The debugger runing in kernel is used to generate
required time sequence to C2 debug interface of the
microcontroller in joystick.
Bug 1375728
Change-Id: I7e366068faa16745e46fe60826b92c9ed44efb32
Signed-off-by: Will Wu <willw@nvidia.com>
Reviewed-on: http://git-master/r/335983
GVS: Gerrit_Virtual_Submit
The <linux/device.h> header includes a lot of stuff, and
it in turn gets a lot of use just for the basic "struct device"
which appears so often.
Clean up the users as follows:
1) For those headers only needing "struct device" as a pointer
in fcn args, replace the include with exactly that.
2) For headers not really using anything from device.h, simply
delete the include altogether.
3) For headers relying on getting device.h implicitly before
being included themselves, now explicitly include device.h
4) For files in which doing #1 or #2 uncovers an implicit
dependency on some other header, fix by explicitly adding
the required header(s).
Any C files that were implicitly relying on device.h to be
present have already been dealt with in advance.
Total removals from #1 and #2: 51. Total additions coming
from #3: 9. Total other implicit dependencies from #4: 7.
As of 3.3-rc1, there were 110, so a net removal of 42 gives
about a 38% reduction in device.h presence in include/*
The macro to_class_dev() uses the deprecated structure class_device, and
the c2port_device has no member named class in the definition of the macro
to_c2port_device.
Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com>
Cc: Rodolfo Giometti <giometti@linux.it>
This silences a false positive warning with kmemcheck.
Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
C2port implements a two wire serial communication protocol (bit
banging) designed to enable in-system programming, debugging, and
boundary-scan testing on low pin-count Silicon Labs devices.
Currently this code supports only flash programming through sysfs
interface but extensions shoud be easy to add.
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
Cc: Greg KH <greg@kroah.com>
