path: root/include/linux/cacheinfo.h
2018-01-31drivers: base: cacheinfo: fix x86 with CONFIG_OF enabledSudeep Holla
commit fac51482577d5e05bbb0efa8d602a3c2111098bf upstream. With CONFIG_OF enabled on x86, we get the following error on boot: " Failed to find cpu0 device node Unable to detect cache hierarchy from DT for CPU 0 " and the cacheinfo fails to get populated in the corresponding sysfs entries. This is because cache_setup_of_node looks for of_node for setting up the shared cpu_map without checking that it's already populated in the architecture specific callback. In order to indicate that the shared cpu_map is already populated, this patch introduces a boolean `cpu_map_populated` in struct cpu_cacheinfo that can be used by the generic code to skip cache_shared_cpu_map_setup. This patch also sets that boolean for x86. Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Mian Yousaf Kaukab <yousaf.kaukab@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-24drivers/base: cacheinfo: fix annoying typo when DT nodes are absentWill Deacon
s/hierarcy/hierarchy/ Maybe the typo will annoy people enough so that they add the missing nodes to their device-tree files, but I still think this is better off fixed. Signed-off-by: Will Deacon <will.deacon@arm.com> Acked-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-07drivers: base: support cpu cache information interface to userspace via sysfsSudeep Holla
This patch adds initial support for providing processor cache information to userspace through sysfs interface. This is based on already existing implementations(x86, ia64, s390 and powerpc) and hence the interface is intended to be fully compatible. The main purpose of this generic support is to avoid further code duplication to support new architectures and also to unify all the existing different implementations. This implementation maintains the hierarchy of cache objects which reflects the system's cache topology. Cache devices are instantiated as needed as CPUs come online. The cache information is replicated per-cpu even if they are shared. A per-cpu array of cache information maintained is used mainly for sysfs-related book keeping. It also implements the shared_cpu_map attribute, which is essential for enabling both kernel and user-space to discover the system's overall cache topology. This patch also add the missing ABI documentation for the cacheinfo sysfs interface already, which is well defined and widely used. Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Tested-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: linux-api@vger.kernel.org Cc: linux390@de.ibm.com Cc: linux-arm-kernel@lists.infradead.org Cc: linux-ia64@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Cc: linux-s390@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
