path: root/include/dt-bindings
2014-11-25Merge tag 'clk-fixes-for-linus' of ↵Linus Torvalds
https://git.linaro.org/people/mike.turquette/linux Pull clock fixes from Mike Turquette: "The fixes for the clock framework are all regressions in drivers, plus a single fix in one of the basic clock templates. No fixes to the core this time around. As with most clock driver fixes these run the gamut from fixing a build warning to fixing wrecked memory timings, with a little USB tossed in for fun" * tag 'clk-fixes-for-linus' of https://git.linaro.org/people/mike.turquette/linux: clk: pxa: fix pxa27x CCCR bit usage clk-divider: Fix READ_ONLY when divider > 1 clk: qcom: Fix duplicate rbcpr clock name clk: at91: usb: fix at91sam9x5 recalc, round and set rate clk: at91: usb: fix at91rm9200 round and set rate
2014-11-17clk: qcom: Fix duplicate rbcpr clock nameGeorgi Djakov
There is a duplication in a clock name for apq8084 platform that causes the following warning: "RBCPR_CLK_SRC" redefined Resolve this by adding a MMSS_ prefix to this clock and making its name coherent with msm8974 platform. Fixes: 2b46cd23a5a2 ("clk: qcom: Add APQ8084 Multimedia Clock Controller (MMCC) support") Signed-off-by: Georgi Djakov <gdjakov@mm-sol.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Michael Turquette <mturquette@linaro.org>
2014-11-16Merge tag 'omap-fixes-against-v3.18-rc4' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap into fixes Merge "omap fixes against v3.18-rc4" from Tony Lindgren: Few omap fixes for hangs and wrong pinctrl defines, and update MAINTAINERS file to avoid missing PMIC and SoC related patches: - Fix random hangs on am437x because of incorrect default value for the DDR regulator - Fix wrong partition name for NAND on am335x-evm - Fix wrong pinctrl defines for dra7xx - Update maintainers entries for PMICs and SoCs * tag 'omap-fixes-against-v3.18-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap: pinctrl: dra: dt-bindings: Fix output pull up/down MAINTAINERS: Update entry for omap related .dts files to cover new SoCs MAINTAINERS: add more files under OMAP SUPPORT ARM: dts: AM437x-SK-EVM: Fix DCDC3 voltage ARM: dts: AM437x-GP-EVM: Fix DCDC3 voltage ARM: dts: AM43x-EPOS-EVM: Fix DCDC3 voltage ARM: dts: am335x-evm: Fix 5th NAND partition's name Signed-off-by: Olof Johansson <olof@lixom.net>
2014-11-10pinctrl: dra: dt-bindings: Fix output pull up/downRoger Quadros
For PIN_OUTPUT_PULLUP and PIN_OUTPUT_PULLDOWN we must not set the PULL_DIS bit which disables the PULLs. PULL_ENA is a 0 and using it in an OR operation is a NOP, so don't use it in the PIN_OUTPUT_PULLUP/DOWN macros. Fixes: 23d9cec07c58 ("pinctrl: dra: dt-bindings: Fix pull enable/disable") Signed-off-by: Roger Quadros <rogerq@ti.com> Acked-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2014-11-04ARM: imx: clk-vf610: define PLL's clock treeimx-fixes-3.18-2Stefan Agner
So far, the required PLL's (PLL1/PLL2/PLL5) have been initialized by boot loader and the kernel code defined fixed rates according to those default configurations. Beginning with the USB PLL7 the code started to initialize the PLL's itself (using imx_clk_pllv3). However, since commit dc4805c2e78ba5a22ea1632f3e3e4ee601a1743b (ARM: imx: remove ENABLE and BYPASS bits from clk-pllv3 driver) imx_clk_pllv3 no longer takes care of the ENABLE and BYPASS bits, hence the USB PLL were not configured correctly anymore. This patch not only fixes those USB PLL's, but also makes use of the imx_clk_pllv3 for all PLL's and alignes the code with the PLL support of the i.MX6 series. Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-10-25ARM: i.MX6: Fix "emi" clock name typoSteve Longerbeam
Fix a typo error, the "emi" names refer to the eim clocks. The change fixes typo in EIM and EIM_SLOW pre-output dividers and selectors clock names. Notably EIM_SLOW clock itself is named correctly. Signed-off-by: Steve Longerbeam <steve_longerbeam@mentor.com> [vladimir_zapolskiy@mentor.com: ported to v3.17] Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Cc: Sascha Hauer <kernel@pengutronix.de> Signed-off-by: Shawn Guo <shawn.guo@linaro.org>
