-Reference: <1247068169.4382.99.camel@ht.satnam> Acked-by: Dave Airlie <airlied@redhat.com>
2009-09-18drm/radeon/kms: Use surfaces for scanout / cursor byte swapping on big endian.Michel Dänzer
Signed-off-by: Michel Dänzer <daenzer@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-18drm/radeon/kms: don't fail if we fail to init GPU accelerationJerome Glisse
Userspace can query if acceleration is working or not true get info ioctl and could fallback to software if for some reason kernel failed to initialize KMS. This should allow to give a working KMS setup in all case (even with non functionning accel). Signed-off-by: Jerome Glisse <jglisse@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-17drm/i915: Add ioctl to set 'purgeability' of objectsChris Wilson
Similar to the madvise() concept, the application may wish to mark some data as volatile. That is in the event of memory pressure the kernel is free to discard such buffers safe in the knowledge that the application can recreate them on demand, and is simply using these as a cache. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-08drm/i915: add B43 chipset supportFabian Henze
Signed-off-by: Fabian Henze <hoacha@quantentunnel.de> Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com> Signed-off-by: Eric Anholt <eric@anholt.net>
2009-09-08drm: include seq_file.h for debugfs builds.Dave Airlie
Fixes a warning seen on powerpc. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-07Merge intel drm-intel-next branchDave Airlie
Merge remote branch 'anholt/drm-intel-next' of ../anholt-2.6 into drm-next Conflicts: drivers/gpu/drm/i915/intel_display.c drivers/gpu/drm/i915/intel_drv.h drivers/gpu/drm/i915/intel_sdvo.c
2009-09-07drm/kms: add a function that can add the mode for the output device without EDIDZhao Yakui
Add a function that can be used to add the default mode for the output device without EDID. It will add the default mode that meets with the requirements of given hdisplay/vdisplay limit. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-02drm/kms: add explicit encoder disable function and detach harder.Dave Airlie
For shared tv-out and VGA encoders, we really need to know if the encoder is just being switched off temporarily in blanking or if we are really disabling it hard. Also we need to try harder to disconnect encoders from unused connectors so we can share more efficently. (shared encoders stuff is coming in radeon tv-out support) Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-09-02drm/mm: add ability to dump mm lists via debugfsDave Airlie
This adds code to the drm_mm to talk to debugfs, and adds support to radeon to add the VRAM and GTT mm lists to debugfs. I tested with spinlock debugging and it doesn't give out. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-31drm/kms: move driver specific fb common code to helper functions (v2)Dave Airlie
Initially I always meant this code to be shared, but things ran away from me before I got to it. This refactors the i915 and radeon kms fbdev interaction layers out into generic helpers + driver specific pieces. It moves all the panic/sysrq enhancements to the core file, and stores a linked list of kernel fbs. This could possibly be improved to only store the fb which has fbcon on it for panics etc. radeon retains some specific codes used for a big endian workaround. changes: fix oops in v1 fix freeing path for crtc_info Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-31drm/crtc_helper: place drm_helper_encoder_in_use() in the header fileMaarten Maathuis
- The symbol was already exported. Signed-off-by: Maarten Maathuis <madman2003@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-27drm: GEM handles are u32, not intPekka Paalanen
Several functions in the GEM kernel API used int as handle type, but user API has it __u32 which is also the intended type. Replace int with u32. Signed-off-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-27drm/ttm: consolidate cache flushing code in one place.Dave Airlie
This merges the TTM and drm cache flushing into one file in the drm core. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-21drm/radeon: add GET_PARAM/INFO support for Z pipesAlex Deucher
Needed for occlusion queries on rv530 chips. Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-21drm/radeon/kms: implement the bo busy ioctl properly.Dave Airlie
The previous patch assumes the ioctl already existed, when it actually didn't. It also didn't return the correct error code. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-20Merge Linus master to drm-nextDave Airlie
linux-next conflict reported needed resolution. Conflicts: drivers/gpu/drm/drm_crtc.c drivers/gpu/drm/drm_edid.c drivers/gpu/drm/i915/intel_sdvo.c drivers/gpu/drm/radeon/radeon_ttm.c drivers/gpu/drm/ttm/ttm_bo.c
2009-08-19ttm: Make parts of a struct ttm_bo_device global.Thomas Hellstrom
