path: root/include/keys/rxrpc-type.h
2011-03-02RxRPC: Fix v1 keysAnton Blanchard
commit 339412841d7 (RxRPC: Allow key payloads to be passed in XDR form) broke klog for me. I notice the v1 key struct had a kif_version field added: -struct rxkad_key { - u16 security_index; /* RxRPC header security index */ - u16 ticket_len; /* length of ticket[] */ - u32 expiry; /* time at which expires */ - u32 kvno; /* key version number */ - u8 session_key[8]; /* DES session key */ - u8 ticket[0]; /* the encrypted ticket */ -}; +struct rxrpc_key_data_v1 { + u32 kif_version; /* 1 */ + u16 security_index; + u16 ticket_length; + u32 expiry; /* time_t */ + u32 kvno; + u8 session_key[8]; + u8 ticket[0]; +}; However the code in rxrpc_instantiate strips it away: data += sizeof(kver); datalen -= sizeof(kver); Removing kif_version fixes my problem. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-16RxRPC: Use uX/sX rather than uintX_t/intX_t typesDavid Howells
Use uX rather than uintX_t types for consistency. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15RxRPC: Parse security index 5 keys (Kerberos 5)David Howells
Parse RxRPC security index 5 type keys (Kerberos 5 tokens). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15RxRPC: Allow key payloads to be passed in XDR formDavid Howells
Allow add_key() and KEYCTL_INSTANTIATE to accept key payloads in XDR form as described by openafs-1.4.10/src/auth/afs_token.xg. This provides a way of passing kaserver, Kerberos 4, Kerberos 5 and GSSAPI keys from userspace, and allows for future expansion. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-21KEYS: Fix the comment to match the file name in rxrpc-type.h.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2007-10-17KEYS: Make request_key() and co fundamentally asynchronousDavid Howells
Make request_key() and co fundamentally asynchronous to make it easier for NFS to make use of them. There are now accessor functions that do asynchronous constructions, a wait function to wait for construction to complete, and a completion function for the key type to indicate completion of construction. Note that the construction queue is now gone. Instead, keys under construction are linked in to the appropriate keyring in advance, and that anyone encountering one must wait for it to be complete before they can use it. This is done automatically for userspace. The following auxiliary changes are also made: (1) Key type implementation stuff is split from linux/key.h into linux/key-type.h. (2) AF_RXRPC provides a way to allocate null rxrpc-type keys so that AFS does not need to call key_instantiate_and_link() directly. (3) Adjust the debugging macros so that they're -Wformat checked even if they are disabled, and make it so they can be enabled simply by defining __KDEBUG to be consistent with other code of mine. (3) Documentation. [alan@lxorguk.ukuu.org.uk: keys: missing word in documentation] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-26[AF_RXRPC]: Provide secure RxRPC sockets for use by userspace and kernel bothDavid Howells
Provide AF_RXRPC sockets that can be used to talk to AFS servers, or serve answers to AFS clients. KerberosIV security is fully supported. The patches and some example test programs can be found in: http://people.redhat.com/~dhowells/rxrpc/ This will eventually replace the old implementation of kernel-only RxRPC currently resident in net/rxrpc/. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