2014-10-15Merge tag 'clk-for-linus-3.18' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clock tree updates from Mike Turquette: "The clk tree changes for 3.18 are dominated by clock drivers. Mostly fixes and enhancements to existing drivers as well as new drivers. This tag contains a bit more arch code than I usually take due to some OMAP2+ changes. Additionally it contains the restart notifier handlers which are merged as a dependency into several trees. The PXA changes are the only messy part. Due to having a stable tree I had to revert one patch and follow up with one more fix near the tip of this tag. Some dead code is introduced but it will soon become live code after 3.18-rc1 is released as the rest of the PXA family is converted over to the common clock framework. Another trend in this tag is that multiple vendors have started to push the complexity of changing their CPU frequency into the clock driver, whereas this used to be done in CPUfreq drivers. Changes to the clk core include a generic gpio-clock type and a clk_set_phase() function added to the top-level clk.h api. Due to some confusion on the fbdev mailing list the kernel boot parameters documentation was updated to further explain the clk_ignore_unused parameter, which is often required by users of the simplefb driver. Finally some fixes to the locking around the clock debugfs stuff was done to prevent deadlocks when interacting with other subsystems." * tag 'clk-for-linus-3.18' of git://git.linaro.org/people/mike.turquette/linux: (99 commits) clk: pxa clocks build system fix Revert "arm: pxa: Transition pxa27x to clk framework" clk: samsung: register restart handlers for s3c2412 and s3c2443 clk: rockchip: add restart handler clk: rockchip: rk3288: i2s_frac adds flag to set parent's rate doc/kernel-parameters.txt: clarify clk_ignore_unused arm: pxa: Transition pxa27x to clk framework dts: add devicetree bindings for pxa27x clocks clk: add pxa27x clock drivers arm: pxa: add clock pll selection bits clk: dts: document pxa clock binding clk: add pxa clocks infrastructure clk: gpio-gate: Ensure gpiod_ APIs are prototyped clk: ti: dra7-atl-clock: Mark the device as pm_runtime_irq_safe clk: ti: LLVMLinux: Move __init outside of type definition clk: ti: consider the fact that of_clk_get() might return an error clk: ti: dra7-atl-clock: fix a memory leak clk: ti: change clock init to use generic of_clk_init clk: hix5hd2: add I2C clocks clk: hix5hd2: add watchdog0 clocks ...
2014-10-15Merge tag 'mfd-for-linus-3.18' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd Pull MFD updates from Lee Jones: "Changes to existing drivers: - DT clean-ups in da9055-core, max14577, rn5t618, arizona, hi6421, stmpe, twl4030 - Export symbols for use in modules in max14577 - Plenty of static code analysis/Coccinelle fixes throughout the SS - Regmap clean-ups in arizona, wm5102, wm5110, da9052, tps65217, rk808 - Remove unused/duplicate code in da9052, 88pm860x, ti_ssp, lpc_sch, arizona - Bug fixes in ti_am335x_tscadc, da9052, ti_am335x_tscadc, rtsx_pcr - IRQ fixups in arizona, stmpe, max14577 - Regulator related changes in axp20x - Pass DMA coherency information from parent => child in MFD core - Rename DT document files for consistency - Add ACPI support to the MFD core - Add Andreas Werner to MAINTAINERS for MEN F21BMC New drivers/supported devices: - New driver for MEN 14F021P00 Board Management Controller - New driver for Ricoh RN5T618 PMIC - New driver for Rockchip RK808 - New driver for HiSilicon Hi6421 PMIC - New driver for Qualcomm SPMI PMICs - Add support for Intel Braswell in lpc_ich - Add support for Intel 9 Series PCH in lpc_ich - Add support for Intel Quark ILB in lpc_sch" [ Delayed to after the poweer/reset pull due to Kconfig problems with recursive Kconfig select/depends-on chains. - Linus ] * tag 'mfd-for-linus-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (79 commits) mfd: cros_ec: wait for completion of commands that return IN_PROGRESS i2c: i2c-cros-ec-tunnel: Set retries to 3 mfd: cros_ec: move locking into cros_ec_cmd_xfer mfd: cros_ec: stop calling ->cmd_xfer() directly mfd: cros_ec: Delay for 50ms when we see EC_CMD_REBOOT_EC MAINTAINERS: Adds Andreas Werner to maintainers list for MEN F21BMC mfd: arizona: Correct mask to allow setting micbias external cap mfd: Add ACPI support Revert "mfd: wm5102: Manually apply register patch" mfd: ti_am335x_tscadc: Update logic in CTRL register for 5-wire TS mfd: dt-bindings: atmel-gpbr: Rename doc file to conform to naming convention mfd: dt-bindings: qcom-pm8xxx: Rename doc file to conform to naming convention mfd: Inherit coherent_dma_mask from parent device mfd: Document DT bindings for Qualcomm SPMI PMICs mfd: Add support for Qualcomm SPMI PMICs mfd: dt-bindings: pm8xxx: Add new compatible string mfd: axp209x: Drop the parent supplies field mfd: twl4030-power: Use 'ti,system-power-controller' as alternative way to support system power off mfd: dt-bindings: twl4030-power: Use the standard property to mark power control mfd: syscon: Add Atmel GPBR DT bindings documention ...
