path: root/include/linux/dma-contiguous.h
2015-10-23mm: cma: fix incorrect type conversion for size during dma allocationRohit Vaswani
This was found during userspace fuzzing test when a large size dma cma allocation is made by driver(like ion) through userspace. show_stack+0x10/0x1c dump_stack+0x74/0xc8 kasan_report_error+0x2b0/0x408 kasan_report+0x34/0x40 __asan_storeN+0x15c/0x168 memset+0x20/0x44 __dma_alloc_coherent+0x114/0x18c Signed-off-by: Rohit Vaswani <rvaswani@codeaurora.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06CMA: generalize CMA reserved area management functionalityJoonsoo Kim
Currently, there are two users on CMA functionality, one is the DMA subsystem and the other is the KVM on powerpc. They have their own code to manage CMA reserved area even if they looks really similar. From my guess, it is caused by some needs on bitmap management. KVM side wants to maintain bitmap not for 1 page, but for more size. Eventually it use bitmap where one bit represents 64 pages. When I implement CMA related patches, I should change those two places to apply my change and it seem to be painful to me. I want to change this situation and reduce future code management overhead through this patch. This change could also help developer who want to use CMA in their new feature development, since they can use CMA easily without copying & pasting this reserved area management code. In previous patches, we have prepared some features to generalize CMA reserved area management and now it's time to do it. This patch moves core functions to mm/cma.c and change DMA APIs to use these functions. There is no functional change in DMA APIs. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com> Acked-by: Minchan Kim <minchan@kernel.org> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Alexander Graf <agraf@suse.de> Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: Gleb Natapov <gleb@kernel.org> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04cma: add placement specifier for "cma=" kernel parameterAkinobu Mita
Currently, "cma=" kernel parameter is used to specify the size of CMA, but we can't specify where it is located. We want to locate CMA below 4GB for devices only supporting 32-bit addressing on 64-bit systems without iommu. This enables to specify the placement of CMA by extending "cma=" kernel parameter. Examples: 1. locate 64MB CMA below 4GB by "cma=64M@0-4G" 2. locate 64MB CMA exact at 512MB by "cma=64M@512M" Note that the DMA contiguous memory allocator on x86 assumes that page_address() works for the pages to allocate. So this change requires to limit end address of contiguous memory area upto max_pfn_mapped to prevent from locating it on highmem area by the argument of dma_contiguous_reserve(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Don Dutile <ddutile@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-27drivers: dma-contiguous: clean source code and prepare for device treeMarek Szyprowski
This patch cleans the initialization of dma contiguous framework. The all-in-one dma_declare_contiguous() function is now separated into dma_contiguous_reserve_area() which only steals the the memory from memblock allocator and dma_contiguous_add_device() function, which assigns given device to the specified reserved memory area. This improves the flexibility in defining contiguous memory areas and assigning device to them, because now it is possible to assign more than one device to the given contiguous memory area. Such split in initialization procedure is also required for upcoming device tree support. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Tomasz Figa <t.figa@samsung.com>
2013-07-02mm/cma: Move dma contiguous changes into a seperate configAneesh Kumar K.V
We want to use CMA for allocating hash page table and real mode area for PPC64. Hence move DMA contiguous related changes into a seperate config so that ppc64 can enable CMA without requiring DMA contiguous. Acked-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> [removed defconfig changes] Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2012-12-11drivers: cma: represent physical addresses as phys_addr_tVitaly Andrianov
This commit changes the CMA early initialization code to use phys_addr_t for representing physical addresses instead of unsigned long. Without this change, among other things, dma_declare_contiguous() simply discards any memory regions whose address is not representable as unsigned long. This is a problem on 32-bit PAE machines where unsigned long is 32-bit but physical address space is larger. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Cyril Chemparathy <cyril@ti.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com>
2012-05-21drivers: add Contiguous Memory AllocatorMarek Szyprowski
The Contiguous Memory Allocator is a set of helper functions for DMA mapping framework that improves allocations of contiguous memory chunks. CMA grabs memory on system boot, marks it with MIGRATE_CMA migrate type and gives back to the system. Kernel is allowed to allocate only movable pages within CMA's managed memory so that it can be used for example for page cache when DMA mapping do not use it. On dma_alloc_from_contiguous() request such pages are migrated out of CMA area to free required contiguous block and fulfill the request. This allows to allocate large contiguous chunks of memory at any time assuming that there is enough free memory available in the system. This code is heavily based on earlier works by Michal Nazarewicz. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Rob Clark <rob.clark@linaro.org> Tested-by: Ohad Ben-Cohen <ohad@wizery.com> Tested-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Tested-by: Robert Nelson <robertcnelson@gmail.com> Tested-by: Barry Song <Baohua.Song@csr.com>
