path: root/include/linux/atmel-mci.h
2009-12-15atmel-mci: change use of dma slave interfaceNicolas Ferre
Allow the use of another DMA controller driver in atmel-mci sd/mmc driver. This adds a generic dma_slave pointer to the mci platform structure where we can store DMA controller information. In atmel-mci we use information provided by this structure to initialize the driver (with new helper functions that are architecture dependant). This also adds at32/avr32 chip modifications to cope with this new access method. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-08atmel-mci: Add support for inverted detect pinJonas Larsson
Same patch as before, modified to use bool. Also adds description of the new field in struct atmel_mci that I missed in the first patch. This patch adds Atmel MCI support for inverted detect pins. Signed-off-by: Jonas Larsson <jonas.larsson@martinsson.se> Acked-by: Pierre Ossman <pierre@ossman.eu> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2009-01-09Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (22 commits) ioat: fix self test for multi-channel case dmaengine: bump initcall level to arch_initcall dmaengine: advertise all channels on a device to dma_filter_fn dmaengine: use idr for registering dma device numbers dmaengine: add a release for dma class devices and dependent infrastructure ioat: do not perform removal actions at shutdown iop-adma: enable module removal iop-adma: kill debug BUG_ON iop-adma: let devm do its job, don't duplicate free dmaengine: kill enum dma_state_client dmaengine: remove 'bigref' infrastructure dmaengine: kill struct dma_client and supporting infrastructure dmaengine: replace dma_async_client_register with dmaengine_get atmel-mci: convert to dma_request_channel and down-level dma_slave dmatest: convert to dma_request_channel dmaengine: introduce dma_request_channel and private channels net_dma: convert to dma_find_channel dmaengine: provide a common 'issue_pending_all' implementation dmaengine: centralize channel allocation, introduce dma_find_channel dmaengine: up-level reference counting to the module level ...
2009-01-05atmel-mci: move atmel-mci.h file to include/linuxNicolas Ferre
Needed to use the atmel-mci driver in an architecture independant maner. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