2014-10-10Merge tag 'sound-3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "This time it's a relatively calm update batch, but the amount isn't too small in the end. Here we go over some highlights: ALSA core: - One major change is the support of nonatomic PCM operations. This allows the trigger and other callbacks to call schedule(), which would be useful for mailbox type communications. Already some drivers (Digigram ones) have been converted to use together with threaded irqs as an example. - Improvement / fixes of DSD PCM format support HD-audio: - Large volume of rewrites are found in Realtek codec driver for converting Dell and HP quirks to generic forms. - Inverted dmic code cleanup from David. - Realtek COEF access has been optimized. - Now HD-audio jack infrastructure allows multiple callbacks, which fixes / simplifies the jack-dependent power controls on STAC/IDT and VIA codecs. - Many additional device-specific fixups as usual - A few deadcode cleanups, CA0132 code cleanup, etc. ASoC: - More componentization work from Lars-Peter, this time mainly cleaning up the suspend and bias level transition callbacks. - Real system support for the Intel drivers and a bunch of fixes and enhancements for the associated CODEC drivers, this is going to need a lot quirks over time due to the lack of any firmware description of the boards. - Jack detect support for simple card from Dylan Reid. - A bunch of small fixes and enhancements for the Freescale drivers. - New drivers for Analog Devices SSM4567, Cirrus Logic CS35L32, Everest Semiconductor ES8328 and Freescale cards using the ASRC in newer i.MX processors. - A few simple-card fixes, mostly cleanups but also a fix for interaction between GPIO 0 and simple-card. Misc: - Virtuoso / Oxygen updates by Clemens - USB-audio: Yamaha MOTIF XF MIDI port name fixes - Conversion of kernel messages to standard dev_*() in ctxfi driver" * tag 'sound-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (251 commits) ASoC: mc13783: Ensure we only try to dereference valid of_nodes ASoC: rockchip-i2s: fix infinite loop in rockchip_snd_txctrl ALSA: hda - Add dock port support to Thinkpad L440 (71aa:501e) ALSA: Allow pass NULL dev for snd_pci_quirk_lookup() ASoC: imx-es8328: Fix of_node_put() call with uninitialized object ASoC: soc-pcm: fix sig_bits determination in soc_pcm_apply_msb() ASoC: simple-card: Initialize headphone and mic GPIO numbers ASoC: imx-es8328: Fix missing return code in imx_es8328_probe() ALSA: hda - Add dock support for Thinkpad T440 (17aa:2212) ALSA: usb: caiaq: check for cdev->n_streams > 1 ASoC: 88pm860x-codec: Fix possibly missing string termination ASoC: core: fix use after free in snd_soc_remove_platform() ASoC: soc-dapm: fix use after free ALSA: hda - Make the inv dmic handling for Realtek use generic parser ALSA: hda - Add Inverted Internal mic for Samsung Ativ book 9 (NP900X3G) ALSA: hda - Add inverted internal mic for Asus Aspire 4830T ASoC: Intel: byt-rt5640: fix coccinelle warnings ASoC: fsl_esai doc: Add "fsl,vf610-esai" as compatible string ASoC: da732x: Remove unnecessary KERN_ERR in pr_err() ASoC: simple-card: Fix detect gpio documentation. ...
