path: root/include/drm
2014-06-10Merge branch 'drm-next-3.16' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-next Some additional patches for radeon for 3.16 now that -fixes has been merged. - Gart fix for all asics r6xx+ - Add some VM tuning parameters - misc fixes * 'drm-next-3.16' of git://people.freedesktop.org/~agd5f/linux: drm/radeon: Move fb update from radeon_flip_work_func to radeon_crtc_page_flip drm/radeon/dpm: powertune updates for SI Revert "drm/radeon: use variable UVD clocks" drm/radeon: add query for number of active CUs drm/radeon: add debugfs file to trigger GPU reset drm/radeon: make vm_block_size a module parameter drm/radeon: make VM size a module parameter (v2) drm/radeon: rename alt_domain to allowed_domains drm/radeon: use the SDMA on for buffer moves on CIK again drm/radeon: remove range check from *_gart_set_page drm/radeon: stop poisoning the GART TLB drm/radeon: hdmi deep color modes must obey clock limit of sink. drm/edid: Store all supported hdmi deep color modes in drm_display_info drm/radeon: add missing vce init case for hawaii drm/radeon: use lower_32_bits where appropriate
2014-06-09drm/edid: Store all supported hdmi deep color modes in drm_display_infoMario Kleiner
HDMI deep color setup must know which modes are supported if it needs to degrade gracefully, as only 12 bpc / dc_36 is guaranteed, but 10 bpc / dc_30 is optional. The maximum bpc is not sufficient for this. Signed-off-by: Mario Kleiner <mario.kleiner.de@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-06-10drm: Remove DRM_ARRAY_SIZE() for ARRAY_SIZE()Damien Lespiau
I cannot see a need to provide a DRM_ version of ARRAY_SIZE(), only used in a few places. I suspect its usage has been spread by copy & paste rather than anything else. Let's just remove it for plain ARRAY_SIZE(). Signed-off-by: Damien Lespiau <damien.lespiau@intel.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-06-10Merge tag 'drm/panel/for-3.16-rc1' of ↵Dave Airlie
git://anongit.freedesktop.org/tegra/linux into drm-next drm/panel: Changes for v3.16-rc1 This set of commits contains a couple of fixes to existing panel drivers and support for some new panels. One commit touches the DRM core in that in modifies the MIPI DSI support to hook up the shutdown function so that drivers can provide code that's run on shutdown. This is used by a subsequent commit to make the simple panel driver power off the backlight on shutdown. * tag 'drm/panel/for-3.16-rc1' of git://anongit.freedesktop.org/tegra/linux: drm/panel: simple - Add AUO B133XTN01 panel support drm/panel: simple - Disable panel on shutdown drm/panel: add support for EDT ET057090DHU panel drm/panel: Add support for EDT ETM0700G0DH6 and ET070080DH6 panels drm/panel: ld9040: add power control sequence drm/panel: s6e8aa0: silence array overflow warning drm/dsi: Support device shutdown
2014-06-10Merge tag 'drm/tegra/for-3.16-rc1' of ↵Dave Airlie
git://anongit.freedesktop.org/tegra/linux into drm-next drm/tegra: Changes for v3.16-rc1 The majority of these changes are a slew of cleanups across the board. A more noteworthy change is the addition of drm_dev_set_unique() and the conversion of the Tegra DRM driver to use it. This allows us to get rid of the host1x drm_bus implementation. Other USB and platform drivers can be changed in a similar way. Unfortunately for most PCI devices there is some userspace that relies on the old functionality and cannot be as easily converted. HDMI and hardware cursor support is added for Tegra124. The SOR output gains support for exposing CRCs via debugfs, which can be used for automated testing. Many values that were hardcoded in the SOR/eDP code are now computed at runtime to increase compatibility with more devices. * tag 'drm/tegra/for-3.16-rc1' of git://anongit.freedesktop.org/tegra/linux: (47 commits) drm/tegra: sor - Remove obsolete comment drm/tegra: sor - Enable only the necessary number of lanes drm/tegra: sor - Power on only the necessary lanes drm/tegra: sor - Do not program interlaced mode registers drm/tegra: sor - Do not hardcode link speed drm/tegra: sor - Do not hardcode number of blank symbols drm/tegra: sor - Don't hardcode link parameters drm/tegra: sor - Change power down ordering drm/tegra: sor - Fix copy/paste error drm/tegra: sor - Remove pixel clock rounding drm/tegra: sor - Make debugfs setup consistent drm/tegra: sor - Recursively remove debugfs tree drm/tegra: dp - Mark the connector as hotplug capable drm/tegra: dp - Implement hotplug detection in work queue drm/tegra: Add hardware cursor support drm/tegra: Remove host1x drm_bus implementation drm: Document how to register devices without struct drm_bus drm: Add device registration documentation drm: Introduce drm_dev_set_unique() gpu: host1x: Rename internal functions for clarity ...
