path: root/include/linux/err.h
2006-09-27[PATCH] consistently use MAX_ERRNO in __syscall_returnRandy Dunlap
Consistently use MAX_ERRNO when checking for errors in __syscall_return(). [ralf@linux-mips.org: build fix] Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-01[PATCH] Fix IS_ERR Threshold ValueRalf Baechle
o Raise the maximum error number in IS_ERR_VALUE to 4095. o Make that number available as a new constant MAX_ERRNO. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-19Fix get_unmapped_area sanity testsLinus Torvalds
As noted by Chris Wright, we need to do the full range of tests regardless of whether MAP_FIXED is set or not, so re-organize get_unmapped_area() slightly to do the sanity checks unconditionally.