2014-10-08Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Arnd Bergmann: "As usual, this is the largest branch, though this time a little under half of the total changes with 307 individual non-merge changesets. The largest changes are the addition of new machines, in particular the Tegra based Chromebook, the Renesas r8a7794 SoC, and DT support for the old i.MX1 platform. Other changes include - at91: various sam9 and sama5 updates - exynos: much extended Peach Pi/Pit (Chromebook 2) support - keystone: new peripherals - meson: added DT for meson6 SoC - mvebu: new device support for Armada 370/375 - qcom: improved support for IPQ8064 and MSM8x60 - rockchip: much improved support for rk3288 - shmobile: lots of updates all over the place - sunxi: dts license change - sunxi: more a23 device support - vexpress: CLCD DT description" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (308 commits) ARM: DTS: meson: update DTSI to add watchdog node ARM: dts: keystone-k2l: fix mdio io start address ARM: dts: keystone-k2e: fix mdio io start address ARM: dts: keystone-k2e: update usb1 node for dma properties ARM: dts: keystone: fix io range for usb_phy0 Revert "Merge tag 'hix5hd2-dt-for-3.18' of git://github.com/hisilicon/linux-hisi into next/dt" Revert "ARM: dts: hix5hd2: add wdg node" ARM: dts: add rk3288 i2s controller ARM: vexpress: Add CLCD Device Tree properties ARM: bcm2835: add I2S pinctrl to device tree ARM: meson: documentation: add bindings documentation ARM: meson: dts: add basic Meson/Meson6/Meson6-atv1200 DTSI/DTS ARM: dts: mt6589: Change compatible string for GIC ARM: dts: mediatek: Add compatible property for aquaris5 ARM: dts: mt6589-aquaris5: Add boot argument earlyprintk ARM: dts: mt6589: Fix typo in GIC unit address ARM: dts: Build dtb for Mediatek board ARM: dts: keystone: fix bindings for pcie and usb clock nodes ARM: dts: keystone: k2l: Fix chip selects for SPI devices ARM: dts: keystone: add dsp gpio controllers nodes ...
2014-10-08Merge tag 'soc-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Arnd Bergmann: "New and updated SoC support. Among the things new for this release are: - at91: Added support for the new SAMA5D4 SoC, following the earlier SAMA5D3 - bcm: Added support for BCM63XX family of DSL SoCs - hisi: Added support for HiP04 server-class SoC - meson: Initial support for the Amlogic Meson6 (aka 8726MX) platform - shmobile: added support for new r8a7794 (R-Car E2) automotive SoC Noteworthy changes to existing SoC support are: - imx: convert i.MX1 to device tree - omap: lots of power management work - omap: base support to enable moving to standard UART driver - shmobile: lots of progress for multiplatform support, still ongoing" * tag 'soc-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (171 commits) ARM: hisi: depend on ARCH_MULTI_V7 CNS3xxx: Fix debug UART. ARM: at91: fix nommu build regression ARM: meson: add basic support for MesonX SoCs ARM: meson: debug: add debug UART for earlyprintk support irq: Export handle_fasteoi_irq ARM: mediatek: Add earlyprintk support for mt6589 ARM: hisi: Fix platmcpm compilation when ARMv6 is selected ARM: debug: fix alphanumerical order on debug uarts ARM: at91: document Atmel SMART compatibles ARM: at91: add sama5d4 support to sama5_defconfig ARM: at91: dt: add device tree file for SAMA5D4ek board ARM: at91: dt: add device tree file for SAMA5D4 SoC ARM: at91: SAMA5D4 SoC detection code and low level routines ARM: at91: introduce basic SAMA5D4 support clk: at91: add a driver for the h32mx clock ARM: pxa3xx: provide specific platform_devices for all ssp ports ARM: pxa: ssp: provide platform_device_id for PXA3xx ARM: OMAP4+: Remove static iotable mappings for SRAM ARM: OMAP4+: Move SRAM data to DT ...
