commit 55a5fcafe3a94e8a0777bb993d09107d362258d2 upstream.
Just add binding for a fixed-factor clock axisel_d4, which would be
referenced by PWM devices on MT7623 or MT2701 SoC.
Cc: stable@vger.kernel.org
Fixes: 1de9b21633d6 ("clk: mediatek: Add dt-bindings for MT2701 clocks")
Signed-off-by: Sean Wang <sean.wang@mediatek.com>
Reviewed-by: Rob Herring <robh@kernel.org>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: devicetree@vger.kernel.org
Signed-off-by: Stephen Boyd <sboyd@kernel.org>
commit 1764f8081f1524bf629e0744b277db751281ff56 upstream.
Add the missing module clock for the second channel of the display unit.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
[ Upstream commit d97556c8012015901a3ce77f46960078139cd79d ]
We need to also have OFFPULLUDENABLE bit set to use the off mode pull values.
Otherwise the line is pulled down internally if no external pull exists.
This is has some documentation at:
http://processors.wiki.ti.com/index.php/Optimizing_OMAP35x_and_AM/DM37x_OFF_mode_PAD_configuration
Note that the value is still glitchy during off mode transitions as documented
in spz319f.pdf "Advisory 1.45". It's best to use external pulls instead of
relying on the internal ones for off mode and even then anything pulled up
will get driven down momentarily on off mode restore for GPIO banks other
than bank1.
[ Upstream commit 5ccb58968bf7f46dbd128df88f71838a5a9750b8 ]
Add missing identifiers for phyclk_mipidphy0_bitclkdiv8_phy and
phyclk_mipidphy0_rxclkesc0_phy clocks. Access to those clocks is needed
to setup initial clock configuration for display subsystem in device tree
in order to avoid dependency on the configuration left by the bootloader.
Acked-by: Krzysztof Kozlowski <krzk@kernel.org>
Acked-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
[ Upstream commit 308d3165d8b2b98d3dc3d97d6662062735daea67 ]
The patches regarding eee-broken-modes was merged before all people
involved could find an agreement on the best way to move forward.
While we agreed on having a DT property to mark particular modes as broken,
the value used for eee-broken-modes mapped the phy register in very direct
way. Because of this, the concern is that it could be used to implement
configuration policies instead of describing a broken HW.
In the end, having a boolean property for each mode seems to be preferred
over one bit field value mapping the register (too) directly.
Cc: Florian Fainelli <f.fainelli@gmail.com>
Signed-off-by: Jerome Brunet <jbrunet@baylibre.com>
[ Upstream commit 1fc31357ad194fb98691f3d122bcd47e59239e83 ]
Tested-by: Yegor Yefremov <yegorslists@googlemail.com>
Tested-by: Andreas Färber <afaerber@suse.de>
commit 68cc085a4daaa32f7138de1e918331c05165a484 upstream.
R8A7794 doesn't have Cortex-A15 CPUs, thus there's no Z clock...
Fixes: 0dce5454d5c2 ("ARM: shmobile: Initial r8a7794 SoC device tree")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal managament updates from Zhang Rui:
- Enhance thermal "userspace" governor to export the reason when a
thermal event is triggered and delivered to user space. From Srinivas
Pandruvada
- Introduce a single TSENS thermal driver for the different versions of
the TSENS IP that exist, on different qcom msm/apq SoCs'. Support for
msm8916, msm8960, msm8974 and msm8996 families is also added. From
Rajendra Nayak
- Introduce hardware-tracked trip points support to the device tree
thermal sensor framework. The framework supports an arbitrary number
of trip points. Whenever the current temperature is changed, the trip
points immediately below and above the current temperature are found,
driver callback is invoked to program the hardware to get notified
when either of the two trip points are triggered. Hardware-tracked
trip points support for rockchip thermal driver is also added at the
same time. From Sascha Hauer, Caesar Wang
- Introduce a new thermal driver, which enables TMU (Thermal Monitor
Unit) on QorIQ platform. From Jia Hongtao
- Introduce a new thermal driver for Maxim MAX77620. From Laxman
Dewangan
- Introduce a new thermal driver for Intel platforms using WhiskeyCove
PMIC. From Bin Gao
- Add mt2701 chip support to MTK thermal driver. From Dawei Chien
- Enhance Tegra thermal driver to enable soctherm node and set
"critical", "hot" trips, for Tegra124, Tegra132, Tegra210. From Wei
Ni
- Add resume support for tango thermal driver. From Marc Gonzalez
- several small fixes and improvements for rockchip, qcom, imx, rcar,
mtk thermal drivers and thermal core code. From Caesar Wang, Keerthy,
Rocky Hao, Wei Yongjun, Peter Robinson, Bui Duc Phuc, Axel Lin, Hugh
Kang
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (48 commits)
thermal: int3403: Process trip change notification
thermal: int340x: New Interface to read trip and notify
thermal: user_space gov: Add additional information in uevent
thermal: Enhance thermal_zone_device_update for events
arm64: tegra: set hot trips for Tegra210
arm64: tegra: set critical trips for Tegra210
arm64: tegra: add soctherm node for Tegra210
arm64: tegra: set hot trips for Tegra132
arm64: tegra: set critical trips for Tegra132
arm64: tegra: use tegra132-soctherm for Tegra132
arm: tegra: set hot trips for Tegra124
arm: tegra: set critical trips for Tegra124
thermal: tegra: add hw-throttle for Tegra132
thermal: tegra: add hw-throttle function
of: Add bindings of hw throttle for Tegra soctherm
thermal: mtk_thermal: Check return value of devm_thermal_zone_of_sensor_register
thermal: Add Mediatek thermal driver for mt2701.
