path: root/include/linux/cleancache.h
2015-04-14cleancache: remove limit on the number of cleancache enabled filesystemsVladimir Davydov
The limit equals 32 and is imposed by the number of entries in the fs_poolid_map and shared_fs_poolid_map. Nowadays it is insufficient, because with containers on board a Linux host can have hundreds of active fs mounts. These maps were introduced by commit 49a9ab815acb8 ("mm: cleancache: lazy initialization to allow tmem backends to build/run as modules") in order to allow compiling cleancache drivers as modules. Real pool ids are stored in these maps while super_block->cleancache_poolid points to an entry in the map, so that on cleancache registration we can walk over all (if there are <= 32 of them, of course) cleancache-enabled super blocks and assign real pool ids. Actually, there is absolutely no need in these maps, because we can iterate over all super blocks immediately using iterate_supers. This is not racy, because cleancache_init_ops is called from mount_fs with super_block->s_umount held for writing, while iterate_supers takes this semaphore for reading, so if we call iterate_supers after setting cleancache_ops, all super blocks that had been created before cleancache_register_ops was called will be assigned pool ids by the action function of iterate_supers while all newer super blocks will receive it in cleancache_init_fs. This patch therefore removes the maps and hence the artificial limit on the number of cleancache enabled filesystems. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Bob Liu <lliubbo@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14cleancache: forbid overriding cleancache_opsVladimir Davydov
Currently, cleancache_register_ops returns the previous value of cleancache_ops to allow chaining. However, chaining, as it is implemented now, is extremely dangerous due to possible pool id collisions. Suppose, a new cleancache driver is registered after the previous one assigned an id to a super block. If the new driver assigns the same id to another super block, which is perfectly possible, we will have two different filesystems using the same id. No matter if the new driver implements chaining or not, we are likely to get data corruption with such a configuration eventually. This patch therefore disables the ability to override cleancache_ops altogether as potentially dangerous. If there is already cleancache driver registered, all further calls to cleancache_register_ops will return EBUSY. Since no user of cleancache implements chaining, we only need to make minor changes to the code outside the cleancache core. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Bob Liu <lliubbo@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-14cleancache: zap uuid arg of cleancache_init_shared_fsVladimir Davydov
Use super_block->s_uuid instead. Every shared filesystem using cleancache must now initialize super_block->s_uuid before calling cleancache_init_shared_fs. The only one on the tree, ocfs2, already meets this requirement. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Bob Liu <lliubbo@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30mm: cleancache: clean up cleancache_enabledBob Liu
cleancache_ops is used to decide whether backend is registered. So now cleancache_enabled is always true if defined CONFIG_CLEANCACHE. Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30cleancache: Make cleancache_init use a pointer for the opsKonrad Rzeszutek Wilk
Instead of using a backend_registered to determine whether a backend is enabled. This allows us to remove the backend_register check and just do 'if (cleancache_ops)' [v1: Rebase on top of b97c4b430b0a (ramster->zcache move] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com> Cc: Andor Daam <andor.daam@googlemail.com> Cc: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Florian Schmaus <fschmaus@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Stefan Hengelein <ilendir@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-23mm: zcache/tmem/cleancache: s/flush/invalidate/Dan Magenheimer
Complete the renaming from "flush" to "invalidate" across both tmem frontends (cleancache and frontswap) and both tmem backends (Xen and zcache), as required by akpm. This change is completely cosmetic. [v10: no change] [v9: akpm@linux-foundation.org: change "flush" to "invalidate", part 3] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Jan Beulich <JBeulich@novell.com> Acked-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Chris Mason <chris.mason@oracle.com> Cc: Rik Riel <riel@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> [v11: Remove the frontswap part] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-01-23mm: cleancache: s/flush/invalidate/Dan Magenheimer
Per akpm suggestions alter the use of the term flush to be invalidate. The next patch will do this across all MM. This change is completely cosmetic. [v9: akpm@linux-foundation.org: change "flush" to "invalidate", part 3] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Jan Beulich <JBeulich@novell.com> Reviewed-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Chris Mason <chris.mason@oracle.com> Cc: Rik Riel <riel@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> [v10: Fixed fs: move code out of buffer.c conflict change] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-05-26mm: cleancache core ops functions and configDan Magenheimer
This third patch of eight in this cleancache series provides the core code for cleancache that interfaces between the hooks in VFS and individual filesystems and a cleancache backend. It also includes build and config patches. Two new files are added: mm/cleancache.c and include/linux/cleancache.h. Note that CONFIG_CLEANCACHE can default to on; in systems that do not provide a cleancache backend, all hooks devolve to a simple check of a global enable flag, so performance impact should be negligible but can be reduced to zero impact if config'ed off. However for this first commit, it defaults to off. Details and a FAQ can be found in Documentation/vm/cleancache.txt Credits: Cleancache_ops design derived from Jeremy Fitzhardinge design for tmem [v8: dan.magenheimer@oracle.com: fix exportfs call affecting btrfs] [v8: akpm@linux-foundation.org: use static inline function, not macro] [v7: dan.magenheimer@oracle.com: cleanup sysfs and remove cleancache prefix] [v6: JBeulich@novell.com: robustly handle buggy fs encode_fh actor definition] [v5: jeremy@goop.org: clean up global usage and static var names] [v5: jeremy@goop.org: simplify init hook and any future fs init changes] [v5: hch@infradead.org: cleaner non-global interface for ops registration] [v4: adilger@sun.com: interface must support exportfs FS's] [v4: hch@infradead.org: interface must support 64-bit FS on 32-bit kernel] [v3: akpm@linux-foundation.org: use one ops struct to avoid pointer hops] [v3: akpm@linux-foundation.org: document and ensure PageLocked reqts are met] [v3: ngupta@vflare.org: fix success/fail codes, change funcs to void] [v2: viro@ZenIV.linux.org.uk: use sane types] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Acked-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Nitin Gupta <ngupta@vflare.org> Acked-by: Minchan Kim <minchan.kim@gmail.com> Acked-by: Andreas Dilger <adilger@sun.com> Acked-by: Jan Beulich <JBeulich@novell.com> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com>
