path: root/include/linux/cgroup_subsys.h
2008-04-29cgroups: implement device whitelistSerge E. Hallyn
Implement a cgroup to track and enforce open and mknod restrictions on device files. A device cgroup associates a device access whitelist with each cgroup. A whitelist entry has 4 fields. 'type' is a (all), c (char), or b (block). 'all' means it applies to all types and all major and minor numbers. Major and minor are either an integer or * for all. Access is a composition of r (read), w (write), and m (mknod). The root device cgroup starts with rwm to 'all'. A child devcg gets a copy of the parent. Admins can then remove devices from the whitelist or add new entries. A child cgroup can never receive a device access which is denied its parent. However when a device access is removed from a parent it will not also be removed from the child(ren). An entry is added using devices.allow, and removed using devices.deny. For instance echo 'c 1:3 mr' > /cgroups/1/devices.allow allows cgroup 1 to read and mknod the device usually known as /dev/null. Doing echo a > /cgroups/1/devices.deny will remove the default 'a *:* mrw' entry. CAP_SYS_ADMIN is needed to change permissions or move another task to a new cgroup. A cgroup may not be granted more permissions than the cgroup's parent has. Any task can move itself between cgroups. This won't be sufficient, but we can decide the best way to adequately restrict movement later. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix may-be-used-uninitialized warning] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Acked-by: James Morris <jmorris@namei.org> Looks-good-to: Pavel Emelyanov <xemul@openvz.org> Cc: Daniel Hokka Zakrisson <daniel@hozac.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Paul Menage <menage@google.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Memory controller: rename to Memory Resource ControllerBalbir Singh
Rename Memory Controller to Memory Resource Controller. Reflect the same changes in the CONFIG definition for the Memory Resource Controller. Group together the config options for Resource Counters and Memory Resource Controller. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13sched: rt-group: make rt groups scheduling configurablePeter Zijlstra
Make the rt group scheduler compile time configurable. Keep it experimental for now. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-07Memory controller: cgroups setupBalbir Singh
Setup the memory cgroup and add basic hooks and controls to integrate and work with the cgroup. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Paul Menage <menage@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Kirill Korotaev <dev@sw.ru> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: David Rientjes <rientjes@google.com> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-02sched: cpu accounting controller (V2)Srivatsa Vaddagiri
Commit cfb5285660aad4931b2ebbfa902ea48a37dfffa1 removed a useful feature for us, which provided a cpu accounting resource controller. This feature would be useful if someone wants to group tasks only for accounting purpose and doesnt really want to exercise any control over their cpu consumption. The patch below reintroduces the feature. It is based on Paul Menage's original patch (Commit 62d0df64065e7c135d0002f069444fbdfc64768f), with these differences: - Removed load average information. I felt it needs more thought (esp to deal with SMP and virtualized platforms) and can be added for 2.6.25 after more discussions. - Convert group cpu usage to be nanosecond accurate (as rest of the cfs stats are) and invoke cpuacct_charge() from the respective scheduler classes - Make accounting scalable on SMP systems by splitting the usage counter to be per-cpu - Move the code from kernel/cpu_acct.c to kernel/sched.c (since the code is not big enough to warrant a new file and also this rightly needs to live inside the scheduler. Also things like accessing rq->lock while reading cpu usage becomes easier if the code lived in kernel/sched.c) The patch also modifies the cpu controller not to provide the same accounting information. Tested-by: Balbir Singh <balbir@linux.vnet.ibm.com> Tested the patches on top of 2.6.24-rc3. The patches work fine. Ran some simple tests like cpuspin (spin on the cpu), ran several tasks in the same group and timed them. Compared their time stamps with cpuacct.usage. Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-11-14revert "Task Control Groups: example CPU accounting subsystem"Andrew Morton