dt-bindings: thermal: Add binding document for Mediatek thermal controller
thermal: max77620: Add thermal driver for reporting junction temp
thermal: max77620: Add DT binding doc for thermal driver
Pull drm updates from Dave Airlie:
"Core:
- Fence destaging work
- DRIVER_LEGACY to split off legacy drm drivers
- drm_mm refactoring
- Splitting drm_crtc.c into chunks and documenting better
- Display info fixes
- rbtree support for prime buffer lookup
- Simple VGA DAC driver
Panel:
- Add Nexus 7 panel
- More simple panels
i915:
- Refactoring GEM naming
- Refactored vma/active tracking
- Lockless request lookups
- Better stolen memory support
- FBC fixes
- SKL watermark fixes
- VGPU improvements
- dma-buf fencing support
- Better DP dongle support
amdgpu:
- Powerplay for Iceland asics
- Improved GPU reset support
- UVD/VEC powergating support for CZ/ST
- Preinitialised VRAM buffer support
- Virtual display support
- Initial SI support
- GTT rework
- PCI shutdown callback support
- HPD IRQ storm fixes
amdkfd:
- bugfixes
tilcdc:
- Atomic modesetting support
mediatek:
- AAL + GAMMA engine support
- Hook up gamma LUT
- Temporal dithering support
imx:
- Pixel clock from devicetree
- drm bridge support for LVDS bridges
- active plane reconfiguration
- VDIC deinterlacer support
- Frame synchronisation unit support
- Color space conversion support
analogix:
- PSR support
- Better panel on/off support
rockchip:
- rk3399 vop/crtc support
- PSR support
vc4:
- Interlaced vblank timing
- 3D rendering CPU overhead reduction
- HDMI output fixes
tda998x:
- HDMI audio ASoC support
sunxi:
- Allwinner A33 support
- better TCON support
msm:
- DT binding cleanups
- Explicit fence-fd support
sti:
- remove sti415/416 support
etnaviv:
- MMUv2 refactoring
- GC3000 support
exynos:
- Refactoring HDMI DCC/PHY
- G2D pm regression fix
- Page fault issues with wait for vblank
There is no nouveau work in this tree, as Ben didn't get a pull
request in, and he was fighting moving to atomic and adding mst
support, so maybe best it waits for a cycle"
* tag 'drm-for-v4.9' of git://people.freedesktop.org/~airlied/linux: (1412 commits)
drm/crtc: constify drm_crtc_index parameter
drm/i915: Fix conflict resolution from backmerge of v4.8-rc8 to drm-next
drm/i915/guc: Unwind GuC workqueue reservation if request construction fails
drm/i915: Reset the breadcrumbs IRQ more carefully
drm/i915: Force relocations via cpu if we run out of idle aperture
drm/i915: Distinguish last emitted request from last submitted request
drm/i915: Allow DP to work w/o EDID
drm/i915: Move long hpd handling into the hotplug work
drm/i915/execlists: Reinitialise context image after GPU hang
drm/i915: Use correct index for backtracking HUNG semaphores
drm/i915: Unalias obj->phys_handle and obj->userptr
drm/i915: Just clear the mmiodebug before a register access
drm/i915/gen9: only add the planes actually affected by ddb changes
drm/i915: Allow PCH DPLL sharing regardless of DPLL_SDVO_HIGH_SPEED
drm/i915/bxt: Fix HDMI DPLL configuration
drm/i915/gen9: fix the watermark res_blocks value
drm/i915/gen9: fix plane_blocks_per_line on watermarks calculations
drm/i915/gen9: minimum scanlines for Y tile is not always 4
drm/i915/gen9: fix the WaWmMemoryReadLatency implementation
drm/i915/kbl: KBL also needs to run the SAGV code
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
- support for interrupt virtualization in the AMD IOMMU driver. These
patches were shared with the KVM tree and are already merged through
that tree.
- generic DT-binding support for the ARM-SMMU driver. With this the
driver now makes use of the generic DMA-API code. This also required
some changes outside of the IOMMU code, but these are acked by the
respective maintainers.
- more cleanups and fixes all over the place.
* tag 'iommu-updates-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (40 commits)
iommu/amd: No need to wait iommu completion if no dte irq entry change
iommu/amd: Free domain id when free a domain of struct dma_ops_domain
iommu/amd: Use standard bitmap operation to set bitmap
iommu/amd: Clean up the cmpxchg64 invocation
iommu/io-pgtable-arm: Check for v7s-incapable systems
iommu/dma: Avoid PCI host bridge windows
iommu/dma: Add support for mapping MSIs
iommu/arm-smmu: Set domain geometry
iommu/arm-smmu: Wire up generic configuration support
Docs: dt: document ARM SMMU generic binding usage
iommu/arm-smmu: Convert to iommu_fwspec
iommu/arm-smmu: Intelligent SMR allocation
iommu/arm-smmu: Add a stream map entry iterator
iommu/arm-smmu: Streamline SMMU data lookups
iommu/arm-smmu: Refactor mmu-masters handling
iommu/arm-smmu: Keep track of S2CR state
iommu/arm-smmu: Consolidate stream map entry state
iommu/arm-smmu: Handle stream IDs more dynamically
iommu/arm-smmu: Set PRIVCFG in stage 1 STEs
iommu/arm-smmu: Support non-PCI devices with SMMUv3
Pull ARM SoC late DT updates from Arnd Bergmann:
"These updates have been kept in a separate branch mostly because they
rely on updates to the respective clk drivers to keep the shared
header files in sync.