2014-06-06Merge tag 'drm-intel-fixes-2014-06-06' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next > Bunch of stuff for 3.16 still: > - Mipi dsi panel support for byt. Finally! From Shobhit&others. I've > squeezed this in since it's a regression compared to vbios and we've > been ridiculed about it a bit too often ... > - connection_mutex deadlock fix in get_connector (only affects i915). > - Core patches from Matt's primary plane from Matt Roper, I've pushed the > i915 stuff to 3.17. > - vlv power well sequencing fixes from Jesse. > - Fix for cursor size changes from Chris. > - agpbusy fixes from Ville. > - A few smaller things. > * tag 'drm-intel-fixes-2014-06-06' of git://anongit.freedesktop.org/drm-intel: (32 commits) drm/i915: BDW: Adding missing cursor offsets. drm: Fix getconnector connection_mutex locking drm/i915/bdw: Only use 2g GGTT for 32b platforms drm/i915: Nuke pipe A quirk on i830M drm/i915: fix display power sw state reporting drm/i915: Always apply cursor width changes drm/i915: tell the user if both KMS and UMS are disabled drm/plane-helper: Add drm_plane_helper_check_update() (v3) drm: Check CRTC compatibility in setplane drm/i915: use VBT to determine whether to enumerate the VGA port drm/i915: Don't WARN about ring idle bit on gen2 drm/i915: Silence the WARN if the user tries to GTT mmap an incoherent object drm/i915: Move the C3 LP write bit setup to gen3_init_clock_gating() for KMS drm/i915: Enable interrupt-based AGPBUSY# enable on 85x drm/i915: Flip the sense of AGPBUSY_DIS bit drm/i915: Set AGPBUSY# bit in init_clock_gating drm/i915/vlv: add pll assertion when disabling DPIO common well drm/i915/vlv: move DPIO common reset de-assert into __vlv_set_power_well drm/i915/vlv: re-order power wells so DPIO common comes after TX drm/i915/vlv: move CRI refclk enable into __vlv_set_power_well ...
2014-06-05drm: Introduce drm_dev_set_unique()Thierry Reding
Add a helper function that allows drivers to statically set the unique name of the device. This will allow platform and USB drivers to get rid of their DRM bus implementations and directly use drm_dev_alloc() and drm_dev_register(). Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-06-05drm/dsi: Support device shutdownThierry Reding
Hook up the MIPI DSI bus's .shutdown() function to allow drivers to implement code that should be run when a device is shut down. Signed-off-by: Thierry Reding <treding@nvidia.com>
2014-06-05Merge commit '9e9a928eed8796a0a1aaed7e0b676db86ba84594' into drm-nextDave Airlie
Merge drm-fixes into drm-next. Both i915 and radeon need this done for later patches. Conflicts: drivers/gpu/drm/drm_crtc_helper.c drivers/gpu/drm/i915/i915_drv.h drivers/gpu/drm/i915/i915_gem.c drivers/gpu/drm/i915/i915_gem_execbuffer.c drivers/gpu/drm/i915/i915_gem_gtt.c
2014-06-05drm/plane-helper: Add drm_plane_helper_check_update() (v3)Matt Roper
Pull the parameter checking from drm_primary_helper_update() out into its own function; drivers that provide their own setplane() implementations rather than using the helper may still want to share this parameter checking logic. A few of the checks here were also updated based on suggestions by Ville Syrjälä. v3: - s/primary_helper/plane_helper/ --- this checking logic may be useful for other types of planes as well. - Fix visibility check (need to dereference visibility pointer) v2: - Pass src/dest/clip rects and min/max scaling down to helper to avoid duplication of effort between helper and drivers (suggested by Ville). - Allow caller to specify whether the primary plane should be updatable while the crtc is disabled. Cc: dri-devel@lists.freedesktop.org Reviewed-by: Chon Ming Lee <chon.ming.lee@intel.com> Signed-off-by: Matt Roper <matthew.d.roper@intel.com> Acked-by: Dave Airlie <airlied@gmail.com> [danvet: Include header properly and fixup declaration mismatch to make this compile.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-06-05drm: add drm_fb_helper_restore_fbdev_mode_unlocked()Rob Clark