Common resources, like memory accounting and swap lists should be global and not per device. Introduce a struct ttm_bo_global to accomodate this, and register it with sysfs. Add a small sysfs interface to return the number of active buffer objects. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-08-19drm/ttm: Memory accounting rework.Thomas Hellstrom
Use inclusive zones to simplify accounting and its sysfs representation. Use DMA32 accounting where applicable. Add a sysfs interface to make the heuristically determined limits readable and configurable. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-08-19drm: Enable drm drivers to add drm sysfs devices.Thomas Hellstrom
Export utility functions for drivers to add specialized devices in the sysfs drm class subdirectory. Initially this will be needed form TTM to add a virtual device that handles power management. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-08-19drm/ttm: optimize bo_kmap_type valuesPekka Paalanen
A micro-optimization on the function ttm_kmap_obj_virtual(). By defining the values of enum ttm_bo_kmap_obj::bo_kmap_type to have a bit indicating iomem, size of the function ttm_kmap_obj_virtual() will be reduced by 16 bytes on x86_64 (gcc 4.1.2). ttm_kmap_obj_virtual() may be heavily used, when buffer objects are accessed via wrappers, that work for both kinds of memory addresses: iomem cookies and kernel virtual. Signed-off-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-19drm/kms: no need to return void value (encoder)Pekka Paalanen
Cc: Francisco Jerez <currojerez@riseup.net> Signed-off-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-19drm: clarify scaling property namesJesse Barnes
Now that we're using the scaling property in the Intel driver I noticed that the names were a bit confusing. I've corrected them according to our discussion on IRC and the mailing list, though I've left out potential new additions for a new scaling property with an integer (or two) for the scaling factor. None of the drivers implement that today, but if someone wants to do it, I think it could be done with the addition of a single new type and a new property to describe the scaling factor in the X and Y directions. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-19drm: fixup includes in encoder slave header files.Dave Airlie
2009-08-17drm/radeon/kms: implement bo busy check + current domainDave Airlie
This implements the busy ioctl along with a current domain check. returns 0 or -EBUSY puts the current domain no matter what the answer. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-13drm: Add more standard TV properties.Francisco Jerez
Overscan, saturation, hue. Used in the nouveau driver for GPUs with integrated TV encoders. Signed-off-by: Francisco Jerez <currojerez@riseup.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-05drm/radeon: Add support for RS880 chipsAlex Deucher
These are new AMD IGP chips Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-04drm: Define some new standard TV properties.Francisco Jerez
Namely "brightness", "contrast" and "flicker reduction". Signed-off-by: Francisco Jerez <currojerez@riseup.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-04drm: Define DRM_MODE_SUBCONNECTOR_SCARTFrancisco Jerez
2009-08-04drm: Define DRM_MODE_CONNECTOR_TVFrancisco Jerez
The existing TV connector types are often unsuitable either because there is no way to probe them until they're actually plugged in or because they can change during run time (e.g. 7-pin DIN connectors that behave as S-Video, Component, Composite or SCART depending on the adaptor plugged in). Signed-off-by: Francisco Jerez <currojerez@riseup.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-04drm/kms: slave encoder interface.Francisco Jerez
Define some helper functions to make easier to detach a KMS encoder implementation from the drm module of the GPU it's used in. This is mainly useful for some external I2C encoders known to be present on cards with GPUs from several different manufacturers. Signed-off-by: Francisco Jerez <currojerez@riseup.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-04DRM: Add the explanation about DRM debug levelZhao Yakui
Add the explanation about DRM debug level in the drmP header file. This is to explain how/where to use the different DRM debug level. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-04drm: Remove the macro defintion of DRM_DEBUG_MODEZhao Yakui
Two macro definitions of DRM_DEBUG_KMS/MODE can be used to add the debug info related with KMS. It is confusing. So remove the macro definition of DRM_DEBUG_MODE. Instead it can be replaced by the DRM_DEBUG_KMS. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Acked-by: Ian Romanick <ian.d.romanick@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-04drm: Remove the unused prefix in DRM_DEBUG_KMS/DRIVER/MODEZhao Yakui