- The Renesas r8a7796 (R-Car M3-W) platform gets added, this is an
automotive SoC similar to the ⅹ8a7795 chip we already support, but
the dts changes rely on a clock driver change that has been merged
for v4.9 through the clk tree.
- The Amlogic meson-gxbb (S905) platform gains support for a few
drivers merged through our tree, in particular the network and usb
driver changes are required and included here, and also the clk
tree changes.
- The Allwinner platforms have seen a large-scale change to their clk
drivers and the dts file updates must come after that. This
includes the newly added Nextthing GR8 platform, which is derived
from sun5i/A13.
- Some integrator (arm32) changes rely on clk driver changes.
- A single patch for lpc32xx has no such dependency but wasn't added
until just before the merge window"
* tag 'armsoc-late' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (99 commits)
ARM: dts: lpc32xx: add device node for IRAM on-chip memory
ARM: dts: sun8i: Add accelerometer to polaroid-mid2407pxe03
ARM: dts: sun8i: enable UART1 for iNet D978 Rev2 board
ARM: dts: sun8i: add pinmux for UART1 at PG
dts: sun8i-h3: add I2C0-2 peripherals to H3 SOC
dts: sun8i-h3: add pinmux definitions for I2C0-2
dts: sun8i-h3: associate exposed UARTs on Orange Pi Boards
dts: sun8i-h3: split off RTS/CTS for UART1 in seperate pinmux
dts: sun8i-h3: add pinmux definitions for UART2-3
ARM: dts: sun9i: a80-optimus: Disable EHCI1
ARM: dts: sun9i: cubieboard4: Add AXP806 PMIC device node and regulators
ARM: dts: sun9i: a80-optimus: Add AXP806 PMIC device node and regulators
ARM: dts: sun9i: cubieboard4: Declare AXP809 SW regulator as unused
ARM: dts: sun9i: a80-optimus: Declare AXP809 SW regulator as unused
ARM: dts: sun8i: Add touchscreen node for sun8i-a33-ga10h
ARM: dts: sun8i: Add touchscreen node for sun8i-a23-polaroid-mid2809pxe04
ARM: dts: sun8i: Add touchscreen node for sun8i-a23-polaroid-mid2407pxe03
ARM: dts: sun8i: Add touchscreen node for sun8i-a23-inet86dz
ARM: dts: sun8i: Add touchscreen node for sun8i-a23-gt90h
ARM64: dts: meson-gxbb-vega-s95: Enable USB Nodes
Pull ARM DT updates from Arnd Bergmann:
"These are as usual a very large number of mostly boring updates to
enable devices in existing machines, or to fix minor bugs. Notably, an
ongoing treewide effort to fix warnings caused by an update to the
device tree compiler. These are enabled with "make W=1" at the moment
but can hopefully become the default once all issues have been
addressed.
No new SoC platform is added this time around (Armada 395 and Orion
mv88f5181 are slight variations of existing ones), but a significant
number of new dts files are added, which I list by platform:
- Allwinner: Empire Electronix M712 and iNet d978 Rev2 tablets,
Orange Pi PC Plus, Orange Pi 2, Orange Pi Plus 2E, Orange Pi Lite,
Olimex A33-Olinuxino, and Nano Pi Neo single-board computers
- ARM Realview: all supported machines (ported from board files)
- Broadcom: BCM958525er, BCM958522er, BCM988312hr, BCM958623hr and
BCM958622hr reference boards for Northstar platform, Raspberry Pi
Zero single-board computer
- Marvell EBU: Netgear WNR854T router (ported from board file),
Armada 395 SoC platform and GP board Armada 390 DB development
board
- NXP i.MX: imx7s Warp7 reference board, Gateworks Ventana GW553x
single-board computer, Technologic Systems TS-4900 and Engicam
IMX6UL GEA M6UL computer-on-module, Inverse Path USB armory board
- Qualcomm: LG Nexus 5 Phone
- Renesas: r8a7792/wheat and r7s72100/rskrza1 development boards
- Rockchip: Rockchip RK3288 Fennec reference board, Firefly RK3288
Reload platform
- ST Microelectronics STi: B2260 (96boards) single-board computer
- TI Davinci: OMAP-L138 LCDK Development kit
- TI OMAP: beagleboard-x15 rev B1 single-board computer"
* tag 'armsoc-dt' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (390 commits)
ARM: dts: sony-nsz-gs7: add missing unit name to /memory node
ARM: dts: chromecast: add missing unit name to /memory node
ARM: dts: berlin2q-marvell-dmp: add missing unit name to /memory node
ARM: dts: berlin2: Add missing unit name to /soc node
ARM: dts: berlin2cd: Add missing unit name to /soc node
ARM: dts: berlin2q: Add missing unit name to /soc node
ARM: dts: berlin2: Remove skeleton.dtsi inclusion
ARM: dts: berlin2cd: Remove skeleton.dtsi inclusion
ARM: dts: berlin2q: Remove skeleton.dtsi inclusion
arm: dts: berlin2q: enable all wdt nodes unconditionally
arm: dts: berlin2: enable all wdt nodes unconditionally
ARM: dts: omap5-igep0050.dts: Use tabs for indentation
ARM: dts: Fix igepv5 power button GPIO direction
ARM: dts: am335x-evmsk: Add blue-and-red-wiring -property to lcdc node
ARM: dts: am335x-evmsk: Whitespace cleanup of lcdc related nodes
ARM: dts: am335x-evm: Add blue-and-red-wiring -property to lcdc node
ARM: dts: s3c64xx: Use macros for pinctrl configuration
ARM: dts: s3c2416: Use macros for pinctrl configuration
ARM: dts: s5pv210: Use macros for pinctrl configuration
ARM: dts: s3c64xx: Use common macros for pinctrl configuration
Pull ARM SoC driver updates from Arnd Bergmann:
"Driver updates for ARM SoCs, including a couple of newly added
drivers:
- The Qualcomm external bus interface 2 (EBI2), used in some of their
mobile phone chips for connecting flash memory, LCD displays or
other peripherals
- Secure monitor firmware for Amlogic SoCs, and an NVMEM driver for
the EFUSE based on that firmware interface.