All drm_fb_helper_restore_fbdev_mode() call sites, save one, do the same locking. Simplify this into drm_fb_helper_restore_fbdev_mode_unlocked(). Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-06-05drm: convert crtc and connection_mutex to ww_mutex (v5)Rob Clark
For atomic, it will be quite necessary to not need to care so much about locking order. And 'state' gives us a convenient place to stash a ww_ctx for any sort of update that needs to grab multiple crtc locks. Because we will want to eventually make locking even more fine grained (giving locks to planes, connectors, etc), split out drm_modeset_lock and drm_modeset_acquire_ctx to track acquired locks. Atomic will use this to keep track of which locks have been acquired in a transaction. v1: original v2: remove a few things not needed until atomic, for now v3: update for v3 of connection_mutex patch.. v4: squash in docbook v5: doc tweaks/fixes Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-06-05drm/dp: add a hw mutex around the transfer functions. (v2)Dave Airlie
This should avoid races between connector probing and HPD irqs in the future, currently mode_config.mutex blocks this possibility. Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-06-04Merge tag 'topic/core-stuff-2014-06-02' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next Just flushing out my pile of random drm patches for the merge window, nothing big. And it all hung around in drm-intel trees for a while (only just rebased now). * tag 'topic/core-stuff-2014-06-02' of git://anongit.freedesktop.org/drm-intel: imx-drm: imx-tve: remove unused variable drm: Missed clflushopt in drm_clflush_virt_range drm/plane: Fix a couple of checkpatch warnings drm/plane: Fix sparse warnings drm/exynos: Fix double locks at PM resume drm/ast: Fix double lock at PM resume drm/dp-helper: Deprecate old i2c-over-dp_aux heleprs
2014-06-04Merge branch 'exynos-drm-next' of ↵Dave Airlie
git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into drm-next Summary: - Resolve probe order and deferred probe issue with component framework support. - Resolve hdmi dt broken issue. . HDMI DT support, which was broken since CCF (common clock framework) support, and considring legacy dt binding. - Consolidate HDMI part. . APB based phy support for Exynos5420 and later, and fixups related to power on/off sequence. - Consolidate IPP part. . Mostly bug fixups and code cleanups. - Trivial fixups and code cleanups. * 'exynos-drm-next' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos: (64 commits) drm/exynos: consider deferred probe case drm/exynos: remove unnecessary exynos_hdmi.h file drm/exynos/fimd: allow multiplatform configuration drm/exynos: add hdmiphy power on/off sequence drm/exynos: ipp: remove description of non-existing field drm/exynos: ipp: update comment for struct drm_ipp_buf_info drm/exynos: ipp: rearrange c_node->event_lock using routine drm/exynos: ipp: rearrange c_node->mem_lock using routines drm/exynos: ipp: add ipp_remove_id() drm/exynos: ipp: add cmd_lock for cmd_list drm/exynos: ipp: rename cmd_lock to lock drm/exynos: ipp: remove duplicated setting drm/exynos: ipp: remove usless list_empty() functions drm/exynos: Use PTR_ERR_OR_ZERO in exynos_dp_core.c drm/exynos: remove hardware overlays disable from fimd probe drm/exynos: Fix checkpatch warning in exynos_dp_reg.c drm/exynos: add fimd dependency to fimd related encoders drm/exynos: remove redundant mutex_unlock drm/exynos/fimc: simplify and rename fimc_dst_get_buf_seq drm/exynos/fimc: replace mutex by spinlock ...
