path: root/include/linux/dynamic_debug.h
2011-10-31treewide: use __printf not __attribute__((format(printf,...)))Joe Perches
Standardize the style for compiler based printf format verification. Standardized the location of __printf too. Done via script and a little typing. $ grep -rPl --include=*.[ch] -w "__attribute__" * | \ grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \ xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }' [akpm@linux-foundation.org: revert arch bits] Signed-off-by: Joe Perches <joe@perches.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-18dynamic_debug: consolidate repetitive struct _ddebug descriptor definitionsJason Baron
Replace the repetitive struct _ddebug descriptor definitions with a new DECLARE_DYNAMIC_DEBUG_META_DATA(name, fmt) macro. [akpm@linux-foundation.org: s/DECLARE/DEFINE/] Signed-off-by: Jason Baron <jbaron@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22dynamic_debug: make netdev_dbg() call __netdev_printk()Jason Baron
Previously, if dynamic debug was enabled netdev_dbg() was using dynamic_dev_dbg() to print out the underlying msg. Fix this by making sure netdev_dbg() uses __netdev_printk(). Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22dynamic_debug: remove unused control variablesJason Baron
Remove no longer used dynamic debug control variables. The definitions were removed a while ago, but we forgot to clean up the extern references. Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-22dynamic_debug: Add __dynamic_dev_dbgJoe Perches
Unlike dynamic_pr_debug, dynamic uses of dev_dbg can not currently add task_pid/KBUILD_MODNAME/__func__/__LINE__ to selected debug output. Add a new function similar to dynamic_pr_debug to optionally emit these prefixes. Cc: Aloisio Almeida <aloisio.almeida@openbossa.org> Noticed-by: Aloisio Almeida <aloisio.almeida@openbossa.org> Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-04jump label: Introduce static_branch() interfaceJason Baron
Introduce: static __always_inline bool static_branch(struct jump_label_key *key); instead of the old JUMP_LABEL(key, label) macro. In this way, jump labels become really easy to use: Define: struct jump_label_key jump_key; Can be used as: if (static_branch(&jump_key)) do unlikely code enable/disale via: jump_label_inc(&jump_key); jump_label_dec(&jump_key); that's it! For the jump labels disabled case, the static_branch() becomes an atomic_read(), and jump_label_inc()/dec() are simply atomic_inc(), atomic_dec() operations. We show testing results for this change below. Thanks to H. Peter Anvin for suggesting the 'static_branch()' construct. Since we now require a 'struct jump_label_key *key', we can store a pointer into the jump table addresses. In this way, we can enable/disable jump labels, in basically constant time. This change allows us to completely remove the previous hashtable scheme. Thanks to Peter Zijlstra for this re-write. Testing: I ran a series of 'tbench 20' runs 5 times (with reboots) for 3 configurations, where tracepoints were disabled. jump label configured in avg: 815.6 jump label *not* configured in (using atomic reads) avg: 800.1 jump label *not* configured in (regular reads) avg: 803.4 Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110316212947.GA8792@redhat.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Suggested-by: H. Peter Anvin <hpa@linux.intel.com> Tested-by: David Daney <ddaney@caviumnetworks.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-02-03Dynamic debug: Add more flagsBart Van Assche
Add flags that allow the user to specify via debugfs whether or not the module name, function name, line number and/or thread ID have to be included in the printed message. Signed-off-by: Bart Van Assche <bvanassche@acm.org> Cc: Greg Banks <gnb@fmeh.org> Cc: Konrad Rzeszutek Wilk <konrad@darnok.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-07dynamic debug: Fix build issue with older gccJason Baron
On older gcc (3.3) dynamic debug fails to compile: include/net/inet_connection_sock.h: In function `inet_csk_reset_xmit_timer': include/net/inet_connection_sock.h:236: error: duplicate label declaration `do_printk' include/net/inet_connection_sock.h:219: error: this is a previous declaration include/net/inet_connection_sock.h:236: error: duplicate label declaration `out' include/net/inet_connection_sock.h:219: error: this is a previous declaration include/net/inet_connection_sock.h:236: error: duplicate label `do_printk' include/net/inet_connection_sock.h:236: error: duplicate label `out' Fix, by reverting the usage of JUMP_LABEL() in dynamic debug for now. Cc: <stable@kernel.org> Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-10-22Merge