- Perf support for the AppliedMicro X-Gene performance monitor unit
- Reset driver for STMicroelectronics STM32
- Reset driver for SocioNext UniPhier SoCs
Aside from these, there are minor updates to SoC-specific bus,
clocksource, firmware, pinctrl, reset, rtc and pmic drivers"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (50 commits)
bus: qcom-ebi2: depend on HAS_IOMEM
pinctrl: mvebu: orion5x: Generalise mv88f5181l support for 88f5181
clk: mvebu: Add clk support for the orion5x SoC mv88f5181
dt-bindings: EXYNOS: Add Exynos5433 PMU compatible
clocksource: exynos_mct: Add the support for ARM64
perf: xgene: Add APM X-Gene SoC Performance Monitoring Unit driver
Documentation: Add documentation for APM X-Gene SoC PMU DTS binding
MAINTAINERS: Add entry for APM X-Gene SoC PMU driver
bus: qcom: add EBI2 driver
bus: qcom: add EBI2 device tree bindings
rtc: rtc-pm8xxx: Add support for pm8018 rtc
nvmem: amlogic: Add Amlogic Meson EFUSE driver
firmware: Amlogic: Add secure monitor driver
soc: qcom: smd: Reset rx tail rather than tx
memory: atmel-sdramc: fix a possible NULL dereference
reset: hi6220: allow to compile test driver on other architectures
reset: zynq: add driver Kconfig option
reset: sunxi: add driver Kconfig option
reset: stm32: add driver Kconfig option
reset: socfpga: add driver Kconfig option
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"Core framework:
- Add the MFD bindings doc to MAINTAINERS
New drivers:
- X-Powers AC100 Audio CODEC and RTC
- TI LP873x PMIC
- Rockchip RK808 PMIC
- Samsung Exynos Low Power Audio
New device support:
- Add support for STMPE1600 variant to stmpe
- Add support for PM8018 PMIC to pm8921-core
- Add support for AXP806 PMIC in axp20x
- Add support for AXP209 GPIO in axp20x
New functionality:
- Add support for Reset to all STMPE variants
- Add support for MKBP event support to cros_ec
- Add support for USB to intel_soc_pmic_bxtwc
- Add support for IRQs and Power Button to tps65217
Fix-ups:
- Clean-up defunct author emails (da9063, max14577)
- Kconfig fixups (wm8350-i2c, as37220
- Constify (altera-a10sr, sm501)
- Supply PCI IDs (intel-lpss-pci)
- Improve clocking (qcom_rpm)
- Fix IRQ probing (ucb1x00-core)
- Ensure fault log is cleared (da9052)
- Remove NO_IRQ check (ucb1x00-core)
- Supply I2C properties (intel-lpss-acpi, intel-lpss-pci)
- Non standard declaration (tps65217, max8997-irq)
- Remove unused code (lp873x, db8500-prcmu, ab8500-debugfs,
cros_ec_spi)
- Make non-modular (altera-a10sr, intel_msic, smsc-ece1099,
sun6i-prcm, twl-core)
- OF bindings (ac100, stmpe, qcom-pm8xxx, qcom-rpm, rk808, axp20x,
lp873x, exynos5433-lpass, act8945a, aspeed-scu, twl6040, arizona)
Bugfixes:
- Release OF pointer (qcom_rpm)
- Avoid double shifting in suspend/resume (88pm80x)
- Fix 'defined but not used' error (exynos-lpass)
- Fix 'sleeping whilst attomic' (atmel-hlcdc)"
* tag 'mfd-for-linus-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (69 commits)
mfd: arizona: Handle probe deferral for reset GPIO
mfd: arizona: Remove arizona_of_get_named_gpio helper function
mfd: arizona: Add DT options for max_channels_clocked and PDM speaker config
mfd: twl6040: Register child device for twl6040-pdmclk
mfd: cros_ec_spi: Remove unused variable 'request'
mfd: omap-usb-host: Return value is not 'const int'
mfd: ab8500-debugfs: Remove 'weak' function suspend_test_wake_cause_interrupt_is_mine()
mfd: ab8500-debugfs: Remove ab8500_dump_all_banks_to_mem()
mfd: db8500-prcmu: Remove unused *prcmu_set_ddr_opp() calls
mfd: ab8500-debugfs: Prevent initialised field from being over-written
mfd: max8997-irq: 'inline' should be at the beginning of the declaration
mfd: rk808: Fix RK818_IRQ_DISCHG_ILIM initializer
mfd: tps65217: Fix nonstandard declaration
mfd: lp873x: Remove unused mutex lock from struct lp873x
mfd: atmel-hlcdc: Do not sleep in atomic context
mfd: exynos-lpass: Mark PM functions as __maybe_unused
mfd: intel-lpss: Add default I2C device properties for Apollo Lake
mfd: twl-core: Make it explicitly non-modular
mfd: sun6i-prcm: Make it explicitly non-modular
mfd: smsc-ece1099: Make it explicitly non-modular
Pull networking updates from David Miller:
1) BBR TCP congestion control, from Neal Cardwell, Yuchung Cheng and
co. at Google. https://lwn.net/Articles/701165/
2) Do TCP Small Queues for retransmits, from Eric Dumazet.