2014-06-04drm: Split connection_mutex out of mode_config.mutex (v3)Daniel Vetter
After the split-out of crtc locks from the big mode_config.mutex there's still two major areas it protects: - Various connector probe states, like connector->status, EDID properties, probed mode lists and similar information. - The links from connector->encoder and encoder->crtc and other modeset-relevant connector state (e.g. properties which control the panel fitter). The later is used by modeset operations. But they don't really care about the former since it's allowed to e.g. enable a disconnected VGA output or with a mode not in the probed list. Thus far this hasn't been a problem, but for the atomic modeset conversion Rob Clark needs to convert all modeset relevant locks into w/w locks. This is required because the order of acquisition is determined by how userspace supplies the atomic modeset data. This has run into troubles in the detect path since the i915 load detect code needs _both_ protections offered by the mode_config.mutex: It updates probe state and it needs to change the modeset configuration to enable the temporary load detect pipe. The big deal here is that for the probe/detect users of this lock a plain mutex fits best, but for atomic modesets we really want a w/w mutex. To fix this lets split out a new connection_mutex lock for the modeset relevant parts. For simplicity I've decided to only add one additional lock for all connector/encoder links and modeset configuration states. We have piles of different modeset objects in addition to those (like bridges or panels), so adding per-object locks would be much more effort. Also, we're guaranteed (at least for now) to do a full modeset if we need to acquire this lock. Which means that fine-grained locking is fairly irrelevant compared to the amount of time the full modeset will take. I've done a full audit, and there's just a few things that justify special focus: - Locking in drm_sysfs.c is almost completely absent. We should sprinkle mode_config.connection_mutex over this file a bit, but since it already lacks mode_config.mutex this patch wont make the situation any worse. This is material for a follow-up patch. - omap has a omap_framebuffer_flush function which walks the connector->encoder->crtc links and is called from many contexts. Some look like they don't acquire mode_config.mutex, so this is already racy. Again fixing this is material for a separate patch. - The radeon hot_plug function to retrain DP links looks at connector->dpms. Currently this happens without any locking, so is already racy. I think radeon_hotplug_work_func should gain mutex_lock/unlock calls for the mode_config.connection_mutex. - Same applies to i915's intel_dp_hot_plug. But again, this is already racy. - i915 load_detect code needs to acquire this lock. Which means the w/w dance due to Rob's work will be nicely contained to _just_ this function. I've added fixme comments everywhere where it looks suspicious but in the sysfs code. After a quick irc discussion with Dave Airlie it sounds like the lack of locking in there is due to sysfs cleanup fun at module unload. v1: original (only compile tested) v2: missing mutex_init(), etc (from Rob Clark) v3: i915 needs more care in the conversion: - Protect the edp pp logic with the connection_mutex. - Use connection_mutex in the backlight code due to get_pipe_from_connector. - Use drm_modeset_lock_all in suspend/resume paths. - Update lock checks in the overlay code. Cc: Alex Deucher <alexdeucher@gmail.com> Cc: Rob Clark <robdclark@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Rob Clark <robdclark@gmail.com>
2014-06-04drm: add signed-range property typeRob Clark
Like range, but values are signed. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
2014-06-04drm: add object property typeRob Clark
An object property is an id (idr) for a drm mode object. This will allow a property to be used set/get a framebuffer, CRTC, etc. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-06-04drm: add extended property typesRob Clark
If we continue to use bitmask for type, we will quickly run out of room to add new types. Split this up so existing part of bitmask range continues to function as before, but reserve a chunk of the remaining space for an integer type-id. Wrap this all up in some type-check helpers to keep the backwards-compat uglyness contained. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-06-04drm: helpers to find mode objectsRob Clark
Add a few more useful helpers to find mode objects. Signed-off-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-06-04drm: drop drm_get_connector_name() and drm_get_encoder_name()Jani Nikula
No longer used or needed as the structs have a name field. Acked-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-06-03Merge branch 'drm-next-3.16' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-next Highlights: - GPUVM opimtizations - HDMI audio cleanups - Deep color HDMI support - more bug fixes, cleanups * 'drm-next-3.16' of git://people.freedesktop.org/~agd5f/linux: (29 commits) drm/edid: Add quirk for Sony PVM-2541A to get 12 bpc hdmi deep color. drm/edid: Parse and handle HDMI deep color modes. drm/radeon: Limit hdmi deep color bit depth to 12 bpc. drm/radeon: Setup HDMI_CONTROL for hdmi deep color gcp's (v2) drm/radeon: fix pll setup for hdmi deep color (v7) drm/radeon: use hw cts/n values for deep color drm/radeon: only apply hdmi bpc pll flags when encoder mode is hdmi drm/radeon/atom: fix dithering on certain panels drm/radeon: optimize CIK VM handling v2 drm/radeon: optimize SI VM handling drm/radeon: add define for flags used in R600+ GTT drm/radeon: rework page flip handling v3 drm/radeon: separate vblank and pflip crtc handling drm/radeon: split page flip and pending callback drm/radeon: remove drm_vblank_get|put from pflip handling drm/radeon: remove (pre|post)_page_flip callbacks drm/radeon/dp: fix lane/clock setup for dp 1.2 capable devices drm/radeon: fix typo in radeon_connector_is_dp12_capable() radeon: Remove useless quirk for zx1/FireGL X1 combo introduced with fdo #7770 vgaswitcheroo: switch the mux to the igp on power down when runpm is enabled ...
