path: root/include/linux/cyclades.h
2008-02-03include/linux/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-18Char: cyclades, fix some -W warningsJiri Slaby
Most of them are signedness, the rest unused function parameters. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Char: cyclades, remove bottom half processingJiri Slaby
The work done in bottom half doesn't cost much cpu time (e.g. tty_hangup itself schedules its own bottom half), it's possible to do the work in isr directly and save hence some .text. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Char: cyclades, dynamic portsJiri Slaby
and save thus approx. 160k of .bss Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Char: cyclades, remove unused timestampsJiri Slaby
2007-05-08Char: cyclades, remove sleep_onJiri Slaby
convert to wait_* and completion Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Char: cyclades, make info->card a pointerJiri Slaby
2007-05-08Char: cyclades, remove useless fileds from cyclades_cardJiri Slaby
pde, ctl_phys and base_phys are useless -- they are never used. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Char: cyclades, unexport struct cyclades_cardJiri Slaby
Do not export internal card data to userspace. cytune doesn't use this anyway. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Char: cyclades, cy_readX/writeX cleanupJiri Slaby
cyclades, cy_readX/writeX cleanup - cy_readX are placeholders for readX, remove it - move cy_writeX macros into do {} while(0) to be safe Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08cyclades: remove custom typesKlaus Kudielka
Switch from private uclong, etc over to standard types. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08fix cyclades.h for x86_64 (and probably others)Klaus Kudielka
At least on x86_64 the present cyclades.h is broken due to the wrong size of uclong. This affects, of course, both the kernel and the user-level utilities. The symptom is that cyzload refuses to load the firmware. I also managed to freeze the machine when unloading the module. The patch below fixes this in an architecture-independent way. I have tested it with 2.6.19 and the driver works fine again with a Cyclades-Z on an Athlon 64 X2. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
