headers
[ Upstream commit f90fb3c7e2c13ae829db2274b88b845a75038b8a ]
Only users of upc_req in kernel side fs/coda/psdev.c and
fs/coda/upcall.c already include linux/coda_psdev.h.
Suggested by Jan Harkes <jaharkes@cs.cmu.edu> in
https://lore.kernel.org/lkml/20150531111913.GA23377@cs.cmu.edu/
Fixes these include/uapi/linux/coda_psdev.h compilation errors in userspace:
linux/coda_psdev.h:12:19: error: field `uc_chain' has incomplete type
struct list_head uc_chain;
linux/coda_psdev.h:13:2: error: unknown type name `caddr_t'
caddr_t uc_data;
linux/coda_psdev.h:14:2: error: unknown type name `u_short'
u_short uc_flags;
linux/coda_psdev.h:15:2: error: unknown type name `u_short'
u_short uc_inSize; /* Size is at most 5000 bytes */
linux/coda_psdev.h:16:2: error: unknown type name `u_short'
u_short uc_outSize;
linux/coda_psdev.h:17:2: error: unknown type name `u_short'
u_short uc_opcode; /* copied from data to save lookup */
linux/coda_psdev.h:19:2: error: unknown type name `wait_queue_head_t'
wait_queue_head_t uc_sleep; /* process' wait queue */
Link: http://lkml.kernel.org/r/9f99f5ce6a0563d5266e6cf7aa9585aac2cae971.1558117389.git.jaharkes@cs.cmu.edu
Signed-off-by: Mikko Rapeli <mikko.rapeli@iki.fi>
Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Fabian Frederick <fabf@skynet.be>
Cc: Sam Protsenko <semen.protsenko@linaro.org>
Cc: Yann Droneaud <ydroneaud@opteya.com>
Cc: Zhouyang Jia <jiazhouyang09@gmail.com>
Remove the slight chance that uids and gids in coda messages will be
interpreted in the wrong user namespace.
- Only allow processes in the initial user namespace to open the coda
character device to communicate with coda filesystems.
- Explicitly convert the uids in the coda header into the initial user
namespace.
- In coda_vattr_to_attr make kuids and kgids from the initial user
namespace uids and gids in struct coda_vattr that just came from
userspace.
- In coda_iattr_to_vattr convert kuids and kgids into uids and gids
in the intial user namespace and store them in struct coda_vattr for
sending to coda userspace programs.
Nothing needs to be changed with mounts as coda does not support
being mounted in anything other than the initial user namespace.
Cc: Jan Harkes <jaharkes@cs.cmu.edu>
Acked-by: Michael Kerrisk <mtk.manpages@gmail.com>
Acked-by: Dave Jones <davej@redhat.com>
Replace the BKL with a mutex to protect the venus_comm structure which
binds the mountpoint with the character device and holds the upcall
queues.
Signed-off-by: Yoshihisa Abe <yoshiabe@cs.cmu.edu>
Now that shared inode state is locked using the cii->c_lock, the BKL is
only used to protect the upcall queues used to communicate with the
userspace cache manager. The remaining state is all local and we can
push the lock further down into coda_upcall().
CODA should not be using defines in the global name space of
that nature, prefix them with CODA_.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Otherwise we must export backing-dev.h as well, which doesn't make
any sense.
This ensures that dirty data gets flushed properly.
These are only for kernel internals as pointed by Arnd Bergmann:
struct kstatfs
struct venus_comm
coda_vcp()
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
fix the following 'make headers_check' warning:
usr/include/linux/coda_psdev.h:90: extern's make no sense in userspace
This is an variation on the patch sent by Christoph Hellwig which kills
file_count abuse by the Coda kernel module by moving the coda_flush
functionality into coda_release. However part of reason we were using the
coda_flush callback was to allow Coda to pass errors that occur during
writeback from the userspace cache manager back to close().
As Al Viro explained on linux-fsdevel, it is impossible to guarantee that
such errors can in fact be returned back to the caller. There are many
cases where the last reference to a file is not released by the close
system call and it is also impossible to pick some close as a 'last-close'
and delay it until all other references have been destroyed.
The CODA_STORE/CODA_RELEASE upcall combination is clearly a broken design,
and it is better to remove it completely.
Cc: Al Viro <viro@ftp.linux.org.uk>
Similar information can easily be obtained with strace -c.
The sb_info structure only contains a single pointer to the character device,
there is no need for the added indirection.
We ignore signals for about 30 seconds to give userspace a chance to see the
upcall. As we did not block signals we ended up in a busy loop for the
remainder of the period when a signal is received.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Give the statfs superblock operation a dentry pointer rather than a superblock
pointer.
This complements the get_sb() patch. That reduced the significance of
sb->s_root, allowing NFS to place a fake root there. However, NFS does
require a dentry to use as a target for the statfs operation. This permits
the root in the vfsmount to be used instead.
linux/mount.h has been added where necessary to make allyesconfig build
successfully.
Interest has also been expressed for use with the FUSE and XFS filesystems.
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Nathan Scott <nathans@sgi.com>
infrastructure for it.
Let it rip!