2014-06-02drm/edid: Parse and handle HDMI deep color modes.Mario Kleiner
Check the HDMI cea block for deep color mode bits. If available, assign the highest supported bpc for a hdmi display, corresponding to the given deep color modes. Signed-off-by: Mario Kleiner <mario.kleiner.de@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2014-06-02Merge tag 'drm-intel-next-2014-05-23' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next - prep refactoring for execlists (Oscar Mateo) - corner-case fixes for runtime pm (Imre) - tons of vblank improvements from Ville - prep work for atomic plane/sprite updates (Ville) - more chv code, now almost complete (tons of different people) - refactoring and improvements for drm_irq.c merged through drm-intel-next - g4x/ilk reset improvements (Ville) - removal of encoder->mode_set - moved audio state tracking into pipe_config - shuffled fb pinning out of the platform crtc modeset callbacks into core code - userptr support (Chris) - OOM handling improvements from Chris, with now have a neat oom notifier which jumps additional debug information. - topdown allocation of ppgtt PDEs (Ben) - fixes and small improvements all over * tag 'drm-intel-next-2014-05-23' of git://anongit.freedesktop.org/drm-intel: (187 commits) drm/i915: Kill private_default_ctx off drm/i915: s/i915_hw_context/intel_context drm/i915: Split the ringbuffers from the rings (3/3) drm/i915: Split the ringbuffers from the rings (2/3) drm/i915: Split the ringbuffers from the rings (1/3) drm/i915: s/intel_ring_buffer/intel_engine_cs drm/i915: disable GT power saving early during system suspend drm/i915: fix possible RPM ref leaking during RPS disabling drm/i915: remove user GTT mappings early during runtime suspend drm/i915: Implement WaVcpClkGateDisableForMediaReset:ctg, elk drm/i915: Fix gen2 and hsw+ scanline counter drm/i915: Draw a picture about video timings drm/i915: Improve gen3/4 frame counter drm/i915: Add a small adjustment to the pixel counter on interlaced modes drm/i915: Hold CRTC lock whilst freezing the planes drm/i915: Only discard backing storage on releasing the last ref drm/i915: Wait for pending page flips before enabling/disabling the primary plane drm/i915: grab the audio power domain when enabling audio on HSW+ drm/i915: don't read HSW_AUD_PIN_ELD_CP_VLD when the power well is off drm/i915: move bsd dispatch index somewhere better ...
2014-06-02drm/plane: Fix sparse warningsThierry Reding
Include the drm_plane_helper.h header file to fix the following sparse warnings: CHECK drivers/gpu/drm/drm_plane_helper.c drivers/gpu/drm/drm_plane_helper.c:102:5: warning: symbol 'drm_primary_helper_update' was not declared. Should it be static? drivers/gpu/drm/drm_plane_helper.c:219:5: warning: symbol 'drm_primary_helper_disable' was not declared. Should it be static? drivers/gpu/drm/drm_plane_helper.c:233:6: warning: symbol 'drm_primary_helper_destroy' was not declared. Should it be static? drivers/gpu/drm/drm_plane_helper.c:241:30: warning: symbol 'drm_primary_helper_funcs' was not declared. Should it be static? drivers/gpu/drm/drm_plane_helper.c:259:18: warning: symbol 'drm_primary_helper_create_plane' was not declared. Should it be static? Doing that makes gcc complain as follows: CC drivers/gpu/drm/drm_plane_helper.o drivers/gpu/drm/drm_plane_helper.c:260:19: error: conflicting types for 'drm_primary_helper_create_plane' struct drm_plane *drm_primary_helper_create_plane(struct drm_device *dev, ^ In file included from drivers/gpu/drm/drm_plane_helper.c:29:0: include/drm/drm_plane_helper.h:42:19: note: previous declaration of 'drm_primary_helper_create_plane' was here struct drm_plane *drm_primary_helper_create_plane(struct drm_device *dev, ^ drivers/gpu/drm/drm_plane_helper.c: In function 'drm_primary_helper_create_plane': drivers/gpu/drm/drm_plane_helper.c:274:11: warning: assignment discards 'const' qualifier from pointer target type formats = safe_modeset_formats; ^ In file included from include/linux/linkage.h:6:0, from include/linux/kernel.h:6, from include/drm/drmP.h:45, from drivers/gpu/drm/drm_plane_helper.c:27: drivers/gpu/drm/drm_plane_helper.c: At top level: drivers/gpu/drm/drm_plane_helper.c:289:15: error: conflicting types for 'drm_primary_helper_create_plane' EXPORT_SYMBOL(drm_primary_helper_create_plane); ^ include/linux/export.h:57:21: note: in definition of macro '__EXPORT_SYMBOL' extern typeof(sym) sym; \ ^ drivers/gpu/drm/drm_plane_helper.c:289:1: note: in expansion of macro 'EXPORT_SYMBOL' EXPORT_SYMBOL(drm_primary_helper_create_plane); ^ In file included from drivers/gpu/drm/drm_plane_helper.c:29:0: include/drm/drm_plane_helper.h:42:19: note: previous declaration of 'drm_primary_helper_create_plane' was here struct drm_plane *drm_primary_helper_create_plane(struct drm_device *dev, ^ Which can easily be fixed by making the signatures of the implementation and the prototype match. Signed-off-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Matt Roper <matthew.d.roper@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-06-02drm/exynos: dp: Use DPCD defines of drm_dp_helper.hJingoo Han