3) Support collect_md mode for all IPV4 and IPV6 tunnels, from Alexei
Starovoitov.
4) Allow cls_flower to classify packets in ip tunnels, from Amir Vadai.
5) Support DSA tagging in older mv88e6xxx switches, from Andrew Lunn.
6) Support GMAC protocol in iwlwifi mwm, from Ayala Beker.
7) Support ndo_poll_controller in mlx5, from Calvin Owens.
8) Move VRF processing to an output hook and allow l3mdev to be
loopback, from David Ahern.
9) Support SOCK_DESTROY for UDP sockets. Also from David Ahern.
10) Congestion control in RXRPC, from David Howells.
11) Support geneve RX offload in ixgbe, from Emil Tantilov.
12) When hitting pressure for new incoming TCP data SKBs, perform a
partial rathern than a full purge of the OFO queue (which could be
huge). From Eric Dumazet.
13) Convert XFRM state and policy lookups to RCU, from Florian Westphal.
14) Support RX network flow classification to igb, from Gangfeng Huang.
15) Hardware offloading of eBPF in nfp driver, from Jakub Kicinski.
16) New skbmod packet action, from Jamal Hadi Salim.
17) Remove some inefficiencies in snmp proc output, from Jia He.
18) Add FIB notifications to properly propagate route changes to
hardware which is doing forwarding offloading. From Jiri Pirko.
19) New dsa driver for qca8xxx chips, from John Crispin.
20) Implement RFC7559 ipv6 router solicitation backoff, from Maciej
Żenczykowski.
21) Add L3 mode to ipvlan, from Mahesh Bandewar.
22) Support 802.1ad in mlx4, from Moshe Shemesh.
23) Support hardware LRO in mediatek driver, from Nelson Chang.
24) Add TC offloading to mlx5, from Or Gerlitz.
25) Convert various drivers to ethtool ksettings interfaces, from
Philippe Reynes.
26) TX max rate limiting for cxgb4, from Rahul Lakkireddy.
27) NAPI support for ath10k, from Rajkumar Manoharan.
28) Support XDP in mlx5, from Rana Shahout and Saeed Mahameed.
29) UDP replicast support in TIPC, from Richard Alpe.
30) Per-queue statistics for qed driver, from Sudarsana Reddy Kalluru.
31) Support BQL in thunderx driver, from Sunil Goutham.
32) TSO support in alx driver, from Tobias Regnery.
33) Add stream parser engine and use it in kcm.
34) Support async DHCP replies in ipconfig module, from Uwe
Kleine-König.
35) DSA port fast aging for mv88e6xxx driver, from Vivien Didelot.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1715 commits)
mlxsw: switchx2: Fix misuse of hard_header_len
mlxsw: spectrum: Fix misuse of hard_header_len
net/faraday: Stop NCSI device on shutdown
net/ncsi: Introduce ncsi_stop_dev()
net/ncsi: Rework the channel monitoring
net/ncsi: Allow to extend NCSI request properties
net/ncsi: Rework request index allocation
net/ncsi: Don't probe on the reserved channel ID (0x1f)
net/ncsi: Introduce NCSI_RESERVED_CHANNEL
net/ncsi: Avoid unused-value build warning from ia64-linux-gcc
net: Add netdev all_adj_list refcnt propagation to fix panic
net: phy: Add Edge-rate driver for Microsemi PHYs.
vmxnet3: Wake queue from reset work
i40e: avoid NULL pointer dereference and recursive errors on early PCI error
qed: Add RoCE ll2 & GSI support
qed: Add support for memory registeration verbs
qed: Add support for QP verbs
qed: PD,PKEY and CQ verb support
qed: Add support for RoCE hw init
qede: Add qedr framework
Edge-rate:
As system and networking speeds increase, a signal's output transition,
also know as the edge rate or slew rate (V/ns), takes on greater importance
because high-speed signals come with a price. That price is an assortment of
interference problems like ringing on the line, signal overshoot and
undershoot, extended signal settling times, crosstalk noise, transmission
line reflections, false signal detection by the receiving device and
electromagnetic interference (EMI) -- all of which can negate the potential
gains designers are seeking when they try to increase system speeds through
the use of higher performance logic devices. The fact is, faster signaling
edge rates can cause a higher level of electrical noise or other type of
interference that can actually lead to slower line speeds and lower maximum
system frequencies. This parameter allow the board designers to change the
driving strange, and thereby change the EMI behavioral.
Edge-rate parameters (vddmac, edge-slowdown) get from Device Tree.