Revert 62d0df64065e7c135d0002f069444fbdfc64768f. This was originally intended as a simple initial example of how to create a control groups subsystem; it wasn't intended for mainline, but I didn't make this clear enough to Andrew. The CFS cgroup subsystem now has better functionality for the per-cgroup usage accounting (based directly on CFS stats) than the "usage" status file in this patch, and the "load" status file is rather simplistic - although having a per-cgroup load average report would be a useful feature, I don't believe this patch actually provides it. If it gets into the final 2.6.24 we'd probably have to support this interface for ever. Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Hook up group scheduler with control groupsSrivatsa Vaddagiri
Enable "cgroup" (formerly containers) based fair group scheduling. This will let administrator create arbitrary groups of tasks (using "cgroup" pseudo filesystem) and control their cpu bandwidth usage. [akpm@linux-foundation.org: fix cpp condition] Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com> Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19cgroups: implement namespace tracking subsystemSerge E. Hallyn
When a task enters a new namespace via a clone() or unshare(), a new cgroup is created and the task moves into it. This version names cgroups which are automatically created using cgroup_clone() as "node_<pid>" where pid is the pid of the unsharing or cloned process. (Thanks Pavel for the idea) This is safe because if the process unshares again, it will create /cgroups/(...)/node_<pid>/node_<pid> The only possibilities (AFAICT) for a -EEXIST on unshare are 1. pid wraparound 2. a process fails an unshare, then tries again. Case 1 is unlikely enough that I ignore it (at least for now). In case 2, the node_<pid> will be empty and can be rmdir'ed to make the subsequent unshare() succeed. Changelog: Name cloned cgroups as "node_<pid>". [clg@fr.ibm.com: fix order of cgroup subsystems in init/Kconfig] Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Task Control Groups: simple task cgroup debug info subsystemPaul Menage
This example subsystem exports debugging information as an aid to diagnosing refcount leaks, etc, in the cgroup framework. Signed-off-by: Paul Menage <menage@google.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Task Control Groups: example CPU accounting subsystemPaul Menage
This example demonstrates how to use the generic cgroup subsystem for a simple resource tracker that counts, for the processes in a cgroup, the total CPU time used and the %CPU used in the last complete 10 second interval. Portions contributed by Balbir Singh <balbir@in.ibm.com> Signed-off-by: Paul Menage <menage@google.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Task Control Groups: make cpusets a client of cgroupsPaul Menage
Remove the filesystem support logic from the cpusets system and makes cpusets a cgroup subsystem The "cpuset" filesystem becomes a dummy filesystem; attempts to mount it get passed through to the cgroup filesystem with the appropriate options to emulate the old cpuset filesystem behaviour. Signed-off-by: Paul Menage <menage@google.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Task Control Groups: basic task cgroup frameworkPaul Menage
Generic Process Control Groups -------------------------- There have recently been various proposals floating around for resource management/accounting and other task grouping subsystems in the kernel, including ResGroups, User BeanCounters, NSProxy cgroups, and others. These all need the basic abstraction of being able to group together multiple processes in an aggregate, in order to track/limit the resources permitted to those processes, or control other behaviour of the processes, and all implement this grouping in different ways. This patchset provides a framework for tracking and grouping processes into arbitrary "cgroups" and assigning arbitrary state to those groupings, in order to control the behaviour of the cgroup as an aggregate. The intention is that the various resource management and virtualization/cgroup efforts can also become task cgroup clients, with the result that: - the userspace APIs are (somewhat) normalised - it's easier to test e.g. the ResGroups CPU controller in conjunction with the BeanCounters memory controller, or use either of them as the resource-control portion of a virtual server system. - the additional kernel footprint of any of the competing resource management systems is substantially reduced, since it doesn't need to provide process grouping/containment, hence improving their chances of getting into the kernel This patch: Add the main task cgroups framework - the cgroup filesystem, and the basic structures for tracking membership and associating subsystem state objects to tasks. Signed-off-by: Paul Menage <menage@google.com> Cc: Serge E. Hallyn <serue@us.ibm.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Srivatsa Vaddagiri <vatsa@in.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