branch 'for-2.6.37/drivers' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/drivers' of git://git.kernel.dk/linux-2.6-block: (95 commits) cciss: fix PCI IDs for new Smart Array controllers drbd: add race-breaker to drbd_go_diskless drbd: use dynamic_dev_dbg to optionally log uuid changes dynamic_debug.h: Fix dynamic_dev_dbg() macro if CONFIG_DYNAMIC_DEBUG not set drbd: cleanup: change "<= 0" to "== 0" drbd: relax the grace period of the md_sync timer again drbd: add some more explicit drbd_md_sync drbd: drop wrong debug asserts, fix recently introduced race drbd: cleanup useless leftover warn/error printk's drbd: add explicit drbd_md_sync to drbd_resync_finished drbd: Do not log an ASSERT for P_OV_REQUEST packets while C_CONNECTED drbd: fix for possible deadlock on IO error during resync drbd: fix unlikely access after free and list corruption drbd: fix for spurious fullsync (uuids rotated too fast) drbd: allow for explicit resync-finished notifications drbd: preparation commit, using full state in receive_state() drbd: drbd_send_ack_dp must not rely on header information drbd: Fix regression in recv_bm_rle_bits (compressed bitmap) drbd: Fixed a stupid copy and paste error drbd: Allow larger values for c-fill-target. ... Fix up trivial conflict in drivers/block/ataflop.c due to BKL removal
2010-10-15dynamic_debug.h: Fix dynamic_dev_dbg() macro if CONFIG_DYNAMIC_DEBUG not setPhilipp Reisner
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
2010-09-22jump label: Convert dynamic debug to use jump labelsJason Baron
Convert the 'dynamic debug' infrastructure to use jump labels. Signed-off-by: Jason Baron <jbaron@redhat.com> LKML-Reference: <b77627358cea3e27d7be4386f45f66219afb8452.1284733808.git.jbaron@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-07-04module: initialize module dynamic debug laterYehuda Sadeh
We should initialize the module dynamic debug datastructures only after determining that the module is not loaded yet. This fixes a bug that introduced in 2.6.35-rc2, where when a trying to load a module twice, we also load it's dynamic printing data twice which causes all sorts of nasty issues. Also handle the dynamic debug cleanup later on failure. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (removed a #ifdef) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25DYNAMIC_DEBUG: fix documentation errorsFlorian Ragwitz
[akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Florian Ragwitz <rafl@debian.org> Cc: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15dynamic_debug.h/kernel.h: Remove KBUILD_MODNAME from dynamic_pr_debugJoe Perches
If CONFIG_DYNAMIC_DEBUG is enabled and a source file has: #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt #include <linux/kernel.h> dynamic_debug.h will duplicate KBUILD_MODNAME in the output string. Remove the use of KBUILD_MODNAME from the output format string generated by dynamic_debug.h If CONFIG_DYNAMIC_DEBUG is not enabled, no compile-time check is done to printk/dev_printk arguments. Add it. Signed-off-by: Joe Perches <joe@perches.com> Cc: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-16Driver core: remove pr_fmt() from dynamic_dev_dbg() printkJason Baron
When pr_fmt() was added to the pr_debug() code, we added it not only to the dynamic_pr_debug() function, but also to the dynamic_dev_dbg() funciton. However, dev_dbg() doesn't make use of pr_fmt(), so neither should dynamic_dev_dbg(). Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24Dynamic debug: fix pr_fmt() build errorGreg Banks
When CONFIG_DYNAMIC_DEBUG is enabled, allow callers of pr_debug() to provide their own definition of pr_fmt() even if that definition uses tricks like #define pr_fmt(fmt) "%s:" fmt, __func__ Signed-off-by: Greg Banks <gnb@sgi.com> Cc: Jason Baron <jbaron@redhat.com> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24dynamic debug: combine dprintk and dynamic printkJason Baron
This patch combines Greg Bank's dprintk() work with the existing dynamic printk patchset, we are now calling it 'dynamic debug'. The new feature of this patchset is a richer /debugfs control file interface, (an example output from my system is at the bottom), which allows fined grained control over the the debug output. The output can be controlled by function, file, module, format string, and line number. for example, enabled all debug messages in module 'nf_conntrack': echo -n 'module nf_conntrack +p' > /mnt/debugfs/dynamic_debug/control to disable them: echo -n 'module nf_conntrack -p' > /mnt/debugfs/dynamic_debug/control A further explanation can be found in the documentation patch. Signed-off-by: Greg Banks <gnb@sgi.com> Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