2014-10-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull input updates from Dmitry Torokhov: "A few new haptic/button drivers, a rudimentary support for laptops using FocalTech touchpads; xpad driver will bind to more devices, and a few other driver fixes." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: soc_button_array - convert to platform bus Input: palmas-pwrbutton - fix typo in the license string Input: palmas-pwrbutton - use IRQF_ONESHOT Input: psmouse - add support for detecting FocalTech PS/2 touchpads Input: psmouse - add psmouse_matches_pnp_id helper function Input: joystick - use ktime for measuring timing Input: add haptic driver on max77693 Input: introduce palmas-pwrbutton Input: add support for the DRV2667 haptic driver Input: xpad - sync device IDs with xboxdrv Input: xpad - add VID/PID for Razer Sabertooth Input: cros_ec_keyb - optimize ghosting algorithm Input: drv260x - fix binding document Input: drv260x - add check for ERM mode and LRA Libraries Input: drv260x - remove unused defines Input: drv260x - add TI drv260x haptics driver
2014-09-30Merge branch 'clk-pxa27x' into clk-nextMike Turquette
2014-09-30clk: add pxa clocks infrastructureRobert Jarzmik
Add a the common code used by all PXA variants. This is the first step in the transition from architecture defined clocks (in arch/arm/mach-pxa) towards clock framework. The goal is to have the same features (and not all the features) of the existing clocks, and enable the transition of PXA to device-tree. All PXA rely on a "CKEN" type clock, which : - has a gate (bit in CKEN register) - is generated from a PLL, generally divided - has an alternate low power clock Each variant will specialize the CKEN clock : - pxa25x have no low power clock - pxa27x in low power use always the 13 MHz ring oscillator - pxa3xx in low power have specific dividers for each clock The device-tree provides a list of CLK_* (ex: CLK_USB or CLK_I2C) to get a handle on the clock. While pxa-clock.h will describe all the clocks of all the variants, each variant will only use a subset of it. Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-09-29Merge tag 'for_3.18/samsung-clk' of ↵Mike Turquette
git://git.kernel.org/pub/scm/linux/kernel/git/tfiga/samsung-clk into clk-next Samsung clock patches for v3.18 1) non-critical fixes (without the need to push to stable) fa0111be4ff3 clk: samsung: exynos4: remove duplicate div_core2 divider clock instantiation b511593d7165 clk: samsung: exynos4: fix g3d clocks c14254300131 clk: samsung: exynos4: add missing smmu_g2d clock and update comments 22842d244af3 clk: samsung: exynos5260: fix typo in clock name e82ba578ccde clk: samsung: exynos3250: fix width field of mout_mmc0/1 59037b92f440 clk: samsung: exynos3250: fix width and shift of div_spi0_isp clock 5ce37f266650 clk: samsung: exynos3250: fix mout_cam_blk parent list 2) Clock driver extensions 07ccf02ba5c3 dt-bindings: clk: samsung: Document the DMC domain of Exynos3250 CMU d0e73eaf1925 ARM: dts: exynos3250: Add CMU node for DMC domain clocks e3c3f19bc618 clk: samsung: exynos3250: Register DMC clk provider 4676f0aab9dc clk: samsung: exynos4: add support for MOUT_HDMI and MOUT_MIXER clocks
2014-09-28Merge tag 'hix5hd2-clock-for-3.18-v2' of ↵Mike Turquette
git://github.com/hisilicon/linux-hisi into clk-next Hisilicon HiX5HD2 clock updates for 3.18-v2 - Add I2C clocks - Add watchdog clocks - Add sd clocks - Add complex clock implementation to support sata, usb and ethernet
2014-09-28clk: hix5hd2: add I2C clocksWei Yan
hix5hd2 add I2C clocks (I2C0~i2C5) Signed-off-by: Wei Yan <sledge.yanwei@huawei.com> Signed-off-by: Zhangfei Gao <zhangfei.gao@linaro.org> Signed-off-by: Wei Xu <xuwei5@hisilicon.com>
2014-09-28clk: hix5hd2: add watchdog0 clocksGuoxiong Yan
hix5hd2 add watchdog0 clocks Signed-off-by: Guoxiong Yan <yanguoxiong@huawei.com> Signed-off-by: Zhangfei Gao <zhangfei.gao@linaro.org> Signed-off-by: Wei Xu <xuwei5@hisilicon.com>
2014-09-28clk: hix5hd2: add sd clkJiancheng Xue
Signed-off-by: Jiancheng Xue <xuejiancheng@huawei.com> Signed-off-by: Zhangfei Gao <zhangfei.gao@linaro.org> Signed-off-by: Wei Xu <xuwei5@hisilicon.com>