Tested on Beaglebone Black with VSC 8531 PHY.
Signed-off-by: Raju Lakkaraju <Raju.Lakkaraju@microsemi.com>
Tegra132 use CCROC throttle registers to configure
pulse skiper, set these registers to enable throttle
function for Tegra132.
Signed-off-by: Wei Ni <wni@nvidia.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
The current clock tree only implements the minimal set of differences
between the i.MX6Q and the i.MX6DL, but that doesn't really reflect
reality.
Apply the following fixes to match the RM:
- DL has no GPU3D_SHADER_SEL/PODF, the shader domain is clocked by
GPU3D_CORE
- GPU3D_SHADER_SEL/PODF has been repurposed as GPU2D_CORE_SEL/PODF
- GPU2D_CORE_SEL/PODF has been repurposed as MLB_SEL/PODF
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Add clocks configuration for CSI, FIRI and IEEE1588.
Signed-off-by: Fabien Lahoudere <fabien.lahoudere@collabora.co.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-amlogic into next/late
Pull "Amlogic driver updates for v4.9, 2nd round" from Kevin Hilman:
- media: update IR support for newer SoCs
- firmware: add secure monitor driver
- net: new stmmac glue driver
- usb: udd DWC2 support for meson-gxbb
- clocks: expose more clock IDs for use by DT
- DT binding updates
* tag 'amlogic-drivers-2' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-amlogic: (21 commits)
clk: gxbb: expose i2c clocks
clk: gxbb: expose USB clocks
clk: gxbb: expose spifc clock
clk: gxbb: expose MPLL2 clock for use by DT
Documentation: dt-bindings: Add documentation for the Meson USB2 PHYs
usb: dwc2: add support for Meson8b and GXBB SoCs
net: stmmac: update the module description of the dwmac-meson driver
net: stmmac: add a glue driver for the Amlogic Meson 8b / GXBB DWMAC
stmmac: introduce get_stmmac_bsp_priv() helper
net: dt-bindings: Document the new Meson8b and GXBB DWMAC bindings
clk: meson-gxbb: Export PWM related clocks for DT
meson: clk: Add support for clock gates
gxbb: clk: Adjust MESON_GATE macro to be shared with meson8b
clk: meson: Copy meson8b CLKID defines to private header file
meson: clk: Rename register names according to Amlogic datasheet
meson: clk: Move register definitions to meson8b.h
clk: meson: Rename meson8b-clkc.c to reflect gxbb naming convention
media: rc: meson-ir: Add support for newer versions of the IR decoder
git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux into next/dt
Pull "Topic branch for Samsung DeviceTree cleanup for 4.9" from Krzysztof Kozłowski:
Replace in DT sources hard-coded values for pinctrl configuration like pull
up/down, drive strength and function. This makes the DTS easier to read,
especially that some drive strengths values are quite non-obvious.
* tag 'samsung-dt-pinctrl-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/krzk/linux:
ARM: dts: exynos: Fix mismatched values of SD drive strengh configuration on exynos4415
ARM: dts: exynos: Fix mismatched value for SD4 pull up/down configuration on exynos4210
ARM: dts: exynos: Use macros for pinctrl configuration on exynos542x/exynos5800
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5410
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5260
ARM: dts: exynos: Use macros for pinctrl configuration on exynos5250
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4415
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4x12
ARM: dts: exynos: Use macros for pinctrl configuration on exynos4210
ARM: dts: exynos: Use macros for pinctrl configuration on exynos3250
ARM: dts: exynos: Use common macros for pinctrl configuration
pinctrl: dt-bindings: samsung: Update documentation with new macros
pinctrl: dt-bindings: samsung: Add header with values used for configuration
Adding missing reset lines for USB 3.0 PHY.
Signed-off-by: Vivek Gautam <vivek.gautam@codeaurora.org>
Hard-coded pinctrl configuration values are scattered through DTS files.
The numbers are difficult to decode by human, especially without the
datasheet. Additionally the drive strength differs between S3C64xx,
S5PV210 and Exynos SoC families increasing the confusion.
The header will help making this more readable and maintainable.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
The ZX296718 clocks are statically listed and registered. More
clock will be added later.
Signed-off-by: Jun Nie <jun.nie@linaro.org>
I2C and AO_I2C clocks are needed for the i2c driver, expose to DT
(and comment out in clk driver)
Acked-by: Stephen Boyd <sboyd@codeaurora.org>
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
USB0_DDR_BRIDGE and USB1_DDR_BRIDGE1 are needed for the related
dwc2 usb controller. USB, USB0 and USB1 are needed for the PHYs.
Expose these clocks to DT and comment out in clk driver.
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
SPI clock is needed for the spifc driver, expose to DT
(and comment out in the clk driver)
This exposes the MPLL2 clock as this is one of the input clocks of the
ethernet controller's internal mux.
https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux into clk-next
Pull Allwinner clock driver changes from Maxime Ripard:
Four more SoCs converted to the new clock framework (A31, A31s, A23 and
A33).