Use DPCD defines of drm_dp_helper.h; thus, duplicated DPCD defines of exynos_dp_core.h can be removed. Also, DP_TEST_EDID_CHECKSUM define is added to drm_dp_helper.h. There is no functional change. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Inki Dae <inki.dae@samsung.com>
2014-05-30drm: store encoder name in encoder structJani Nikula
This makes drm_get_encoder_name() thread safe. Reference: http://lkml.kernel.org/r/645ee6e22cad47d38a2b35c21c8d5fe3@DC1-MBX-01\ .ptsecurity.ru Signed-off-by: Jani Nikula <jani.nikula@intel.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-05-30drm: store connector name in connector struct (v2)Jani Nikula
This makes drm_get_connector_name() thread safe. [airlied: fix to build.] Reference: http://lkml.kernel.org/r/645ee6e22cad47d38a2b35c21c8d5fe3@DC1-MBX-01.ptsecurity.ru Signed-off-by: Jani Nikula <jani.nikula@intel.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-05-27drm/dp: Add missing kernel-docThierry Reding
Commit 9dc4056026e0 (drm/dp: let drivers specify the name of the I2C- over-AUX adapter) introduced a new field but didn't add the proper kernel-doc for it. Signed-off-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-05-26drm/ttm: fix kerneldoc of ttm_bo_createAlexandre Courbot
The kerneldoc header of ttm_bo_create() was referring to another (nonexisting) function and had a few obsolete or incorrect arguments. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-05-23drm/dp_helper: add defines for DP 1.2 and MST support. (v2)Dave Airlie
This just adds the defines from the DP 1.2 spec, which we will use later. fix some DP MST to 1.2 MST Signed-off-by: Dave Airlie <airlied@redhat.com> Reviewed-by: Todd Previte <tprevite@gmail.com> Reviewed-by: Jingoo Han <jg1.han@samsung.com>
2014-05-21Merge branch 'topic/drm-vblank-rework' into drm-intel-next-queuedDaniel Vetter
Pull in the drm vblank rework from Ville and me. drm core parts acked by Dave Airlie Conflicts: drivers/gpu/drm/i915/intel_display.c Just a bit of fun around the placement of drm_vblank_on. This merge resolution has been tested in drm-intel-nightly for a while already. Acked-by: Dave Airlie <airlied@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-05-21drm/irq: Add kms-native crtc interface functionsDaniel Vetter
We need to start somewhere ... With this the only places left in i915 where we use pipe integers is in the interrupt handling code. And there it actually makes some amount of sense. v2: - Polish kerneldoc a bit (Thierry). - Drop "dev" parameter since it's unecessary. - Split out i915 changes (Thierry). Cc: Thierry Reding <thierry.reding@gmail.com> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-05-20drm: Add drm_vblank_on()Ville Syrjälä
drm_vblank_off() will turn off vblank interrupts, but as long as the refcount is elevated drm_vblank_get() will not re-enable them. This is a problem is someone is holding a vblank reference while a modeset is happening, and the driver requires vblank interrupt to work during that time. Add drm_vblank_on() as a counterpart to drm_vblank_off() which will re-enabled vblank interrupts if the refcount is already elevated. This will allow drivers to choose the specific places in the modeset sequence at which vblank interrupts get disabled and enabled. Testcase: igt/kms_flip/*-vs-suspend Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> [danvet: Add Testcase tag for the igt I've written.] Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-05-20drm: Make the vblank disable timer per-crtcVille Syrjälä
Currently there's one per-device vblank disable timer, and it gets reset wheneven the vblank refcount for any crtc drops to zero. That means that one crtc could accidentally be keeping the vblank interrupts for other crtcs enabled even if there are no users for them. Make the disable timer per-crtc to avoid this issue. Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-05-19Merge tag 'drm-intel-next-2014-05-06' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next - ring init improvements (Chris) - vebox2 support (Zhao Yakui) - more prep work for runtime pm on Baytrail (Imre) - eDram support for BDW (Ben) - prep work for userptr support (Chris) - first parts of the encoder->mode_set callback removal (Daniel) - 64b reloc fixes (Ben) - first part of atomic plane updates (Ville) * tag 'drm-intel-next-2014-05-06' of git://anongit.freedesktop.org/drm-intel: (75 commits) drm/i915: Remove useless checks from primary enable/disable drm/i915: Merge LP1+ watermarks in safer way drm/i915: Make sure computed watermarks never overflow the registers drm/i915: Add pipe update trace points drm/i915: Perform primary enable/disable atomically with sprite updates drm/i915: Make sprite updates atomic drm/i915: Support 64b relocations drm/i915: Support 64b execbuf drm/i915/sdvo: Remove ->mode_set callback drm/i915/crt: Remove ->mode_set callback drm/i915/tv: Remove ->mode_set callback drm/i915/tv: Rip out pipe-disabling nonsense from ->mode_set drm/i915/tv: De-magic device check drm/i915/tv: extract set_color_conversion drm/i915/tv: extract set_tv_mode_timings drm/i915/dvo: Remove ->mode_set callback drm/i915: Make encoder->mode_set callbacks optional drm/i915: Make primary_enabled match the actual hardware state drm/i915: Move ring_begin to signal() drm/i915: Virtualize the ringbuffer signal func ...