We will have to add a prefix when using the macro defintion of DRM_DEBUG_KMS /DRM_DEBUG_DRIVER/MODE. It is not convenient. We should use the DRM_NAME as default prefix. So remove the prefix in the macro definition of DRM_DEBUG_KMS/DRIVER/MODE. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Acked-by: Ian Romanick <ian.d.romanick@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-08-04drm/radeon: add some new r7xx pci idsAlex Deucher
2009-07-29Merge branch 'drm-radeon-kms' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-radeon-kms' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (35 commits) drm/radeon: set fb aperture sizes for framebuffer handoff. drm/ttm: fix highuser vs dma32 confusion. drm/radeon: Fix size used for benchmarking BO copies. drm/radeon: Add radeon.test parameter for running BO GPU copy tests. drm/radeon/kms: allow interruptible waits for objects. drm/ttm: powerpc: Fix Highmem cache flushing. x86: Export kmap_atomic_prot() needed for TTM. drm/ttm: Fix ttm in-kernel copying of pages with non-standard caching attributes. drm/ttm: Fix an oops and sync object leak. drm/radeon/kms: vram sizing on certain r100 chips needs workaround. drm/radeon: Pay more attention to object placement requested by userspace. drm/radeon: Fall back to evicting BOs with memcpy if necessary. drm/radeon: Don't unreserve twice on failure to validate. drm/radeon/kms: fix bandwidth computation on avivo hardware drm/radeon/kms: add initial colortiling support. drm/radeon/kms: fix hotspot handling on pre-avivo chips drm/radeon/kms: enable frac fb divs on rs600/rs690/rs740 drm/radeon/kms: add PLL flag to prefer frequencies <= the target freq drm/radeon/kms: block RN50 from using 3D engine. drm/radeon/kms: fix VRAM sizing like DDX does it. ...
2009-07-29drm/radeon/kms: add initial colortiling support.Dave Airlie
This adds new set/get tiling interfaces where the pitch and macro/micro tiling enables can be set. Along with a flag to decide if this object should have a surface when mapped. The only thing we need to allocate with a mapped surface should be the frontbuffer. Note rotate scanout shouldn't require one, and back/depth shouldn't either, though mesa needs some fixes. It fixes the TTM interfaces along Thomas's suggestions, and I've tested the surface stealing code with two X servers and not seen any lockdep issues. I've stopped tiling the fbcon frontbuffer, as I don't see there being any advantage other than testing, I've left the testing commands in there, just flip the fb_tiled to true in radeon_fb.c Open: Can we integrate endian swapping in with this? Future features: texture tiling - need to relocate texture registers TXOFFSET* with tiling info. This also merges Michel's cleanup surfaces regs at init time patch even though it makes sense on its own, this patch really relies on it. Some PowerMac firmwares set up a tiling surface at the beginning of VRAM which messes us up otherwise. that patch is: Signed-off-by: Michel Dänzer <daenzer@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-07-15drm/ttm/radeon: add dma32 support.Dave Airlie
This add support for using dma32 memory on gpus that really need it. Currently IGPs are left without DMA32 but we might need to change that unless we can fix rs690. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-07-15ttm: Make messages more readable.Thomas Hellstrom
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-07-15drm/mode: add the GTF algorithm in kernel spaceZhao Yakui
Add the GTF algorithm in kernel space. And this function can be called to generate the required modeline. I copied it from the file of xserver/hw/xfree86/modes/xf86gtf.c. What I have done is to translate it by using integer calculation. This is to avoid the float-point calculation in kernel space. At the same tie I also refer to the function of fb_get_mode in drivers/video/fbmon.c Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-07-15drm/mode: add the CVT algorithm in kernel spaceZhao Yakui
Add the CVT algorithm in kernel space. And this function can be called to generate the required modeline. I copied it from the file of xserver/hw/xfree86/modes/xf86cvt.c. What I have done is to translate it by using integer calculation. This is to avoid the float-point calculation in kernel space. [airlied:- cleaned up some bits] Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-07-15drm/radeon: add some missing pci idsAlex Deucher
Also, fix ordering for a couple others Signed-off-by: Alex Deucher <alexdeucher@gmail.com> Signed-off-by: Dave Airlie <airlied@linux.ie>
2009-06-24drm: Fix shifts which were miscalculated when converting from bitfields.Michel Dänzer
Looks like I managed to mess up most shifts when converting from bitfields. :( The patch below works on my Thinkpad T500 (as well as on my PowerBook, where the previous change worked as well, maybe out of luck...). I'd appreciate more testing and eyes looking over it though. Signed-off-by: Michel Dänzer <daenzer@vmware.com> Tested-by: Michael Pyne <mpyne@kde.org> Signed-off-by: Dave Airlie <airlied@linux.ie>