* tag 'sunxi-clk-for-4.9' of https://git.kernel.org/pub/scm/linux/kernel/git/mripard/linux:
clk: sunxi-ng: Add hardware dependency
clk: sunxi-ng: Add A23 CCU
clk: sunxi-ng: Add A33 CCU support
clk: sunxi-ng: Add N-class clocks support
clk: sunxi-ng: mux: Add mux table macro
clk: sunxi-ng: div: Allow to set a maximum
clk: sunxi-ng: div: Add kerneldoc for the _ccu_div structure
clk: sunxi-ng: div: Add mux table macros
clk: sunxi-ng: Add A31/A31s clocks
clk: sunxi-ng: mux: Add clk notifier functions
clk: sunxi-ng: mux: support fixed pre-dividers on multiple parents
clk: sunxi-ng: mux: Add support for mux tables
clk: sunxi-ng: mux: Rename mux macro to be consistent
clk: sunxi-ng: nkm: Add mux to support multiple parents
clk: sunxi-ng: mux: Increase fixed pre-divider div size
clk-next
Pull samsung clk driver updates from Sylwester Nawrocki:
In addition to a few clean up and code consolidation patches this
includes:
- addition of sound subsystem related clocks for Exynos5410 SoC
(EPLL, PDMA) and support for "samsung,exynos5410-audss-clock"
compatible in the clk-exynos-audss driver,
- addition of DRAM controller related clocks for exynos5420,
- MAINTAINERS update adding Chanwoo Choi as the Samsung SoC
clock drivers co-maintainer.
* tag 'clk-v4.9-samsung' of git://linuxtv.org/snawrocki/samsung:
clk: samsung: Add support for EPLL on exynos5410
clk: samsung: clk-exynos-audss: Whitespace and debug trace cleanup
clk: samsung: clk-exynos-audss: Add exynos5410 compatible
clk: samsung: clk-exynos-audss: controller variant handling rework
clk: samsung: Use common registration function for pll2550x
clk: samsung: exynos5410: Expose the peripheral DMA gate clocks
clk: samsung: exynos5420: Add clocks for CMU_CDREX domain
clk: samsung: exynos5410: Use samsung_cmu_register_one() to simplify code
clk: samsung: exynos5260: Move struct samsung_cmu_info to init section
MAINTAINERS: Add myself as Samsung SoC clock drivers co-maintainer
clk: samsung: exynos5410: Add clock IDs for PDMA and EPLL clocks
clk: samsung: Add clock IDs for the CMU_CDREX (DRAM Express Controller)
Pull "Amlogic 64-bit DT changes for v4.9" from Kevin Hilman:
- add watchdog, reset, IR remote, PWM
- add secure monitor and eFuse
- add always-on (AO) domain clock and reset
* tag 'amlogic-dt64' of git://git.kernel.org/pub/scm/linux/kernel/git/khilman/linux-amlogic:
ARM64: dts: amlogic: gxbb: Enable NVMEM
documentation: Add nvmem bindings documentation
ARM64: dts: amlogic: gxbb: Enable secure monitor
documentation: Add secure monitor bindings documentation
ARM64: dts: meson-gxbb: Add PWM pinctrl nodes
ARM64: dts: meson-gxbb: Enable the the IR decoder on supported boards
ARM64: dts: meson-gxbb: Add Infrared Remote Controller decoder
dt-bindings: media: meson-ir: Add Meson8b and GXBB compatible strings
ARM64: dts: amlogic: add the input pin for the IR remote
ARM64: dts: meson-gxbb: Add GXBB AO Clock and Reset node
clk: meson: Fix invalid use of sizeof in gxbb_aoclkc_probe()
clk: meson: Add GXBB AO Clock and Reset controller driver
dt-bindings: clock: reset: Add GXBB AO Clock and Reset Bindings
ARM64: DTS: meson-gxbb: switch ethernet to real clock
ARM64: dts: amlogic: meson-gxbb: Add watchdog node
git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into next/dt
Pull "Rockchip dts32 changes for 4.9" from Heiko Stübner:
32bit Rockchip devicetree changes containing two new rk3288 boards (Fennec
and Firefly-reload), display support for the rk3288-evb, support for the
recently added firmware reboot-flag support and some housekeeping cleanups.
* tag 'v4.9-rockchip-dts32-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip:
ARM: dts: rockchip: Add sensor-supplies on PopMetal-RK3288 board
ARM: dts: rockchip: fix L3G4200D i2c address on PopMetal-RK3288 board
ARM: dts: rockchip: enable usbotg for Popemtal-rk3288 board
ARM: dts: rockchip: add missing regulators for firefly reload board
ARM: dts: rockchip: remove excess sd properties from firefly reload
ARM: dts: rockchip: add syscon-reboot-mode DT node
soc: rockchip: add reboot-mode header
ARM: dts: rockchip: move rk3288 usbphy under the GRF node
ARM: dts: rockchip: add rk3288-firefly-reload
ARM: dts: rockchip: add dts for RK3288-Fennec boards
ARM: dts: rockchip: add the panel power supply for rk3288-evb board with rk808 pmu
ARM: dts: rockchip: add the panel power supply for rk3288-evb board with act8846 pmu
ARM: dts: rockchip: add eDP/panel display device nodes for rk3288-evb
into drm-next
This adds the ASoC codec interfaces for TDA998x HDMI audio from
Jyri Sarha.
* 'drm-tda998x-devel' of git://git.armlinux.org.uk/~rmk/linux-arm:
ARM: dts: am335x-boneblack: Add HDMI audio support
drm/i2c: tda998x: Register ASoC hdmi-codec and add audio DT binding
drm/i2c: tda998x: Improve tda998x_configure_audio() audio related pdata
This commit introduces the clocks found in the Allwinner A33 CCU.