2014-05-16Merge tag 'topic/core-stuff-2014-05-05' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next Update pull request with drm core patches. Mostly some polish for the primary plane stuff and a pile of patches all over from Thierry. Has survived a few days in drm-intel-nightly without causing ill. I've frobbed my scripts a bit to also tag my topic branches so that you have something stable to pull - I've accidentally pushed a bunch more patches onto this branch before you've taken the old pull request. * tag 'topic/core-stuff-2014-05-05' of git://anongit.freedesktop.org/drm-intel: drm: Make drm_crtc_helper_disable() return void drm: Fix indentation of closing brace drm/dp: Fix typo in comment drm: Fixup flip-work kerneldoc drm/fb: Fix typos drm/edid: Cleanup kerneldoc drm/edid: Drop revision argument for drm_mode_std() drm: Try to acquire modeset lock on panic or sysrq drm: remove unused argument from drm_open_helper drm: Handle ->disable_plane failures correctly drm: Simplify fb refcounting rules around ->update_plane drm/crtc-helper: gc usless connector loop in disable_unused_functions drm/plane_helper: don't disable plane in destroy function drm/plane-helper: Fix primary plane scaling check drm: make mode_valid callback optional drm/edid: Fill PAR in AVI infoframe based on CEA mode list
2014-05-16drm: fix memory leak around mode_group (v2)Dave Airlie
This mode group id_list was never being freed. v2: take David's suggestion to free in minor_free. Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-05-12srm/i915/chv: Add Cherryview PCI IDsVille Syrjälä
v2: Update to also fill in the new num_pipes field. v3: Rebase on top of the pciid extraction. v4: Switch from info->has*ring to info->ring mask. Also add VEBOX support whiel at it. v5: s/CHV_PCI_IDS/CHV_IDS/, and drop the trailing '\' Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-05-07Merge branch 'mullins' of git://people.freedesktop.org/~deathsimple/linux ↵Dave Airlie
into drm-fixes Add Mullins chips support. * 'mullins' of git://people.freedesktop.org/~deathsimple/linux: drm/radeon: add pci ids for Mullins drm/radeon: add Mullins VCE support drm/radeon: modesetting updates for Mullins. drm/radeon: dpm updates for KV/KB drm/radeon: add Mullins dpm support. drm/radeon: add Mullins UVD support. drm/radeon: update cik init for Mullins. drm/radeon: add Mullins chip family
2014-05-06drm/radeon: add pci ids for MullinsSamuel Li
Signed-off-by: Samuel Li <samuel.li@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Christian König <christian.koenig@amd.com>
2014-05-05drm/i915: Split the BDW device definition to prepare for dual BSD rings on ↵Zhao Yakui
BDW GT3 Based on the hardware spec, the BDW GT3 has the different configuration with the BDW GT1/GT2. So split the BDW device info definition. This is to do the preparation for adding the Dual BSD rings on BDW GT3 machine. V1->V2: Follow Daniel's comment to pay attention to the stolen check for BDW in kernel/early-quirks.c Reviewed-by: Imre Deak <imre.deak@intel.com> Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-05-01Merge branch 'drm-init-cleanup' of git://people.freedesktop.org/~danvet/drm ↵Dave Airlie
into drm-next Next pull request, this time more of the drm de-midlayering work. The big thing is that his patch series here removes everything from drm_bus except the set_busid callback. Thierry has a few more patches on top of this to make that one optional to. With that we can ditch all the non-pci drm_bus implementations, which Thierry has already done for the fake tegra host1x drm_bus. Reviewed by Thierry, Laurent and David and now also survived some testing on my intel boxes to make sure the irq fumble is fixed correctly ;-) The last minute rebase was just to add the r-b tags from Thierry for the 2 patches I've redone. * 'drm-init-cleanup' of git://people.freedesktop.org/~danvet/drm: drm/<drivers>: don't set driver->dev_priv_size to 0 drm: Remove dev->kdriver drm: remove drm_bus->get_name drm: rip out dev->devname drm: inline drm_pci_set_unique drm: remove bus->get_irq implementations drm: pass the irq explicitly to drm_irq_install drm/irq: Look up the pci irq directly in the drm_control ioctl drm/irq: track the irq installed in drm_irq_install in dev->irq drm: rename dev->count_lock to dev->buf_lock drm: Rip out totally bogus vga_switcheroo->can_switch locking drm: kill drm_bus->bus_type drm: remove drm_dev_to_irq from drivers drm/irq: remove cargo-culted locking from irq_install/uninstall drm/irq: drm_control is a legacy ioctl, so pci devices only drm/pci: fold in irq_by_busid support drm/irq: simplify irq checks in drm_wait_vblank