2014-09-28clk: hix5hd2: add complex clkZhangfei Gao
Support clk of sata, usb and ethernet Signed-off-by: Jiancheng Xue <xuejiancheng@huawei.com> Signed-off-by: Zhangfei Gao <zhangfei.gao@linaro.org> Signed-off-by: Wei Xu <xuwei5@hisilicon.com>
2014-09-27Merge tag 'v3.18-rockchip-cpuclk' of ↵Mike Turquette
git://git.kernel.org/pub/scm/linux/kernel/git/mmind/linux-rockchip into clk-next CPU clock handling for Rockchip SoCs
2014-09-27Merge branch 'v3.18-next/armclkid' into v3.18-next/cpuclkHeiko Stuebner
2014-09-27clk: rockchip: add binding id for ARMCLKHeiko Stuebner
Signed-off-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Doug Anderson <dianders@chromium.org>
2014-09-26Merge tag 'tegra-clk-3.18' of ↵Mike Turquette
git://nv-tegra.nvidia.com/user/pdeschrijver/linux into clk-next Tegra clk updates for 3.18
2014-09-26mfd: dt-bindings: Add RK808 device tree bindings documentChris Zhong
Add device tree bindings documentation and a header file for rockchip's RK808 pmic. Signed-off-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Chris Zhong <zyw@rock-chips.com> Signed-off-by: Zhang Qing <zhangqing@rock-chips.com> Tested-by: Heiko <heiko@sntech.de> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-09-25Merge branch 'clk-next-rockchip' into clk-nextMike Turquette
2014-09-25clk: rockchip: add some needed clock binding id for rk3288Kever Yang
This patch add some clock binding id for different modules that under development and going to send upstream. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-09-25clk: rockchip: rk3288: add reset indices for SOFTRST9-11Mark yao
The patch add the rest of the indices of the additional reset registers from the updated TRM. Signed-off-by: Mark yao <mark.yao@rock-chips.com> Reviewed-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-09-24Merge tag 'imx-dt-3.18' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/dt Merge "ARM: imx: device tree changes for 3.18" from Shawn Guo: The i.MX device tree changes for 3.18: - Device tree support for i.MX ADS and Armadeus APF9328 boards - Enable thermal sensor support for i.MX6SL - Add LCD support for i.MX6SL EVK board - Fix display duplicate name for a bunch of board dts files - Configure imx6qdl-sabresd board pins locally to remove the dependency on bootloader - A set of imx28-tx28 board dts updates from Lothar - Add pci config space as platform resource - Enable devices RTC, I2C and HDMI for nitrogen6x board - Split HummingBoard DT to support s/dl and d/q - mSATA and IR input support for HummingBoard - Add SSI baud clock for i.MX6 device trees - Add USB support for vf610-colibri and vf610-twr boards - A set of cleanup and updates on Gateworks boards * tag 'imx-dt-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (86 commits) ARM: dts: imx6: make gpt per clock can be from OSC ARM: dts: imx: ventana: add canbus support for GW52xx ARM: dts: imx: ventana: cleanup pinctrl groups ARM: dts: imx: ventana: configure padconf for all pins ARM: dts: imx: ventana: use gpio constants ARM: dts: imx: ventana: remove unused aliases ARM: dts: imx: ventana: remove unsupported dt nodes ARM: dts: imx28-tx28: add alias for CAN XCVR regulator ARM: dts: imx28-tx28: add spi-gpio as alternative for spi-mxs ARM: dts: imx28-tx28: use GPIO flags ARM: dts: imx28-tx28: remove spidev labels and add third instance of spidev ARM: dts: imx6sl: add baud clock and clock-names for ssi ARM: dts: imx6qdl: add baud clock and clock-names for ssi ARM: dts: imx6qdl-sabresd: Configure the pins locally ARM: dts: imx28-m28evk: Fix display duplicate name warning ARM: dts: imx28-tx28: Fix display duplicate name warning ARM: dts: imx28-m28cu: Fix display duplicate name warning ARM: dts: imx28-cfa100: Fix display duplicate name warning ARM: dts: imx28-apf28dev: Fix display duplicate name warning ARM: dts: imx28-apx4devkit: Fix display duplicate name warning ... Signed-off-by: Olof Johansson <olof@lixom.net>