Since this SoC is very similar to the A23, and we share a significant share
of the DTSI, the clock IDs that are going to be used will also be shared
with the A23, hence the name of the various header files.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Acked-by: Chen-Yu Tsai <wens@csie.org>
There is no such significant differences in pll2550x PLL type
to justify a separate registration function. This patch adapts
exynos5440 driver to use the common function and removes
samsung_clk_register_pll2550x().
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Chanwoo Choi <cw00.choi@samsung.com>
The PDMA{0,1} and EPLL clock IDs are added separately in this
patch so the patch can be merged to the arm-soc tree as dependency.
This patch adds missing clock IDs for CMU_CDREX (DRAM Express Controller)
which generates clocks for DRAM and NoC (Network on Chip) busses.
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Register ASoC HDMI codec for audio functionality and adds device tree
binding for audio configuration.
With the registered HDMI codec the tda998x node can be used like a
regular codec node in ASoC card configurations. HDMI audio info-frame
and audio stream header is generated by the ASoC HDMI codec. The codec
also applies constraints for available sample-rates based on Edid Like
Data from the display. The device tree binding document has been
updated [1].
Part of this patch has been inspired by Jean Francoise's "drm/i2c: tda998x:
Add support of a DT graph of ports"-patch [2]. There may still be some
identical lines left from the original patch and some of the ideas
have come from there.
[1] Documentation/devicetree/bindings/display/bridge/tda998x.txt
[2] http://mailman.alsa-project.org/pipermail/alsa-devel/2015-July/095255.html
Signed-off-by: Jyri Sarha <jsarha@ti.com>
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into clk-next
Pull rockchip clk driver updates from Heiko Stuebner:
The biggest addition is probably the special clock-type for ddr clock
control. While reading that clock is done the normal way from the
registers, setting it always requires some sort of special handling
to let the system survive this addition.
As the commit message explains, there are currently 3 handling-types
known. General SRAM-based code on rk3288 and before (which is waiting
essentially for the PIE support that is currently being worked on),
SCPI-based clk setting on the rk3368 through a coprocessor, which we
might support once the support for legacy scpi-variants has matured
and now on the rk3399 (and probably later) using a dcf controller that
is controlled from the arm-trusted-firmware and gets accessed through
firmware calls from the kernel. This is the variant we currently
support, but the clock type is made to support the other variants in
the future as well.
Apart from that slightly bigger chunk, we have a mix of PLL rates,
clock-ids and flags mainly for the rk3399.
And interestingly an iomap fix for the legacy gate driver, where I
hopefully could deter the submitter from actually using that in any
new works.
* tag 'v4.9-rockchip-clk1' of git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip:
clk: rockchip: use the dclk_vop_frac clock ids on rk3399
clk: rockchip: drop CLK_SET_RATE_PARENT from rk3399 fractional dividers
clk: rockchip: add 2016M to big cpu clk rate table on rk3399
clk: rockchip: add rk3399 ddr clock support
clk: rockchip: add dclk_vop_frac ids for rk3399 vop
clk: rockchip: add new clock-type for the ddrclk
soc: rockchip: add header for ddr rate SIP interface
clk: rockchip: add SCLK_DDRC id for rk3399 ddrc
clk: rockchip: handle of_iomap failures in legacy clock driver
clk: rockchip: mark rk3399 hdcp_noc and vio_noc as critical
clk: rockchip: use general clock flag when registering pll
clk: rockchip: delete the CLK_IGNORE_UNUSED from aclk_pcie on rk3399
clk: rockchip: add 65MHz and 106.5MHz rates to rk3399 plls used for HDMI
Signed-off-by: Chris Brandt <chris.brandt@renesas.com>
Export the dclk_vop_frac out, so we can set the dclk_vop as the
child of dclk_vop_frac, and then we can start to take use of
the fractional dividers.
Signed-off-by: Yakir Yang <ykk@rock-chips.com>
Signed-off-by: Chris Zhong <zyw@rock-chips.com>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Add the PWM related clocks in order to be referenced as PWM source
clocks.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Signed-off-by: Michael Turquette <mturquette@baylibre.com>
Link: lkml.kernel.org/r/1471870177-10609-1-git-send-email-narmstrong@baylibre.com
Only expose future CLKID constants if necessary. This patch
removes CLK_NR_CLKS from the DT bindings but leaves all previously
defined CLKIDs there to keep backward compatibility.
Signed-off-by: Alexander Müller <serveralex@gmail.com>
Link: lkml.kernel.org/r/1472319654-59048-5-git-send-email-serveralex@gmail.com
Add the needed id for the ddr clock.
Signed-off-by: Lin Huang <hl@rock-chips.com>
In order to support the Qualcomm MDM9615 SoC, add support for the
RPM regulator entries in the qcom-rpm driver.
Acked-by: Bjorn Andersson <bjorn.andersson@linaro.org>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Add a new style driver for the clock control unit in Allwinner A31/A31s.
A few clocks are still missing:
- MIPI PLL's HDMI mode support
- EMAC clock
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Rob Herring <robh@kernel.org>
This patch adds missing 2 PCIE common reset lines.
Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org>
Ths patch lists STM32F4's RCC numeric constants.
It will be used by clock and reset drivers, and DT bindings.
Signed-off-by: Maxime Coquelin <mcoquelin.stm32@gmail.com>
Signed-off-by: Gabriel Fernandez <gabriel.fernandez@st.com>
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
