path: root/include/linux/aio_abi.h
2007-05-11signal/timer/event: KAIO eventfd support exampleDavide Libenzi
This is an example about how to add eventfd support to the current KAIO code, in order to enable KAIO to post readiness events to a pollable fd (hence compatible with POSIX select/poll). The KAIO code simply signals the eventfd fd when events are ready, and this triggers a POLLIN in the fd. This patch uses a reserved for future use member of the struct iocb to pass an eventfd file descriptor, that KAIO will use to post events every time a request completes. At that point, an aio_getevents() will return the completed result to a struct io_event. I made a quick test program to verify the patch, and it runs fine here: http://www.xmailserver.org/eventfd-aio-test.c The test program uses poll(2), but it'd, of course, work with select and epoll too. This can allow to schedule both block I/O and other poll-able devices requests, and wait for results using select/poll/epoll. In a typical scenario, an application would submit KAIO request using aio_submit(), and will also use epoll_ctl() on the whole other class of devices (that with the addition of signals, timers and user events, now it's pretty much complete), and then would: epoll_wait(...); for_each_event { if (curr_event_is_kaiofd) { aio_getevents(); dispatch_aio_events(); } else { dispatch_epoll_event(); } } Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-01[PATCH] Add vector AIO supportBadari Pulavarty
This work is initially done by Zach Brown to add support for vectored aio. These are the core changes for AIO to support IOCB_CMD_PREADV/IOCB_CMD_PWRITEV. [akpm@osdl.org: huge build fix] Signed-off-by: Zach Brown <zach.brown@oracle.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Acked-by: Benjamin LaHaise <bcrl@kvack.org> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