2014-09-24Merge tag 'imx-soc-3.18' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux into next/soc Merge "ARM: imx: SoC updates for 3.18" from Shawn Guo: The i.MX SoC updates for 3.18: - Add initial devicetree support for i.MX1 - Support GPT per clock source from OSC for i.MX6 - A couple of parent selection corrections for i.MX6SL clock driver - Support more chip revision for i.MX6 - Convert pr_warning to pr_warn - Add exclusive gate clock support - Add BYPASS support for i.MX6 PLL clocks - Update i.MX6 clock tree for audio use case - A couple of VF610 clock driver updates * tag 'imx-soc-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/shawnguo/linux: (30 commits) ARM: imx_v6_v7_defconfig updates ARM: imx_v4_v5_defconfig: Select CONFIG_IMX_WEIM arm: mach-imx: Convert pr_warning to pr_warn ARM: imx: source gpt per clk from OSC for system timer ARM: imx: add gpt_3m clk for i.mx6qdl ARM: imx: fix register offset of pll7_usb_host gate clock ARM: clk-imx6sl: refine clock tree for SSI ARM: imx: remove ENABLE and BYPASS bits from clk-pllv3 driver ARM: imx6sx: add BYPASS support for PLL clocks ARM: imx6sl: add BYPASS support for PLL clocks ARM: imx6q: add BYPASS support for PLL clocks ARM: imx: add an exclusive gate clock type ARM: clk-imx6q: refine clock tree for SSI ARM: clk-imx6q: refine clock tree for ASRC ARM: clk-imx6sl: correct the pxp and epdc axi clock selections ARM: clk-imx6q: refine clock tree for ESAI ARM: clk-imx6sl: Select appropriate parents for LCDIF clocks ARM: clk-imx6sl: Remove csi_lcdif_sels[] ARM: imx: clk-vf610: Add USBPHY clocks ARM: imx: add cpufreq support for i.mx6sx ... Signed-off-by: Olof Johansson <olof@lixom.net>
2014-09-22clk: samsung: exynos4: add support for MOUT_HDMI and MOUT_MIXER clocksMarek Szyprowski
This patch adds support for exporting mout_hdmi and mout_mixer to device tree. Access to those clocks is required to correctly setup HDMI module on Exynos 4210 and 4x12 SoCs. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> CC: Mike Turquette <mturquette@linaro.org> CC: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com>
2014-09-22clk: samsung: exynos4: add missing smmu_g2d clock and update commentsMarek Szyprowski
This patch adds missing smmu_g2d clock implementation and updates comment about Exynos4 clocks from 278-282 range. Those clocks are available on all Exynos4 SoC series, so the misleading comment has been removed. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com>
2014-09-22clk: samsung: exynos3250: Register DMC clk providerKrzysztof Kozlowski
Add clock provider for clocks in DMC domain including EPLL and BPLL. The DMC clocks are necessary for Exynos3 devfreq driver. The DMC clock domain uses different address space (0x105C0000) than standard clock domain (0x10030000 - 0x10050000). The difference is huge enough to add new DT node for the clock provider, rather than extending existing address space. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com>
2014-09-18ARM: tegra: Add PLL_M_UD and PLL_C_UD to tegra124-car binding headerMikko Perttunen
Add these clocks to the binding header so that EMC timings that have them as parent can refer to the clocks. Signed-off-by: Mikko Perttunen <mperttunen@nvidia.com>
2014-09-16ARM: imx: add gpt_3m clk for i.mx6qdlAnson Huang
Add gpt_3m clock for i.mx6qdl, as gpt can source clock from OSC, some i.MX6 series SOCs has fixed divider of 8 for gpt clock, so here add a fix clk of gpt_3m. i.MX6Q TO1.0 has no gpt_3m option, so force it to be from ipg_per. Signed-off-by: Anson Huang <b20788@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-09-16ARM: clk-imx6sl: refine clock tree for SSIShengjiu Wang
Each SSI has "ssi", "ssi_ipg" clocks, and they share same gate bits. Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-09-16ARM: imx6sx: add BYPASS support for PLL clocksShawn Guo
This is the same change for imx6sx clock driver as "ARM: imx6q: add BYPASS support for PLL clocks" for imx6q. The difference is that only anaclk1 is available on imx6sx. Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-09-16ARM: imx6sl: add BYPASS support for PLL clocksShawn Guo
This is the same change for imx6sl clock driver as "ARM: imx6q: add BYPASS support for PLL clocks" for imx6q. The difference is that only anaclk1 is available on imx6sl. Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-09-16ARM: imx6q: add BYPASS support for PLL clocksShawn Guo