2014-05-01drm: try harder to avoid regression when merging mode bitsDave Airlie
For QXL hw we really want the bits to be replaced as we change the preferred mode on the fly, and the same goes for virgl when I get to it, however the original fix for this seems to have caused a wierd regression on Intel G33 that in a stunning display of failure at opposition to his normal self, Daniel failed to diagnose. So we are left doing this, ugly ugly ugly ugly, Daniel you fixed that G33 yet?, ugly, ugly. Tested-by: Marc-André Lureau <marcandre.lureau@redhat.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2014-05-01Merge tag 'drm-intel-next-2014-04-16' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next drm-intel-next-2014-04-16: - vlv infoframe fixes from Jesse - dsi/mipi fixes from Shobhit - gen8 pageflip fixes for LRI/SRM from Damien - cmd parser fixes from Brad Volkin - some prep patches for CHV, DRRS, ... - and tons of little things all over drm-intel-next-2014-04-04: - cmd parser for gen7 but only in enforcing and not yet granting mode - the batch copying stuff is still missing. Also performance is a bit ... rough (Brad Volkin + OACONTROL fix from Ken). - deprecate UMS harder (i.e. CONFIG_BROKEN) - interrupt rework from Paulo Zanoni - runtime PM support for bdw and snb, again from Paulo - a pile of refactorings from various people all over the place to prep for new stuff (irq reworks, power domain polish, ...) drm-intel-next-2014-04-04: - cmd parser for gen7 but only in enforcing and not yet granting mode - the batch copying stuff is still missing. Also performance is a bit ... rough (Brad Volkin + OACONTROL fix from Ken). - deprecate UMS harder (i.e. CONFIG_BROKEN) - interrupt rework from Paulo Zanoni - runtime PM support for bdw and snb, again from Paulo - a pile of refactorings from various people all over the place to prep for new stuff (irq reworks, power domain polish, ...) Conflicts: drivers/gpu/drm/i915/i915_gem_context.c
2014-04-30drm/i915: don't try DP_LINK_BW_5_4 on HSW ULXPaulo Zanoni
Because the docs say ULX doesn't support it on HSW. Reviewed-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Jani Nikula <jani.nikula@intel.com>
2014-04-29drm: Fixup flip-work kerneldocThierry Reding
Describe the fifo parameter. It seems like kerneldoc doesn't properly handle fields defined using a macro, so it will end up complaining about this anyway and not generate the documentation for it either. At least the kerneldoc is now complete. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-04-23drm: Remove dev->kdriverDaniel Vetter
With the last patch to ditch the ->get_name callbacks the last user is now gone. Reviewed-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-04-23drm: remove drm_bus->get_nameDaniel Vetter
The only user is the info debugfs file, so we only need something human readable. Now for both pci and platform devices we've used the name of the underlying device driver, which matches the name of the drm driver in all cases. So we can just use that instead. The exception is usb, which used a generic "USB". Not to harmful with just one usb driver, but better to use "udl", too. With that converted we can rip out all the ->get_name implementations. Reviewed-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2014-04-23drm: rip out dev->devnameDaniel Vetter
This was only ever used to pretty-print the irq driver name. And on kms systems due to set_version bonghits we never set up the prettier name, ever. Which make this a bit pointless. Also, we can always dig out the driver-instance/irq relationship through other means, so this isn't that useful. So just rip it out to simplify the set_version/set_busid insanity a bit. Also delete the temporary busname from drm_pci_set_busid, it's now unused. v2: Rebase on top of the new host1x drm_bus for tegra. Reviewed-by: Thierry Reding <treding@nvidia.com> Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