The imx6q clock driver currently hard-codes all PLL clocks to source from OSC24M without BYPASS support. The patch adds the missing lvds_in clock which is mutually exclusive with lvds_gate, and implements BYPASS and BYPASS_CLK_SRC selection for PLL clocks as per Figure 10-3. Primary Clock Generation in IMX6DQRM, i.e. both BYPASS_CLK_SRC and BYPASS bits are implemented as mux clocks, and ENABLE bit of PLL clocks is implemented as a gate clock after BYPASS mux. Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-09-16ARM: clk-imx6q: refine clock tree for ASRCShengjiu Wang
ASRC has "asrc", "asrc_ipg", "asrc_mem" clocks, and they share the same gate bits. Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-09-16ARM: clk-imx6q: refine clock tree for ESAIShengjiu Wang
There are three clock for ESAI, esai_extal, esai_ipg, esai_mem. Rename 'esai' to 'esai_extal', 'esai_ahb' to 'esai_mem', and add 'esai_ipg'. Make the clock for ESAI more clear and align them with imx6sx. Signed-off-by: Shengjiu Wang <shengjiu.wang@freescale.com> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-09-16ARM: imx: clk-vf610: Add USBPHY clocksStefan Agner
This commit adds PLL7 which is required for USBPHY1. It also adds the USB PHY and USB Controller clocks and the gates to enable them. Acked-by: Jingchang Lu <jingchang.lu@freescale.com> Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Shawn Guo <shawn.guo@freescale.com>
2014-09-09clk: Add driver for Maxim 77802 PMIC clocksJavier Martinez Canillas
The MAX77802 PMIC has two 32.768kHz Buffered Clock Outputs with Low Jitter Mode. This patch adds support for these two clocks. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-09-09clk: max77686: Add DT include for MAX77686 PMIC clockJavier Martinez Canillas
This patch adds a dt-binding include for Maxim 77686 PMIC clock IDs that can be used by both the max77686 clock driver and Device Tree source files. Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Reviewed-by: Mike Turquette <mturquette@linaro.org> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-09-09ARM: shmobile: Initial r8a7794 SoC device treeUlrich Hecht
Signed-off-by: Hisashi Nakamura <hisashi.nakamura.ak@renesas.com> [uli: reduced to minimum, added cmt, enabled scif2, split off board part] Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2014-09-05pinctrl: at91: add drive strength configurationMarek Roszko
The SAMA5 and SAM9x5 series both have drive strength options for the PIOs. This patch adds the ability to set one of three hardware options for drive strengths of low, medium or high for the each pin. The actual current output of the chip based on the setting is defined in the datasheets and varies per pins separate from banks and with supply voltage. This patch adds three new dt-bindings that allow setting the strength when configuring pins. By default, no change will be made to the drive strength of a pin from its reset value. Due to the difference between the register addresses of the SAMA5 and SAM9x5 series, a new sama5d3-pinctrl id was added. Signed-off-by: Marek Roszko <mark.roszko@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-03Merge tag 'v3.17-rc3' into nextDmitry Torokhov
Sync with mainline to bring in Chrome EC changes.
2014-08-28pinctrl: Add mux options 3 and 4 for rockchip pinctrlDoug Anderson
Newer Rockchip SoCs have more muxing slots. Add slots 3 and 4 since the rk3288 table goes all the way up to 4. Signed-off-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-08-23ARM: shmobile: r8a7740: clock register bitsUlrich Hecht
Contains the header file with the clock pulse generator and MSTP bits. Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com> Acked-by: Magnus Damm <damm+renesas@opensource.se> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2014-08-22ARM: shmobile: r8a7740: clock register bitsUlrich Hecht
Contains the header file with the clock pulse generator and MSTP bits. Signed-off-by: Ulrich Hecht <ulrich.hecht+renesas@gmail.com> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
